Question about Boating
Wiring diagram for honda bf40a 40hp 4 stroke engine
I have some wiring in the power trim and tilt wire harness in the engine cont overheating and melting the insulation
natenash7986
  • 53 Answers
SOURCE: Wiring harness
you should never cut the wires on your factory harness... metra and other companys have harnesses that fit your car and would provide you with a correct wire color code you need to hook up a aftermarket stereo keep that in mind but i will post the wire diagram u are looking for
Posted on Aug 12, 2008
  • 157 Answers
SOURCE: relay switch for power tilt for Johnson outboard motor 40HP
Hello jalbin0308, I may can help but "NEED MORE INPUT" said ET. Model, year, HP, ect.
Posted on Oct 30, 2008
SOURCE: tilt and trim
Check the cable from the helm to the motor. Put a tone set or multimeter on it. If that cable is still fine then check that your new relays are functioning correctly.
Posted on Nov 05, 2008
  • 34 Answers
SOURCE: 7 wire harness going to blower motor resistor
There is an updated resistor/connector package. Very expensive from GM, try your local NAPA or other parts supplier for a replacement
Posted on Jul 09, 2009
  • 548 Answers
SOURCE: Engine and Wiring Harness Diagrams
join autozone.com for free and youll find lots of free diagrams and schematics for your car that will help in all your car endeavors
Posted on Sep 16, 2009
On my 50 Yamaha two stroke I have power to the trim motor from the green and blue wire but no movement. I have a clicking sound when I move up or down is the motor bud?
Sounds like faulty trim tilt relay.Connect blue green wires direct to battery ,if motor goes up or down then trim is ok but relay is faulty
Aug 10, 2015 | Boating
How do I replace the motor on a yamaha power tilt and trim 1995
loosen engine mounting bolts and steering tube , trim engine up by releasing the valve on the side and tie up so not tocome down ! remove pin on the ram then remove all bolts and wires and should come out !
Jul 20, 2014 | Arco Yamaha Outboard Power Tilt and Trim...
I cannot start the motor or raise the tilt and trim. Have power to the starter solenoid. have powere to the starter
check the control box , use multi metre and check the trim button and ignition key ! check main harness socket on the engine for corrosion or breaks in the wires !
Apr 11, 2014 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
Tilt trim go up wont go down 2003 johnson 140 hp 4 stroke
You may want to check service bulletin #2002-052. Some of these motors supply too much voltage to the trim switch at the throttle lever and that trim switch stops working. There is an add-on harness #586806 that fixes this. If you can still tilt and trim the motor at the trim switch that is built into the motor housing this is likely the problem.
Jan 30, 2012 | Boating
Kenwood kdc-248u. Installing into a 01 mitsubishi galant. Using a wiring harness adapter to plug into the factory harness. The wires on the radio pig tail have a label of P.CONT, ANT CONT, and MUTE. Not...
From the installation instructions: Ant Cont - Motor antenna control wire (Not used) P. Cont - Power control wire - To the power control terminal when using the optional power amplifier or to the antenna control terminal in the vehicle. Mute - Mute control wire - To the terminal that is grounded when either the telephone rings or during conversation (this would be to the telephone that is purchased separately.
May 21, 2011 | Car Audio & Video
Boat does not plane
you could try a lower pitched prop.2" would up the revs by 400 revs.,which would up the revs ,but give you more low down thrust,and/or tucking the motor under more[if you have electric trim/tilt].thats a big boat and fair bit of weight for a 40hp..my 40hp merc is on a 13ft saracen,and with two of us it takes a while to get gooing.so i bought a ProPulse prop,with adjustable pitch.been god to try different pitches
Jul 10, 2010 | Light Outboard Motor Boat Bass Fishing...
Intalling my kdc-138 in a honda
the brown wire is for a cell phone mute...to use with a hardwired car kit, and the blue/white is for a power antenna. orange ...is this from the car harness?
May 25, 2009 | Kenwood KDC-MP205 CD Player
WIREING A 1P52FMH ENGINE TO A HONDA 1973 CT-70 trail bike..
Hi, Harroknec the answer to this question is way above my pay grade and for this situation, I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1P52FMH ENGINE wiring diagram Google Search
1973 honda ct70 wiring diagram Google Search
Honda Motorcycle Wiring Diagrams
Honda ST50 Shop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda ST50 Owner Manual
May 01, 2017 | 1973 Honda CB 100
1970-79--80horse mercury
here are links to wire diagrams for an 80
http://www.maxrules.com/oldmercs/Wiring/1966ona/31.jpg
or go here to pick other modles for your new control side
http://www.maxrules.com/MERCwireindex.html
good luck
Mar 23, 2009 | Boating
Wiring diagram
If theres wires coming out of the motor it is more than likely an electric motor , If it is a gasoline engine it is a 4 stroke engine
Dec 05, 2008 | Air Tools & Compressors
Boating Logo
56 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
