Question about Health & Beauty
What isreverse t3 common name - Health & Beauty
How to connect to cisco 7120-t3 router
You can use serial cable to connect via your pc , you will need software like putty to use it
putty download link :
http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html
Mar 20, 2013 | Cisco 7120-t3 Wired Router cisco7120-t3 T3...
I have a single phase copland compressor NEW ( AG133ET-001)that i just replaced. i wired common leg from contactorsT3 to compressors T3(common winding,From contactors T1 to compressors T2(Run winding?)...
you will have to look at the schematic for this theirs different units that wire different way but that sounds correct the way you have it you can double check reverse the start and run always write this down when doing these the supply house can help you to be sure just ask them say hay the diagram has worn away what is t1,t2,and t3 double check your cap it could call for a different size all compressors that ive seen does take a start capacitor some even require start assist kits unless they are three phase what is this compressor going on email me I will help you more and even call my supply house if need be pendletonheatandair@hotmail.com
Sep 14, 2010 | Heating & Cooling
Is there a differance between T and T3 terminal on R7184P furnace controler. I W from thermostat go to T or T3.I am trying to find the C Common port to connect the swithch relay to control external...
you may have to pick up the common from the circuit board. alot of times those contactors are breaking the line voltage side of the power leg and not the common. a 240volt circuit will operate without the nuetral. there is a difference in the t3 terminal so play it safe and pick up the common at the board
Dec 19, 2009 | Honeywell Programmable Thermostat Heater
My sony dsc-t3 cybershot has vertical lines on the display
This is a problem known to Sony. They had a recall on the T3 because of it. They extended the recall, however, the extension ended in about March of '08. Some recall - You had to stumble on it at their web site to know about it!
I got my T3 repaired in May of '08, but had to pay shipping both ways to Laredo, the nearest Sony repair place. They insisted on insurance, so it cost almost as much as their flat fee repair of $121.
They fixed the camera, but it didn't focus as well after that. I didn't realize that 'til after their 30-day repair warranty period was up.
Here's their email, if you want to wrestle with them:
SONYSVCLRD@AM.SONY.COM
Recently I began getting "Turn power off and on again" message. It's a common problem, but again, Sony offered no suggestions. They basically wanted $121 to fix it.
The FixYa site helped me "fix" it by flipping the lens cover open (down) with my finger when turning it on.
I am not buying any more Sony cameras, and will probably sell this one with a disclaimer. There are too many trouble-free high-spec cameras around to fool with Sony-baloney. They've gone too far downhill.
I'll probably get a Canon S90. It's almost the same size as the T3 and much higher-spec.
Hope this helps!
Dec 12, 2009 | Sony Cyber-Shot DSC-T3 Digital Camera
I need a complete workingsource code written in
This is a simple source code for Simple calculator in Java using RMI
//mathServer//
import java.rmi.*;
import java.rmi.Naming.*;
import java.rmi.server.*;
import java.rmi.registry.*;
import java.net.*;
import java.util.*;
interface mathInterface extends Remote
public int add(int a,int b) throws RemoteException;
public int subt(int a,int b) throws RemoteException;
public int mult(int a,int b) throws RemoteException;
public int div(int a,int b) throws RemoteException;
public class mathServer extends UnicastRemoteObject implements
mathInterface
public mathServer() throws RemoteException
System.out.println("Initializing Server");
return(a+b);
return(a-b);
return(a*b);
return(a/b);
public static void main(String args[])
try
mathServer ms=new mathServer();
java.rmi.Naming.rebind("MathServ",ms);
System.out.println("Server Ready");
catch(RemoteException RE)
System.out.println("Remote Server Error:"+ RE.getMessage());
System.exit(0);
catch(MalformedURLException ME)
System.out.println("Invalid URL!!");
//mathClient//
import java.rmi.*;
import java.awt.*;
import java.awt.event.*;
public class mathClient extends Frame implements ActionListener
Button B1=new Button("Sum");
Button B2=new Button("Subtract");
Button B3=new Button("Multiply");
Button B4=new Button("Divide");
Label l1=new Label("Number 1");
Label l2=new Label("Number 2");
Label l3=new Label("Result");
TextField t1=new TextField(20);
TextField t2=new TextField(20);
TextField t3=new TextField(20);
public mathClient()
super("Calculator");
setLayout(null);
l1.setBounds(20,50,55,25);
add(l1);
l2.setBounds(20,100,55,25);
add(l2);
l3.setBounds(20,150,55,25);
add(l3);
t1.setBounds(150,50,100,25);
add(t1);
t2.setBounds(150,100,100,25);
add(t2);
t3.setBounds(150,150,100,25);
add(t3);
B1.setBounds(20,200,80,25);
add(B1);
B2.setBounds(100,200,80,25);
add(B2);
B3.setBounds(180,200,80,25);
add(B3);
B4.setBounds(260,200,80,25);
add(B4);
B1.addActionListener(this);
B2.addActionListener(this);
B3.addActionListener(this);
B4.addActionListener(this);
addWindowListener(
new WindowAdapter()
public void windowClosing(WindowEvent e)
System.exit(0);
public void actionPerformed(ActionEvent AE)
if(AE.getSource()==B1)
sum();
else if(AE.getSource()==B2)
subt();
else if(AE.getSource()==B3)
mult();
else if(AE.getSource()==B4)
div();
public void sum()
int i=Integer.parseInt(t1.getText());
int j=Integer.parseInt(t2.getText());
int val;
try
String ServerURL="MathServ";
mathInterface MI=(mathInterface)Naming.lookup(ServerURL);
val=MI.add(i,j);
t3.setText(""+val);
catch(Exception ex)
System.out.println("Exception:"+ex);
public void subt()
int val;
try
val=MI.subt(i,j);
t3.setText(""+val);
catch(Exception ex)
public void mult()
int val;
try
val=MI.mult(i,j);
t3.setText(""+val);
catch(Exception ex)
public void div()
int val;
try
val=MI.div(i,j);
t3.setText(""+val);
catch(Exception ex)
mathClient MC=new mathClient();
MC.setVisible(true);
MC.setSize(600,500);
Jul 03, 2009 | Microsoft Computers & Internet
I have a TLKR-T3 and a T5720 radios. can they communicate? Thanks
No, they have no frequencies in common. The TLKR-T3 uses the PMR446 frequencies common in Europe. The T5720 uses FRS freqeuncies common in the USA.
Dec 19, 2008 | Motorola Talkabout T5720 (7 Channels)...
Apple-Mac 'Leopard' operating system and my T3
you might need Mark Space software to get then to talk
May 19, 2008 | Palm Tungsten T3 Handheld
No Ranging Response received - T3 time-out
below 55dBmv TX is a lot better. Could be a bad service line. Also if you call the cable company and have them come out again. Have them put their DSAM meters on the house lines as well as the service tap and have them check for upstream ingress. a lot of things can cause this. It could be a loose fitting somewhere in the house. A t.v.'s shielding may be going out causing unwanted frequencies bleeding in and creating all kinds of noise on the upstream spectrum going back to the node. It could even be a neighbor causing this with their own equipment. If that's the case their maintenance techs should be able to find that.
Mar 13, 2008 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
DSC-T3 Sony, Image from the lense is not diaplayed on the screen
Yes , this is very common with T3 : it is caused by faulty CCD sensor ( see enclosed pic of a sensor and lens assy . ) and this needs replacing . Good news is that Sony will repair free of charge.2bcdbc0.jpg
Dec 05, 2007 | Sony Cyber-Shot DSC-T3 Digital Camera
Synchronizing Tungsten T3 with desktop or laptop
I recently re-installed my T3 program
What do you mean?
  • Did you restore your T3 from a backup on the PC?
  • Did you install programs on the T3 using the PC's "quick install"?
Is Palm Desktop showing the correct Contact/To-do/Calendar Data?
How are the conduits set up? (From Palm Desktop, select Hotsync->Custom)
Nov 15, 2007 | Palm Tungsten T3 Handheld
Health & Beauty Logo
26 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
