Question about Midea Dehumidifiers
Code P1 for mdf-65AE-BA8 dehumidifier - Midea Dehumidifiers
3 Suggested Answers
  • 4736 Answers
SOURCE: I have West ponte Mdf 65 Ae BA8 dehumidifier 1
You may have the humidity/moisture level set to high. Try lowering it to 35%. Or if you don't have a LED Screen on your unit, turn it to maximum.
In addition, most dehumidifiers don't work well if the air temperature is between 40 & 60 degrees F. Keep in mind, the temperature at floor level in a basement is colder that the air temperature at chest high level. Raising the unit up, off the floor on something sturdy enough to handle the weight (with a full tank of water) and the vibration, may help.
Hope this helps you to troubleshoot and solve the problem. Please let me know. Thanks.
Posted on Jun 03, 2011
heatman101
  • 43501 Answers
SOURCE: The dehumidifier is a MDF-65AE. The top area above
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Posted on Aug 13, 2011
What is the P1 code on my Dayton Dehumidifier 5eaj9 mean?
Empty the bucket. Reseat the bucket carefully or the code will not reset. This is the only documented action for code P1.
Jun 14, 2014 | Dehumidifiers
Spt 65 pint error code p1
According to the manual, this code, P1, means that it is in a defrost cycle. I now have the problem that my unit is in the P1 mode as often as it is in the dehumidification mode.
May 15, 2012 | Sunpentown 65 Pint Dehumidifier with...
The dehumidifier is a MDF-65AE. The top area above the storage water bucket is freezing and the water leak's all over the floor?
heatman101
Jul 02, 2011 | Kenmore Dehumidifiers
I have West ponte Mdf 65 Ae BA8 dehumidifier 1 year old. Filter is clean. It worked last summer but now after the winter it is running fine but no water is comming in the bucket eventhough basement is...
Jun 03, 2011 | Dehumidifiers
Our dehumidifier model #MDC-25AEN3 or MDC-45AE or MDC-65AE only dehumidifies about 1 inch in the pan. There is about 80 percent humidity so something is wrong because it should fill it up. It has worked...
There are many reasons for a dehumidifier tto not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Apr 09, 2010 | Dehumidifiers
Code on Top
I have another of their dehumidifiers, the MDF1-30AE. The first time the P1 came on, the unit stopped, because the filter needed cleaning. Recently P1 came on but the unit didn't turn off, and I had already cleaned the filter, so I phoned Midea customer service at 1-866-646-4332. The man told me P1 means it's in defrost mode and said to just leave it on and the P1 will eventually go away. It's been a while though....
Dec 01, 2009 | Midea MDC-45AE Dehumidifier
Polar wind dehumidifier: p1 or p2 code after emptying tank.
P1 error indicates that:
  1. The water tank on the side of the unit is full.
  2. The water tank in not properly seated in the housing.
  3. The switch at the back of the water tank housing is not engaged or is loose
Jul 24, 2009 | Kenmore 54501 Dehumidifier
What does P1 mean on display?
Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Service Rep. described the following code for my dehumidifier model (DDR657EE):
P1 = Defrosting: the unit will go into Defrost mode periodically to ensure that the parts are working at the right operating temperature. It should be in Defrost (P1) mode for only a brief period of time. If the unit is in Defrost (P1) mode continuously for a couple of hours (or more), then you should call Danby Service for further assistance.
He had no documentation of a P2 code for my model.
He also described other General Codes (applicable to most Dehumidifier/Humidifier models):
E1 = Not enough water
E2 = Not draining
E3 = Water temperature too cool
E4 = Overflow Switch activated
E6 / E7 = Problem with Temperature Sensor
I hope that helps.
May 16, 2009 | Danby Dehumidifiers
My model is DDR4009EE, after it run for a while, the display changed from RH to "P1",what does "P1" mean?
My Danby DDR657EE shows P1 periodically also. So, I called Danby.
He also described other General Codes (applicable to most Danby Dehumidifier/Humidifier models):
E2 = Not draining
So, if you see P1 periodically (for brief periods), then it would be normal.
Also, here is a link to Danby's FAQ page for Dehumidifiers (which answers some common questions):
https://www.danby.com/faqs.php?cat=12
I hope that helps.
May 11, 2009 | Dehumidifiers
P1 error code
Take out your filter and clean it, if its dirty your machine can frost up due to the lack of air flow and will not work correctly. Once you clean it, it should be fine.
Sep 13, 2008 | Danby DDR2506 Dehumidifier
Dehumidifiers Logo
56 people viewed this question
Top Midea Dehumidifiers Experts
J.D. Browning
J.D. Browning
jasbo
jasbo
 Russ Hill
Russ Hill
Are you a Midea Dehumidifier Expert? Answer questions, earn points and help others
