Question about KitchenAid KP26M1X Stand Mixer
Kitchenaid mixer will not start
I took off the rear cover for my wife to clean flour off the vents and when I replaced the cover the unit would not turn on. I checked the current and it has 123v to the control panel. I checked for loose connections and when I moved the control panel it came on at the highest speed. Has me stumped ????
    Novelist:
  • KitchenAid Expert
  • 185 Answers
When you removed the cover you exposed the speed control switch, the black and copper rectangle object under the cover. When you cleaned it you either loosened one or all three of the 3 aluminium screws that are in the top two corners and the bottom center of the speed control switch. You only have to move one of the top two screws a quarter turn in either direction to place the mixer out of sync. The bottom center screw controls the upper speeds and the top two control speed from stir to medium. You can Google speed tune kitchenaid mixer and you will find one or two good videos on how to speed time the mixer. Hope that hlpes if not get back to us so we can Fixya.
Posted on Jan 28, 2015
    Scholar:
  • KitchenAid Expert
  • 173 Answers
The model number shown is for the Professional series which does not have a separate rear cover. Below are links to KitchenAid mixer Service Manuals:
Professional 5/6 quart
http://ep.yimg.com/ty/cdn/mendingshed/kitchenaid6qtservicemanual.pdf
4.5/5 quart
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Posted on Jan 24, 2015
3 Suggested Answers
  • 16 Answers
SOURCE: My Kitchenaid K5SS 300 watt standing mixer launches into the highest speed regardless of the speed ....
I would recommend that you first check the Hall effect sensor which determines the speed.  I had this exact problem (but mine occurred with a 600 professional model) and I actually went out and bought another Hall sensor for about $13.  I replaced the original sensor and made sure that the connection between the sensor and control board was nice and snug. My blender worked as good as new! But I was curious to know if my original sensor was defective so I put it back in mixer and again made sure all of the connections were tight.  Guess what?  My original sensor also made my mixer work!  There was nothing wrong with my original Hall effect sensor except the connection between the control board and sensor was not adequate--unfortunately I didn't check the connections before I decided to buy another one. My guess is that the connection between the control board and the sensor probably loosens or comes undone over time from use and vibrations.
1.  Download the mixer parts and diagrams from the Kitchenaid website to see what the Hall effect sensor looks like. 2.  You'll need a phillips head screwdriver to open up the mixer. 3.  Make sure that the connection between the control board and sensor is absolutely tight and snug. 4.  Also, make sure that the orientation of the sensor connection between the control board and sensor is correct. it's hard to know which way the sensor should be connected because the control board has three prongs and the sensor can attach facing up or facing down. If, after you've made the connections, the mixer still doesn't work.  Disconnect the sensor and reconnect it with the prongs facing the opposite direction and try it.  I actually found the right orientation through trial and error.  By going through this trial and error, I also had my Eureka moment when I realized that the original sensor probably would also work it were reconnected with correct orientation.   5.  This whole process probably takes less than 10-15 minutes to perform.
Posted on Dec 30, 2008
txinspector
  • 359 Answers
SOURCE: Why won't our kitchenaid stand mixer run?
He rdnowak:
I am sure #10 in the highest speed, but are you saying it will only run at #10? if so I would start by removing the cover again. Hopefully no parts are missing. Make sure the selector switch is moving things on the board if possible. I mean if you can move it with you finger you should be able to move it with the selector lever. Sorry for the trouble but I have never taken mine apart I just clean the out side. I do no this. Sometimes I must take something apart and reassemble them several times before getting them to work the way they are supposed to.
Best of luck
'RR
Posted on May 15, 2014
I have to go up to 3 or 4 before the mixer will start
Does the mixer operate on the lower settings once you've got it going at the higher speeds?
If so the motor mechanism may need to be serviced (cleaned). OR it could be the switch mechanism is either 'dirty' (maybe with built up flour?) or has failed and needs to be replaced.
While UNPLUGGED, move the switch back and forth from OFF to full speed many times, if you have compressed air, blow that into the slot around (top & bottom) while operating the switch.
Set to OFF, plug it in the mixer and try it.
If that doesn't fix the problem, then consider having the mixer serviced or replaced.
Nov 27, 2015 | KitchenAid KSM150PSMC Mixer
He rdnowak:
Best of luck
'RR
May 15, 2014 | KitchenAid Pro 600 Stand Mixer KP26M1X-...
My wife was given a ksm90 blender. It looks like it was never used. It had a few yellow spots of yellowish greasy material on it (gear grease ?) When I started it up it had kind of an electricalish...
it should be high temperature grease. it will only drip out if the seal has dried out or cracked.i think the seal has a spring inside it may need changing they should be cheap.and easy to change. or you could always put some flour in the bowl and run it for a few minutes to see if it dries up it may just be lack of use.
Dec 20, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Which part do i need to replace?It seems like I put too much flour.in the bowl.then the mixer started to work very slow.I havea kitchenaid mixer made by Hobart Corp. model k5ss max watts 300 hz 60...
Hello Jovana,
First thing you are going to have to do is take the planetary off and check the key and the gears in the planetary. The parts that you may need to replace are endless as we do not know what may be broke in the unit. More than likely it will be in the planetary of the unit if you get it off and do not find anything post back to this thread and I will get you started on the next step.
Thank you for choosing FixYa
Dec 15, 2010 | KitchenAid 32685 Mixer
After putting flower into mixing bowl large quanity of flower is ejected when mixer is turnon at low speed. Once it starts to mix then it's ok.
Firstly, I think you mean "flour".
Put in your ingredients. Cover the mixer, head and bowl, with a dishtowel. Turn on mixer to "stir" (or lowest speed). But! Mix only for 1 or 2 seconds. Repeat this, with bowl covered, until flour is mixed in enough not to fly out.
Happy baking!
Dec 11, 2010 | KitchenAid Classic Stand Mixer
Wife removed rear cover, blew out dust, brushed lightly with toothbrush. Also removed round black cover on side releasing a spring and cam but seems to be put back correctly. When plugged into power outlet...
There may be a few solutions to you problem. it could be that the carbon brushes located at the left and right of the unit are either gone or improperly seated, as they will only work one way. part number for the brushes is 9706416 after checking these and if they are okay. i would check the board to see if there was any bending atall during the cleaning. there is a metal arm that the white actuator slides into on your board. if this metal arm has been bent even by a 1/4 inch or more it wont make contact and your unit will not operate.hope this helps
Thanks
Oct 04, 2009 | KitchenAid K45SS Classic Stand Mixer
525 watt mixers broken
http://www.kitchenaid.com/flash.cmd?/#/page/customer-service here u go. Customer care will direct you to a certified kitchen aid repair shop in your area.
Apr 21, 2009 | KitchenAid KP26M1X Stand Mixer
The mixing part of mixer not working motor is fine
Hi. Since I can't tell how much you have taken apart, I'll start from the beginning.
Remove the silver band, remove the top cover. At the top front of the mixer locate the transmission housing. If it's plastic, inspect it carefully for cracks around the screws and the body of this housing. If you find cracks, you have found the cheap plastic part that kitchenaid still installs in new mixers, and the cause of your trouble. They know that it's substandard but don't care enough to place a recall notice on this part. It may not please you to know that their replacement part is METAL like the original part should have been. "For the way it's made"! Indeed!
If you intend to repair the mixer yourself, go to kitchenaid's website, enter your model # and locate the parts list for your mixer. Download the drawings, they will assist you with your project.
Be sure to tell kitchenaid what you think of their cheap plastic part.
If this solution has assisted you, please rate it. Good luck! ricardok45
Apr 12, 2009 | KitchenAid KP2671 Professional 6 Series...
KitchenAid 600, Stand Mixer - Loud grinding noise, happened when mixing bread dough. When bowl is lowered (dough hook disengaged)....no noise, hook turns. When bowl is raised so that hook engages dough,...
Hi. Stop using your mixer. If your mixer is still covered by warranty, call Kitchenaid Customer Service, they are very good with warranty repairs.
If your mixer is out of warranty, remove the silver band that surrounds the top of mixer. Remove the top cover. At the front of the mixer, locate the transmission housing which is now exposed. Examine this housing carefully for cracks. If you find cracks anywhere in this housing, you have found the under-engineered plastic transmission housing. Kitchenaid's replacement housing is made of metal. Your plastic housing has no business being in a mixer that is marketed as being able to mix bread dough. It cannot!
If you're confident that you can make the repairs yourself, go to the Kitchenaid website and download the parts drawings. Remove the Trans. housing, remove the worm gear shaft assembly which is driven by the motor.. Remove and save as much grease as necessary to thoroughly inspect the worm gear. Inspect the worm shaft bearings. Look for cracks, or missing pieces on the bearings. Look for crunched cogs on all gears. Be prepared to wait at least a month for your parts to arrive after you order them. The replacement grease should be Shell Darina 2, or Chevron FM ALC EP 2.
If you're not confident about repairing this yourself, call Kitchenaid and determine the nearest "approved" repair shop.
You may be able to pressure Kitchenaid to pay for the damaged parts in your mixer. They are still installing these plastic Trans. housing on new mixers. Insist on a metal cover when replacing. Apparently, Kitchenaid feels no shame in their manufacturing process, and will not issue a recall notice for these housings. They are substandard at best.
If you found this solution helpful, please rate it. Good luck! ricardok45.
Jan 31, 2009 | KitchenAid KP2671 Professional 6 Series...
KitchenAid K45SS will not run
If you know what the brushes in the motor are then you should get some from kitchen aid or an appliance parts store. If you dont know what brushes for the motor are then find a local repair shop that will fix it for you. All the best.
Mar 26, 2008 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Food Mixers Logo
93 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
