Question about Sony EVO-250 Hi8 VCR
How to connect eo-250 to computer? - Sony EVO-250 Hi8 VCR
Camera keeps saying "busy" when I try to upload pictures to my computer using EOS Utility
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use the EOS Utility or any other photo management program, such as Picasa ( http://picasa.google.com ).
Jul 10, 2014 | Canon EOS Rebel XSi Digital Camera
I need to conect my camera eos 3000 to the computer what i need?
The EOS 3000 is a film camera and was not designed to connect to a computer.
Oct 10, 2012 | Canon EOS 3000 Kit 35mm SLR Camera
CANON EOS Rebel XSI is not being seen by EOS Utility. I can't update firmware, I can't download pictures, nothing. It doesn't see that it is hooked up. I have tried updating the EOS Utility...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as iPhoto, Windows Photo Gallery, or ZoomBrowser.
Aug 14, 2011 | Canon EOS Rebel XSi Digital Camera
Will not connect to computer to download pictures
Canon EOS Rebel G is a film camera it doesn't connect to the computer
Dec 27, 2010 | Canon EOS Rebel G 35mm SLR Camera
I cannnot download my photos from my Canon EOS Rebel IT camera onto my computer.
Try to disconnect the camera from the computer, then connect it to a different USB port if your computer is a desktop connect the camera to the back USB port then restart the computer and check it again.
Jun 02, 2010 | Canon Rebel XT / EOS 350D Digital Camera
My eos says busy when trying to download pics to my pc? and deleted pics off the memory card.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Canon ZoomBrowser or any other photo cataloging program.
Apr 28, 2010 | Canon Rebel XT / EOS 350D Digital Camera
I get an Err CR inmy Canon EOS Rebet XT-Bad card?
  1. Test the CF card on your computer or another camera. If it works fine then it may not be the card. Make sure the card is not UDMA, 4GB or more in memory size since those new big cards are not compatible with the older cameras.
  2. Look inside the CF port. Make sure that none of the contacts that connect the camera and CF card are bend of smashed flat. If so then the camera will have to be send off for repair. This is a rather expensive repair, $250 is not uncommon.
  3. I it is neither of these then take the camera to a local camera shop and ask them to look at it. It may need to be sent off, but testing another brand card, or resetting the camera or checking for physical defects couldn't hurt at this point.
Nov 27, 2009 | Canon Rebel XT / EOS 350D Digital Camera
EOS software not connecting to camera
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use the EOS utility or any other photo cataloging program.
Feb 22, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
EOS Utility does not recoganize Canon Rebel Xti
I believe there are 2 modes of usb transfer that you can pick in the camera. They are set somewhere in the menu in the options. If you go through the menus thoroughly you'll find it. One option is for connecting the camera directly to a printer and the other is for computer transfer (there might also be an Auto setting but I don't remember for sure). Make sure that setting is set for computer transfer. If that doesn't fix your problem, re-install or update EOS Utility / ZoomBrowser.
Jul 30, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
No connection to computer via usb
You have your camera turned on, right?  I initially had my camera off and I had the same problem, but EOS utility repsonded when I turned it on.
Dec 26, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Sony EVO-250 Hi8 VCR Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
