Question about Nordic Track C2255 Console (treadmill)
Why does the treadmill stop in the middle of walking
Can I fix a NB1500 treadmill belt that is bowing in the middle? I've tried adjusting the tighteners on the back and cannot eliminate the bowing in the middle.
No, you need a new belt as it is stretched because that is where it gets pounded all the time. $50 to $100 depending on the quality you choose.
New Balance 1500 Treadmill Walking Belt 20 x 119 - Treadmill Doctor
https://www.treadmilldoctor.com/new-balance-walking-belt-1500
Replacement Walking Belt For The New Balance 1500 Treadmill. Belt size 20" X 119".
New Balance 1500 Treadmill Walking Belt - eBay
www.ebay.com > ... > Fitness Equipment & Gear > Other Fitness Equipment & Gear US$94.99 - ‎In stock
New Balance 1500 Treadmill Walking Belt in Sporting Goods, Fitness, Running & Yoga, Fitness Equipment & Gear, Other Fitness Equipment & Gear ' eBay.
Amazon.com : New Balance Treadmill Running Belt Model 1500 ...
https://www.amazon.com/Balance-Treadmill-Running-Belt-Model/.../B00H4QKAOO Rating: 5 - ‎1 review
This is a 1-ply Residential walking belt, some sellers will try to sell you a 2-ply belt (claiming better quality) for your treadmill, which is not recommended for ...
Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt ...
https://www.amazon.com/Newbalance-Treadmill-Running-Belt-Model/.../B008EYOF... Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt Model 1500 : Exercise Treadmill Belts : Sports & Outdoors.
NB1500 treadmill belt Google Search
Aug 14, 2017 | Exercise & Fitness
I just got a sportcraft tx 400 treadmill from a family that had two and was getting rid of one. my first time walking on it it stops in the middle of walking and starts and stopslike the belt is stuck or i...
The plank under the belt may be badly worn, Natashia. You MIGHT be able to get a little graphite powder under the belt, but your best bet would be to disassemble it, remove the belt, and have some countertop laminate (like Formica) laminated to the top of that plank. That's what it was originally surfaced with, but after some time it wears through.
Aug 12, 2014 | Exercise & Fitness
I have a ET-388 threadmill. however when i walk or run on the machine the sound is very heavy. can you tell me what is wrong of is it normal?
hi,
Its time to lubricate your treadmill.
You must obtain the proper lubricant for your treadmill. There are several different types. Contact your manufacturer for what type is needed. Using the manufacturer provided allen wrench, loosen the walking belt approximately 10 full turns on each side of the rear roller. Apply approximately 1/2 ounce of lubricant directly in the middle of the walk area underneath the walking belt upon the deck. Retighten the rear roller 10 turns on each side. Run the treadmill at 6.0 mph for 2-3 minutes to spread the lubricant evenly. Wipe excess lube from the sides of the belt. Walk on treadmill to check for proper tension on belt.
for make it easy for you I have added a video. ok
Jul 14, 2011 | Spirit Esprit by ET-8 Folding Treadmill
Belt on treadmill is moving towards the right and bunching up
you need to adjust the travel of belt. to do this you need a allen wrench that came with it. if you have it run treadmill at slow speed,go to the rear right at the right end cap there is a hole, use the allen wrench and unscrew slowly while watching the belt until returns to the middle. if it slips when walking go back to rear and adjust by screwing in one turn on each side until belt wont slip.
Feb 09, 2011 | Proform 380 Treadmill Walking Belt
I've had my treadmill for a good while now(about 6 years) and have used it A LOT. However, now it just stops on me after about 35 minutes or so. The controls continue to run, but not the belt. Have I just...
If the treadmill slows down or cuts off when warm it is probably a worn or dry walk belt.Lift the edge of the walk belt and feel the underside of it about 1 inch from the edge,now compare that to the underside of it in towards the middle where your feet are stepping on it,if that area feels alot more frayed or fuzzy the walk belt is worn.Now rub your hand on the platform surface where the walk belt rides,you should feel a wax film on the platform,if not you can purchase treadmill wax from the manufacturer,retailer or on-line.Apply the wax under the belt in towards the center 2/3 of the belt area,that should be done whenever you don't feel that wax film when you check it.
Aug 17, 2009 | Proform Exercise & Fitness
Squeaking noise on my Proform 580 Cross walk
it is the edge of the belt on the deck. Walk in the middle. Eric
Aug 04, 2009 | Exercise & Fitness
Nordic Track C2255 Console (treadmill) Logo
64 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
