Question about Maytag MAH6700AWW Neptune Front-Load Washer
Problem with draining maytag neptune mod.mah55flbww
  • 8 Answers
SOURCE: maytag neptune mah3000aww
re original issue, see if R11 is burned. if so, need to change R11 resistor and associated triac, and probably wax motor so it won't do it again. temporary fix just cut out R11, door won't lock. if your model won't spin that way, depress actuator for microswitch from door wax motor. instructions on web.
Posted on Oct 23, 2008
TheRepairGur
  • 27 Answers
SOURCE: Neptune MAH55FLBWW front load washer LR code
LR = Locked (main motor) Rotor and very likely a new motor will be needed but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
TheRepairGuru --- www.RepairClinic.com
http://www.repairclinic.com/Maytag-Washing-Machine-Parts
Posted on Jan 27, 2009
  • 1294 Answers
SOURCE: i have a maytag neptune washer the water will not drain out of it
First drain as much water from the drum as possible and unplug from the outlet. Then there are 2 screws left and right under the front lower panel at floor level. Undo those two screws. Pry the front panel DOWN from the door panel. Once the lower panel is removed you will see the pump and pump filter on your right. The pump filter is to the left. It has a large turnscrew. Be ready with a pan or something to catch the water from the open filter! Screw this counterclockwise until it comes loose. You will now be able to remove the filter and all the debris. After cleaning, re-screw the turnscrew. Before you put back the front panel test that it is clear by doing a wash. If it still doesnt drain you must remove debris from the pump itself. The pump is between the pump filter and the pump motor on the right. Undo the white clips from the motor and the retaing clips attiching the filter to the metal washer body. Then turn the motor clockwise to separate it from the filter. Refit carefully after job is done. And fit outlet tube a correct height, not too deep. <courtesy tzotsi>
Posted on Mar 10, 2009
milten1
  • 1304 Answers
SOURCE: Maytag Neptune won't drain
your pump is clogged with matt mud...
remove the back panel
the pump will be right on the left
two hose clazmps
you will loose a gal water
1/4 turn on the pump it will now come out
disconnect the two wires...
clean the pump out and try to clean out sump hose and drain hose
sump from tub to pump
darin pump to drain
reassemble your done
Posted on Oct 04, 2009
digritz
  • 530 Answers
SOURCE: how do i fix nd code for mde5500ayw maytag neptune
There are two possible causes to the "nd" code. The first is with the pump itself. Either is is blocked or it is simply worn out and needs replacing. The second is a malfunction with the control board. Unless you find a blockage to the pump there is no way to know which one is the cause of the "nd" code without some testing or replace these items.
If you are unafraid of facing your washer with tools in hand then you should be able to test the pump. As for the board, all you can do is check it for damage most likely caused from a component melt down. In which case it's going to need replacement.
But check for blockages first because that will cause the "nd" code.
I hope this helps and good luck.
Posted on Oct 06, 2009
Maytag neptune front load model MAH55FLBWW
hmmm..that's odd...are all the wires back in correct locations? or does this have a connector?
May 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
How do you get to the wate level pressure swith on a maytag neptune front load washer model #mah55flbww
First make sure the washer is unpluged. Remove the two screws on the back side of the top cover. Then you can slide the top cover off by pushing backwards and lift. Now you will expose the controls. One of the controls on the right side of the washer that has a clear 1/4 tube hooked up to it is your pressure switch.
Jun 07, 2014 | Maytag MAH6700AWW Neptune Front-Load...
MAYTAG NEPTUNE WON'T SPIN OR DRAIN
If it can't drain, it shouldn't spin. Pump blocked? Broken pump? Level sensor broken?
Sep 05, 2012 | Maytag MAH6700AWW Neptune Front-Load...
I have Neptune clothes washer model number MAH55FLBWW. Do you know what its capacity is? 3.8? 4.0? What????
First of all, do you know there is a class action suit against maytag on this machine?
See this pdf file.
http://www.maytagfrontloadsettlement.com/pdfs/notice.pdf
From what I have read, you have a 4.0 cu. ft. machine.
Nov 25, 2010 | Maytag Neptune MAH5500B Front Load Washer
The belt keeps coming off my maytag washer mo. mah55flbww. tub bearing seem good motor seems ok
That is a tough one, especially since you indicate that the bearings are okay. The belt not wanting to stay on a Maytag Neptune washer usually does not bode well. It is usually an indication that the drum bearings are shot. Look for brown splatter on the back of the drum and the inside bottom of the washer. The presence of any brown discoloration is a pretty good indicator that the bearings are going. Anyway, hope this helped, sorry for your problem, and best wishes.
Jul 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
MATAG NEPTUNE WAHER LEAKS FROM FRONT DOOR
hi there,
base on your problem, and other like what you say they changed the seal gasket of the door to avoid the water from spilling or leaking on the front door.
Hope this initial info helps.
Jun 04, 2009 | Maytag Neptune MAH7500A Front Load Washer
We have a Maytag Neptune washer Model # MAH4000 AWW it is leaking from the front at the bottom of door. Water pours out like a water fall when it wants to rinse. Any ideas?
TO ELLIESHIRK, I SEE YOU POSTED YOUR PROBLEM ON MAR. 19, 2009. I HAVE A MATAG NEPTUNE FRONT LOADER WASH MACHINE MODEL #MAH55FLBWW. I AM HAVING THE SAME PROBLEM WITH MY MACHINE LEAKING WATER OUT THE FRONT DOOR. MY WASH MACHINE SEAL LOOKS FINE. IF YOU HAVE FOUND A SOLUTION TO YOUR WASH MACHINE LEAK PROBLEM, PLEASE LET ME KNOW, OK. YOU MAY EMAIL ME AT: CJA931@FRONTIERNET.NET , MY WASH MACINE IS NOT VERY OLD EITHER 4-5 YEARS IM GUESSING, IT WAS LEFT WITH THE HOUSE I PURCHASED. THANK-YOU FOR YOUR HELP AND TIME. CONNIE
Mar 18, 2009 | Maytag Neptune MAH7500A Front Load Washer
Jan 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
59 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
