Question about Tacsew Sewing Machines
I have a T111-155 Tacsew walking foot sewing machine & need a parts manual.
Trifect7
  • 57 Answers
SOURCE: How do I attach a walking foot
Okay let's get started.
  • First let's look at the walking foot.
  • Turn the bulky body so that it's away from you.
  • On the left you see a groove that is going to be where you attach the foot to your machine.
  • On the right is a u-shaped arm which you can move up and down. It will go over the needle clamp
Now, let's remove your present foot from the machine and look at it.
  • Loosen the foot screw until it almost comes off. (if it does come off, screw it back on a bit.) The screw is on the left of the foot-bar.
  • On the right you'll see the needle bar with a needle clamp (what you tighten when you replace a needle) on the right of the needle-bar.
Okay the walking foot business.
  • slide the walking foot into position so that the foot screw is in the slot on the right and the u-shaped arm is over the needle clamp, with the needle clamp in the middle of the u-shaped opening.
  • Tighten the foot screw securely, it's going to be under more strain than normal.
  • While you're at it, check that the needle-clamp is nice and tight as well.
Okay, then! There you go... Happy sewing.
Are you happy? Than please vote
Here are a few helpful pictures.
Posted on Mar 02, 2008
  • 3 Answers
SOURCE: Help with Thompson mini walking foot...
Hi
www.sailrite.com
These guys should have a manual for you. Just tell them you have a LS1 Straight Stitch.
The Thompson machine was the precursor to a whole slew of walking foot clones.
Sailrite may not acknowledge the Thompson but I have researched a few things
and the Sailrite Machines are direct descendants.
Hope this helps.
Posted on Oct 27, 2008
riclap
  • 3 Answers
SOURCE: looking for a manual
www,raichert.com has a free PDF download for the manual for this machine but his pictures are not good. Still, it may be enough to let you figure out what to do.
Posted on Dec 20, 2008
riclap
  • 3 Answers
SOURCE: tacsew lu-563 sewing machine
Generally going to have to be addressing the drive motor, either substituting a lower speed clutch motor for the existing one, ie if you have 3000 rpm motor, then going to a 1725 rpm motor. Alternatively, selling the clutch motor and buying a servo motor instead, which should be available with a variable maximum speed control. The Sewquiet 4000 can select different speed ranges with the flick of a switch. If you already have a servo motor and it does not have a variable max speed, then switching the drive pulley on the servo motor to a smaller size should help
A more convoluted solution would be building a support under the table for a layshaft with different pulley sizes so that the motor could drive one pulley and then a smaller pulley on the shaft would drive the sewing machine. Not a bolt on solution but pretty cheap to do if you are good at fabricating.
Posted on Jan 01, 2009
JUKI HOME SEWING DIVISION 8500 NW 17 th Street Miami, FL 33126 Phone: (305) 594-0059 ingrid@juki.com she will send you one
Posted on Jun 03, 2009
Can the presser foot be adjusted to acomadate thicker fabric?
You may try contacting this vendor:
Tacsew Industrial Sewing Machines at SewingGold com including the T111 155...
Unfortunately, trying to sew thicker fabric than intended for the machine could cause damage. Most machines have a fabric "thickness" limit.
Nov 07, 2016 | Tacsew Sewing Machines
How to adjust pressure foot pressure on husqvarn viking disginer 1 sewing maching
I'm confused by your question, which mentions two machines. The presser foot pressure on a Tacsew T111-155 is adjusted by turning the knob on the left side, top of the machine that is directly over the needle. The Designer 1 mostly sets its own presser foot pressure, but it can be increased or decreased by following the procedure on p. 13 of the manual: http://new.husqvarnaviking.com/SiteMedia/Products/Machines/Support/Designer_I_manual_EN.pdf
May 22, 2014 | Tacsew T111155 Mechanical Sewing Machine
How to install Bernette 65 walking foot?
Here is the link to the manual for the Bernette and it shows how to install and use the walking foot. Good luck with this! THe Bernina is a great machine.
http://www.manualslib.com/manual/389081/Bernina-Bernette-25.html?page=61
Apr 16, 2014 | Bernina BERNETTE 65 Mechanical Sewing...
Can't find place to order parts
http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313&_nkw=Tacsew+T500&_sacat=0
found a couple of things on fleebay drive belt and a new one for about £120 quid
you can try other ebay sites like ebay.it or ebay.fr etc
info
Tacsew Tacsew T500 : Best Quailty Portable Metal Blind Stitch Hemmer Machine Manufactured by Huei Hwang Tony TAIWAN Machinery Company. Ltd. for Tacony Tacsew Industrial Sewing Machines in the USA
usa site ask them for the parts you need
http://www.american-sewing.com/tacsew-t500-port.html
Feb 13, 2014 | Tacsew T500
Replacement foot control for tac sew T500
try ebay
www.allbrands.com
www.shop.heavysew.com
industrial-sewing-machines.com
www.amapparelsupply.com
Mar 26, 2012 | Tacsew T500
I have the White Sewing Machine (Jeans Machine) Model No. 1999 and I need a users manual and also walking stitch foot can you help?
singer.com has a free operation manual
on the singer home page at the bottom look for instruction manuals & click on it & then in the search box put w1999 & then you can download it
here are 2 website to try for the foot---sewingpartsonline.com or sewingmachineparts.net
Dec 11, 2010 | White Sewing 1999 Mechanical Sewing...
Where can I purchase an instruction manual , walking foot & embroidery foot for a JANOME MEMORY CRAFT 4800 QC
try janome website for the walking & embroidery feet & manual
try these sites for manuals also
(pdf) manuals online.com
sewusa.com
sewingmanuals.com
mastersewusa.com
sewingmachineplus.com
homeappliance.manualsonline.com
Jul 19, 2010 | Janome Memory Craft 4800QC
Sewing Machines Logo
123 people viewed this question
Top Tacsew Sewing Machines Experts
Rommel Balcita
DavidinClt
Level 1 Expert
Ruth summersides
Are you a Tacsew Sewing Machine Expert? Answer questions, earn points and help others
