Question about Angelcare Ac401 Single Baby Movement Sound Monitor
Why can't I see tic and movement icon on the parent unit
Do i have to keep the tick sound on my parents unit? how will i sleep with that noise?
on the back of the base unit there is a switch with which to select between three options. I never found any use for the "ticking"! BTW excellent product/ remember to turn it off before taking the babe out the the crib. You'll be running back to do so when the very loud alarm goes off!!
Nov 25, 2010 | Angelcare 2009 Movement Sensor Baby...
I request information about angel care AC401 We have build this product but we are not able to work it. When we turn on the unit parent the digital screen shown "--" and the nursery unit icon...
turn both the nursery and parent units off.
turn on the parent unit.
hold menu for 5 secs until it beeps.
turn on the nursery unit.
press and hold the little round blue light at the top for about 5 second until it beeps.
the parent unit waits for the signal then pairs.
Nov 08, 2010 | Angelcare Baby Movement and Sound Monitor...
Angelcare monitor Model #AC420-P no transmittion between base and monitor. no battery problems in either
Had exactly the same problem but this worked. Never even realised there was a button on the top of the unit!!! It looks like a little LED at the base of the hoop. Happy monitoring.
CONNECTING THE PARENTS UNIT TO THE NURSERY UNIT:
If you lose the connection between the 2 units,turn them both off. Turn ON the parents unit and
press and hold the MENU button ,the "out of range"indicator will flash and you will hear a
beep.Turn ON the nursery unit and press and hold the top button of the nursery unit to reconnect.
The Tic light flashes.This normally happens within a few seconds and you will hear a bleep
to confirm it. If successful, the parents unit display will first show the channel of transmission (C1
to C8), which will be replaced by the room temperature and icons for all activated functions.
Note : The connecting process should be done within 30 seconds. If longer, the operation will be
ignored and you will have to start over.
• PAGING: If you want to locate the parents unit, press the top button of the nursery unit.
Aug 10, 2010 | Toys
Angel care unit is beeping every 3 seconds
Press MENU once.
Press UP arrow until the swinging tick indicator is no longer showing (just movement and sound)
Press SELECT.
Mar 16, 2010 | Angelcare 2009 Movement Sensor Baby...
Angle care wont connect to the base
Manuals: http://www.angelcare-monitor.com/Canada/en/help
Had same problem - here's what worked for AC401 (from manual):
CONNECTING THE PARENTS UNIT TO THE NURSERY UNIT: If you lose the connection between the 2 units,turn them both off. Turn ON the parents unit and press and hold the MENU button ,the "out of range"indicator will flash and you will hear a beep.Turn ON the nursery unit and press and hold the top button of the nursery unit to reconnect. The Tic light flashes.This normally happens within a few seconds and you will hear a bleep to confirm it. If successful, the parents unit display will first show the channel of transmission (C1 to C8), which will be replaced by the room temperature and icons for all activated functions.
Dec 20, 2009 | Angelcare 2009 Movement Sensor Baby...
I droped the monitor last night and I only get to dashes appearing on the screen and it wont pick up any sound!
Manuals here: http://www.angelcare-monitor.com/Canada/en/help#tabs-2
Nov 26, 2009 | Angelcare Deluxe Movement Sensor & Sound...
My parent unit wont do anything, it just flashes with the nursery unit simble and i can not access the menu.
Oct 16, 2009 | Angelcare Deluxe Movement Sensor & Sound...
The parent unit does not recognize that the nursery unit is on. all the correct lights are displayed on the nursery unit for normal function, but the parent unit display indicates that the nursery unit is...
Sounds like the units need to be paired. Start with all units off. Then turn on one of the parent units. Press and hold the menu button until it beeps. Quickly turn on the nursery unit and press and hold the button on the nursery unit that has the parent unit icon below it. After a couple of seconds the units will pair. Repeat this process with the other parent unit.
Oct 10, 2009 | Bebesounds Ac401 2p Angelcare Deluxe...
My parent unit is not working. All it does is flash when it's supposed to show me the pendulum swinging, room temp etc. I have forgotten how to reset it. Help please
Oct 02, 2009 | Angelcare Deluxe Movement Sensor & Sound...
The base unit is turning on and operating, but the parent's unit all of a sudden just won't connect. I know the base unit is working because it is still detecting movement and the alarm goes off when...
Try the manuals: http://www.angelcare-monitor.com/Canada/en/help#tabs-2
The picture showing looks like the AC201 which has a hard switch for the channel selection, but you describe a menu screen which sounds like the AC401 or similar. If it is the AC201 - ensure both units are on the same channel. If it is the AC401 or other unit where there is an LCD, then try the following:
Sep 19, 2009 | Angelcare 2009 Movement Sensor Baby...
Angelcare Ac401 Single Baby Movement Sound Monitor Logo
46 people viewed this question
Top Angelcare Baby Gear Experts
Dorel UK
Dorel UK
Shehu Pro
Shehu Pro
Are you an Angelcare Baby Gear Expert? Answer questions, earn points and help others
