Question about Estate Washing Machines
The water is running into the tub but it is draining out. the tub will not fill up.
  • Estate Master
  • 5,323 Answers
Washer fills with water then drains:
The critical question is. Is the water is just running down the drain but the pump isn't running. If it is being pumped out, and you can hear the pump running just the same as when it's emptying prior to spin then it could be aborting the wash because it is, or it thinks it's overheating. ( due to defective water temperature switch)
If the pump is failing to shut off then there is something wrong with the electronics. If your washer is a mechanical timer controlled device then you may have a sticking switch (which may explain if switching cycles does something for you). But if you have an electronic timer then you may be experiencing a board failure, where a cycle is being commanded when it is not intended to by design.
If water isn't being pumped out, but just draining away all the time, the washer will keep detecting there isn't enough water inside and top up with more.
Modern washing machines should be sophisticated enough to realize something's wrong and abort with an error, but if not, it may continue washing or rinsing for a short while before losing enough water to trigger more coming in again. It can get stuck on this cycle indefinitely and it's called siphoning.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine.
Try raising the hose and see what happens.
Also the drain hose should have some type of air gap where it fits into the stand pipe. It should not have an air tight fit.
Again Either it's siphoning down the drain due to an issue with the plumbing, it's overfilling, or also if it ( THE WATER) overheats then in some machines the software will employ a fill and drain tactic to cool down the water. The important thing is to work out which of these different faults is causing the problem by careful observation.
Other switch's to check would be the water inlet valve and the water pressure switch with a multi meter for continuity or OHMS.
And in some modern washers that come with THERMISTORS:
One symptom of a washing machine that thinks it's overheating and thus fills and drains at same time ( possibly because of a faulty thermistor) is if it's filling with cold water and pumping out at the same time. This is covered in this articleWashing machine fills and drains at same timealthough the same symptom can be caused by other faults.
By the way my advice is free cuz God is good!
the water is running into the tub but it is draini - 24414014-5l44rnzs0d0ajyywclqoqvey-2-0.jpg
24414014-5l44rnzs0d0ajyywclqoqvey-2-2.jpg the water is running into the tub but it is draini - 24414014-5l44rnzs0d0ajyywclqoqvey-2-5.jpgt/uploads/images/24414014-5l44rnzs0d0ajyywclqoqvey-2-5.jpg" alt="24414014the water is running into the tub but it is draini - 24414014-5l44rnzs0d0ajyywclqoqvey-2-9.jpg"h_mi" />
Posted on Apr 25, 2016
  • 213 Answers
SOURCE: het3 elite
remove the bottom panel below tha door. youll see the drain pump in the center,fronr of washer. there is a black hose going from the pump to the bottom of the tub. remove that hose. at the end of the hose there is a plastic ball that is supposed to seal the end of the hose. more than likely there is lint build up on the ball or around where the ball seal. clean the ball and the hose and reinstall. you should be fine after that
Posted on Nov 27, 2007
  • 1294 Answers
SOURCE: Kenmore Model # 417.90812990 Stack washer & Dryer
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Height of exit hose (behind machine) should be approx 3 feet from ground level when you are re-fitting.
Rate me pl.....if helped.
Posted on Jan 03, 2008
  • 61 Answers
SOURCE: water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Posted on Jan 20, 2009
jsrock516
  • 5911 Answers
SOURCE: kenmore washer...the water just runs it never fills up.
I have seen this problem numerous times on service calls. It sounds like you have a siphoning problem. The key symptom is the wash tub that continously attempts to fill, but cannot achieve the proper water level. This is often caused by not having an air gap on your drain line, improper placement of the drain hose, or a standpipe that is too small in diameter. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
If you place the drain hose in the standpipe too far, or seal the top of the standpipe, this can cause a vacuum which will cause the symptoms you describe. A tell-tale sign will be a sucking noise as you pull the drain hose from the standpipe. Read through the link I provided. If this does not correct your problem please post back and let me know before you rate this solution. This way I can try to assist you further. I hope this corrects your problem.
Posted on Feb 25, 2009
  • 188 Answers
SOURCE: water will not stay filled in tub on rinse cycle
It sounds like a siphon issue.
Check that the drain hose does a high loop before it goes into the drain pipe. (ie. drain hose loops above the water level inside the tub). Make sure the drain hose is not pushed too far down into the drain pipe. Also if the drain hose is sealed to the drain pipe this will create an airlock and a siphon will occur, allow air to enter between drain hose and drain pipe connection.
This should help you but if there is still a problem let me know and I'll try to assist you further.
Posted on Mar 21, 2009
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
When the water is entering the tub it immediately goes out the outflow. The tub will not even fill up a little bit. What could be the problem? thanks
The drain hose outlet must be located higher that any expected water level in the tub. If too low, gravity drains the tub as it is filled. Extend the (a) drain pipe up to the proper level, even if you are using a floor drain to carry away the water. Hope this helps!
Jan 27, 2011 | GE WDSR2080D Top Load Washer
Washer will not hold water
You need to check drain hose, the drain hose needs to be above the tub. If it isn't the water will just drain out when you fill
Jan 12, 2010 | Washing Machines
My washer will not spin and can only fill tub on small loads cause water will run out
does the water keep running and it keeps draining the water? if so your drain hose needs to be higher than the highest water level in the tub or it will drain as it fills.
Aug 31, 2009 | Washing Machines
I have an Eljer jet bathtub with a smell to the water when we bat
What you smell is algae forming in the pipes. If you have small black particles in the tub when running the jets, it is algae. Fill the tub with hot water, add 2 teaspoons of cascade dish soap and 1/2 cup bleach. run the tub for 15 minutes and drain. fill tub with cold water, run for 15 minutes and drain, tub is now ready to use. repeat as necessary.
Aug 02, 2009 | Home
The water is going out the drain and cannot fill up the tub.
Check out the height of your drain. If the drain is too low, the water will drain right out of the tub. Check out the attached photo. Hope this helped and best wishes.
Aug 02, 2009 | Roper RAS8445KQ Top Load Washer
Keeps filling with water, but draining at the same time!
be sure your drain is nearly to the top of the washer if it is you may need to try a siphon break
Apr 24, 2009 | Washing Machines
Tub fills only 1/2 full but water keeps running as if the tub is not full. If the water level is set to 1/2 or less, tub fills 1/2 full and begins to cycle. The water is running into the tub but not...
Check the drain hose to make sure you have a high loop, ie. make sure the drain hose loops above the height of the washer lid before going to the drain pipe.
Also make sure the drain hose is not going too far down into the drain pipe.
You may be getting a siphon effect.
Feb 20, 2009 | Admiral AAV7000A
Water runs into tub but does not fill?
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Water runs, but tub does not fill on whirlpool washer
Well...if the water is running, the tub is not filling, and you don't have water all over the floor, your drain hose is installed too deep in the drain pipe, or just installed too low, so that the water is simply running out of the machine and out the drain hose.
Sep 14, 2008 | Washing Machines
Washing Machines Logo
15 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
