Question about Frigidaire Kitchen Ranges
Frigidaire Gallery 30 Electric Double Oven Model CGEF308TNF Clock runs fast
The clock gains 4 minutes every 1/2 hour. I have reset it a dozen times and tried in 24 hour mode. Still fast.
  • 7 Answers
SOURCE: Frigidaire electric range
is there voltage going to the erc (electronic range control)?
Posted on Feb 09, 2008
SOURCE: Frigidaire Electric Smoothtop Range......getting F 1 error on digital display
F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Posted on Aug 02, 2008
aborcass
  • 2651 Answers
SOURCE: Frigidaire stove model gles388dsb
sounds as if there is a problem with the latch assy, there are 2 switches mounted on the latch mechanism for monitoring positon of hte switches, seems as if one has gone bad, not recognizing the door lock positon therfore continues to rotate without stop.part number for the motor latch assy w/switch and bracket 318095957 . located behind rear panel
Posted on Nov 24, 2008
SOURCE: Frigidaire Electric flat top Range
My range will not hold the heat for either the convection or regular heat. the model number is CGLEF385AS2
Posted on Dec 24, 2008
  • 149 Answers
SOURCE: Ilve electric oven modle P 90 WMP. the digital
on the back of the clok is 4 wires the brown and the blue suply power for the clock and timers functions the 2 reds the timer makes these live if only one is live when set to manual then its best to replace the clock or if you can change the relay that the wires ar conected too
Posted on Mar 23, 2010
When we reset the clock after a power outage, the clock runs fast now almost a minute in 30 seconds. Bosch HBL5750
Advise manufacturer; may give you a warranty on this part even after it has expired because of nature of the problem.
Mar 08, 2015 | Bosch HBL5750UC Electric Oven
How to fix frigidaire wall oven beeping error message f11
Good Morning Friend,
I understand that your Frigidaire wall oven is beeping and showing an F11 error code. Typically an F11 error code states that there is a shorted key, or a button has been detected as pressed for a long time. I suggest hard resetting your appliance, by cutting the power at your homes circuit breaker for 3-5 minutes. While you are resetting your oven, make sure to wipe down the control panel. The panel is very sensitive and could be detecting something that has splashed or spilled onto it, even dust. When you bring power back to your appliance you will need to start by setting the clock. Turn your oven on any cycle at any temperature. If you are still receiving an F11 error code, I suggest contacting your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
May 14, 2014 | Frigidaire 30 in. Electric Gallery Series...
I have a frigidaire gallery wall oven (2003). We set the self cleaning and then canceled. The door is now locked and the fan is running. I tried to reset breaker and it is still locked. How can I get the...
If tripping and turning the circuit breaker off for about 10 minutes does not work, contact Frigidaire. Sounds like the control board and/or door switch will need replacing.
Aug 07, 2012 | Frigidaire 30 in. Electric Gallery Series...
My frigerdaire oven heats for a while about 15-30 minutes then shuts down with a beeping noise and a f3 code.
Good Afternoon Friend,
I see that your Frigidaire double oven heats up for about 15-30 minutes, then shuts down and begins beeping while showing an F3error code. The F3 states that the oven is sensing a potential runaway temperature. This is possibly a sensor issue or it could be a false error code.
I suggest giving your double oven a hard reset by cutting the power at the circuit breaker for at least 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Let the oven heat up, and if you are still receiving an F3 error code, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Jan 27, 2012 | Frigidaire 30 in. Electric Gallery Series...
Pleb30t8ccb
I see that your Frigidaire double oven, model# PLEB30T8CCB, is having trouble with the top oven not heating.
Turn the oven on to heat up, and if it does not, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Jan 09, 2012 | Frigidaire 30 in. Electric Gallery Series...
I try to turn on and when I do the temp starts going backwards until it is off. The clock will do the same things after I try resetting the breaker.
is there a time bake or something similar on it,sounds like it's stuck on that cycle,next time send the model number,could have a bad touch pad or clock assy. stuck on a time cycle so no matter what you do it's counting down
Nov 21, 2010 | Frigidaire 30 in. Electric Gallery Series...
F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Apr 01, 2009 | Frigidaire 27 in. Electric Gallery Pro...
I started my oven on ''clean'' -- how long should this take?
Whithout knowing the model number in general it takes several hours for the cleaning cycle. My oven takes approx. 4 hours to complete a good cleaning. On my own oven, you can set the timer for as long as you want. Do you have an owners manual? If not, you can find one here...........
http://www.frigidaire.com/support/manuals.asp
Mar 20, 2009 | Frigidaire 30 in. Electric Gallery Series...
Kitchen Ranges Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
