Question about Philips 27PT563S 27" TV
Tv picture is shrinking.
The screen is getting smaller from the top the black bar is about 3 inches now. it looks like the top of the screen is folded over with a black bar at the very top
    Genius:
  • Philips Master
  • 1,550 Answers
Check for dry electrolitic capacitors near the vertical IC
Posted on Jun 23, 2009
Why are the movies half screen?
Movies that are created for "Wide Screen" viewing show up in letterbox on your TV. If you go to a theatre you notice it is a big rectangle. To be able to fit all of the widescreen movie on a TV it has to make the height smaller.
Because many people want to see the "complete" Movie, the "Letterbox Format" came about. I do NOT know what the word "Letterbox" actually means, or how that term was chosen. To get the complete Rectangle into that Square, they discovered that they could shrink the entire rectangle to fit that square. Meaning, what used to take 2 inches on your screen, now may only take 1.75 inches. Now a problem arrose. When you shrink the WIDTH to fit your dinky Square of a TV, the HEIGHT also has to be shrunk along with it, or else you're stretching the image as if it was on silly-putty ("Compression"). When the image was shrunk to fit the TV Screen, they were left with a gap at the top and bottom of the screen. So they simply fill it in with "Black". I guess the only alternative was to leave it snowy.
Nov 13, 2014 | Televison & Video
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
JVC D-Series TV top of picture shrinking
There are probably two capacitors that are bad in the vertical circuit. Not too hard to replace if you have any experience at all. Find the vertical output IC ( usually IC451 or similar ) and simply change the closest electrolytic capacitors. A professional can do this easily. Could cost up to $150.
May 13, 2009 | JVC AV-27D302 27" TV
When Playing Halo 3... The Screen Shrinks Down...
kyleolver,
16:9 is the widescreen mode, the other size is 4:3 ratio which is what the game's native size, it is picture boxing by the plazma is showing the size as not to distort the image, to get the full screen picture, but make sure it's not the plazma's setting first - where it selects the size of the image, you may have the streched version on your normal play.
randy320sgi
Dec 21, 2008 | Samsung HP-R4272 42 in. Plasma HDTV
Hoizontal Bar across RCA Model 24F501TDV Color TV
you may need to change your resolution on tv settings as well as cable or satelite settings if you have one of those
Dec 12, 2008 | RCA 24F501TDV 24" TV
Normal picture mode make the sharper picture quality but smaller screen apparance
If the broadcast is in 4:3 (square) then either you can have the black bars on the side, or the TV can stretch the image to fill the screen.
Nothing wrong with your set. The broadcast must be in 16:9 to fil the screen.
Aug 07, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Picture size is shrinking within screen
hi there, you have vertical section prob., repalce imeditely the electrolytic capacitor at the vertical section. do some test and check up. ty
Feb 18, 2008 | Philips 27MT3305 27" TV
SCREEN GOES BLACK AFTER 1 MINUTE
In electronics dust has nothing to do. cleaning will not solve your problem your problem is due to trouble in vertical section. mostly it is due to electrolytic capacitor in vertical section is defective.it is common problem. also check supply to vertical section. "THE SCREEN SHRINKS TOWARDS THE TOP OF THE SCREEN FOR A FEW SECONDS BEFORE THE PICTURE TURNS UPSIDEDOWN THEN TURNS BLACK." is called fold over. regards thanks
Sep 12, 2007 | Sony KV-32S42 32" TV
Shrinked picture of 29 inch television.
It is a pincushion problem. There is a bad cap and or a bad diode in the horzontal section.
Oct 29, 2006 | Toshiba 27A51 27" TV
Philips 27PT563S 27" TV Logo
499 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
