Question about Dryers
How to replace the element in model 970-c87192-10
Model 970-5574. Why won't the elements heat?
really sounds like you need a repairman and an electrician at the same time .
Jul 17, 2015 | Kenmore Kitchen Ranges
I have a Kenmore Range Model # 970-5060 and the top element will not work on bake but will on Broil. What is the problem?
No problem - that's the way it is supposed to work.
Note: in some ranges/ovens, the broil (upper) element is a little bit of the time to help even out temperatures, but it will not glow red.
Oct 10, 2014 | Kenmore Kitchen Ranges
Are there fuses for the oven on my flat top stove oven. it is very slow to heat up
Yes, there are fuses (or at least 1 fuse), but if they were bad, your oven wouldn't heat up at all. You may have a bad element. Does your oven have a visible (or hidden) bake element? Does it have a convection fan & element? One of those may be bad, causing slow heating.
Oct 07, 2014 | Kenmore Kitchen Ranges
We have a Kenmroe dryer model 970-c85192-00 that only blows cold air right now.
Check the heating element and the thermal fuses for continuity first
Dec 29, 2012 | Dryers
DRYER RUNS BUT NO HEAT.WHERE CAN THE FUSES BE ?MODEL NO 970-17802-20.SERIAL NO XE73210031.KENMORE
If it runs but no heat that is probably your heating element.
I recently worked on one of theses and got my grandson to snap a few photos of the repair.
417.91702000 Broken dryer belt and felt replacement
Jan 30, 2011 | Kenmore 98702 Stacked Washer/Dryer
The element light will not go off and no burners
The infinite switch is faulty. You'll have to have it replaced (the switch) or replace it yourself. It's not really a serviceable item beyond replacing the switch. They are not expensive though...relative to the range cost. maybe $20-$50us. don't mix up the large burner switch with the small. the small is rated usually somewhere around 5.2-6.6amp. the large 8.9-11 amp.
does your model number start with a 970 or a 110 ?
those three digits identify who made the unit for sears. 970 being frigidaire and 110 being whirlpool.
most local or online parts suppliers will carry the switch you require.
good luck
Sep 26, 2009 | Kenmore Kitchen Ranges
I'm having trouble with the model # provided. If there is no switch directly behind the knob that turns that element on then it has a control board that is most likely behind the back panel about midway down on the left side. If it is this setup you will need to replace the board. If it has a switch directly behind the knob then replace that switch. Make sure unit is not plugged in when looking for or replacing parts.
Oct 06, 2007 | Kenmore 99123 Electric Kitchen Range
Dryers Logo
Top Dryers Experts
