Question about Reptile
What does secondary source sonnet mean ? - Reptile
I want to know if ther are any first person pronouns in sonnet 18
Yes, there are. Shakespeare did you a first person pronoun in Sonnet 18.
Feb 20, 2014 | Computers & Internet
Tech sheet missing need help with codes
Your Error code is 94
81. - 95
. (0101xxxx) Phase 2 to 3 - Display/ Motor Control
Module. See Fault Code 106
106. (01101010) Phase 2 to 3 and 5 - Display to Motor
Control Module Communications Errors
(Phase 6 IW Also)
These faults are reported when the Display Module detects an error in
the communications between the Display Module and the Motor
Control Module.
Phase 2 to 3
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module. If the new
Motor Control Module corrects the fault, refit the
original Display Module.
Phase 5
Primary Source: Pump
Action: Measure resistance of pump. If resistance is
less than 33 ohms, replace pump.
Secondary Source: Display Module.
Tertiary Source: Motor Control Module.
Feb 21, 2013 | Fisher and Paykel Washing Machines
In terms of reptile habitat, what is the difference between a primary and secondary heat source?
A primary heat source maintains the overall temperature of the tank, while a secondary heat source provides "hot spots" within the tank used as basking areas.
Sep 04, 2012 | Aqueon Reptile
Can't found any windows driver for my tempo sata e2p Sonnet
You can download & install it by going to Windows Update.
Worked for me! Good luck!
Dec 06, 2010 | Sonnet TEMPO SATA E2P PCIX CARD...
Example of assonance poem?
I am assuming you mean sonnets...yes?
If so, please check out this website:
http://www.poetryfoundation.org/archive/tool.poem.glossary.1.html?id=25
Thanks for using Fixya.
Oct 14, 2010 | Computers & Internet
I really need help with drivers for Sonnet tempo 133 i have some useful stuff on this raid please somebody help me on official site i have find NOTHING for this card
One web-page says "supported by Mac OS 8.5 through OS 9.2.2, and OS X".
So, if you just connect it into any PCI slot on a Mac, the necessary device-drivers should be loaded.
May 29, 2010 | Sonnet Tempo Raid 133 (tat133r) ATA...
Sonnet Encore G4 upgrade (won't always boot)
first Check your ram & make it dust free.
Secondly show your motherboard to hardware engineer.
Check your antivirus updated so that there might be virus in machine
Mar 10, 2008 | Computers & Internet
Open Questions:
Reptile Logo
134 people viewed this question
Top Reptile Experts
windryder
Level 1 Expert
john h
Ned Halaweh
Ned Halaweh
Are you a Reptile Expert? Answer questions, earn points and help others
