Question about Gestetner 2712 Digital Imaging System Copier
Gestetner 2712 as a scanner
Will the Gestetner 2712 scan documents to a network server?
  • 10,515 Answers
Yes they can.
Hope i helped you.
Thanks for using "Fixya".
Posted on Jun 23, 2009
X544dn scanning and Windows Server 203
Scanning documents at the printer
1 Load the document into the scanner.
Note: Documents may be loaded into the scanner in multiple ways. For information on the different methods of loading documents into the scanner, see the User's Guide that came with the printer.
2 Touch Scan to Network. If prompted, enter the user name and password used to access the printer. Contact your system support person for login information.
3 Select the destination where you want to receive the scanned document. If prompted, enter the user name and password required to access the destination. Contact your system support person for login information.
4 Some additional job options may be available depending on how the application has been configured. Follow the instructions on the screen to update the options. Contact your system support person for more information on each option.
5 Touch Scan It. Depending on how the application has been configured, you may have the option to preview and make adjustments to scanned pages.
6 To scan additional documents, load the next document into the scanner and select one of the following from the confirmation screen:
• Touch Yes, to same destination to scan the document to the previous destination.
• Touch Yes, to a different destination to scan the document to a different destination.
• Touch No to finish the operation and return to the printer Home screen.
Jul 23, 2012 | Lexmark X544dn All-In-One Laser Printer
My gestetner 2712 has ran out of toner. i have replaced the toner, the machine takes a while to load and then comes back with load toner again. Why would it not be registering a full toner bottle?
GESTETNER 2712 PROBLEM USUSALLY SIMILAR TO RICOH 2022/1022/27 PROBLEM IN WHICH INLET IN PCU AT LOAD TONER OUPUT. wHAT YOU CAN DO ,TEK OUT THE PCU IN CHECK IF THE PCU TONER INLET IS BLOCK EITHER BY SEAL OR DUE TO INLET CLOSER MALFUNCTION CAN BE REPAIRED IF YOU HAS EXPERIENCE OPENIG UP THE PCU
Apr 06, 2010 | Gestetner 2712 Digital Imaging System...
Gestetner 2712 copier. Won't power on
IT IS SIMILAR WITH RICOH 1012/1022/1027/270.WHAT CAN BE THE PROBLEM IS EITHER YOUR POWER BOARD HAD BURN IC THAT MEAN YOU HAVE TO REPLACE IT OR JUST CHECK THE POWER SOCKET ,MAY BE THE CODED WIRE NOT IN CONTACT WHILE YOU REPLACING THE FUSE,JUST BE CAREFUL AS LIVE WIRE CAN BURN YOUR COPIER.
Mar 17, 2010 | Gestetner 2712 Digital Imaging System...
How do I send an immage to my server - location S:\scans
the address can be found if you go to the server an right click the folder it should have full address and this has to be set up then on copier by going into the user toolsd and then administrator you are looking for the address boook if you set up new user an put the adddress as a folder here it should save it you can also do this on the web monitor by typing in the ip address ie http/..ip of machine..192.168. etc
May 29, 2009 | Gestetner Copier
Ricoh MP4000B
hi
a rijas working in dubai
my Gestetner MP 4000B nw its showing waste toner bottil is full please advice me how to solve dis problem
Feb 18, 2009 | Office Equipment & Supplies
Gestetner DSC224 Scanning and Fax Issues
scanrouter? disable delivery server from scanner menu
Jan 22, 2009 | Gestetner DSc224 Copier
GESTETNER DSM627 COPIER, SCANNER, FAX
The basic scanning method is to use the Twain driver, found in the printer driver disc.
Install it on your computer.
Put original on the exposure glass.
Open Word document, click insert, select from scanner or camera
and select your device scanner and click on insert.
Then you can save it and attach it to an email.
Hope I was helpful, please rate me, thanks.
Oct 09, 2008 | Gestetner - DSm627 Digital Imaging System...
How to Network the scan function of a Gestetner DSm635
The only real problem would be finding the software driver for your machine.When your driver for your scan function is loaded it will assign an IP address for the scanner.without the software,your out of luck.I'll look online tonight for it and let you know if I find it.
Mar 10, 2008 | Gestetner DSm635 Copier
How to scan a doc on Gestetner Copier
You can install the Twain scanning driver which is provided on the Printer driver CD. Insert this CD and select to install the Twain driver only.
After installation od this driver, please open Word document and click on Insert, Picture and select from Scanner or Camera. Check and choose your twain scanner driver and click on insert.
Beforehand you must put the original on the exposure glass.
Try this or you can use scan to email but you need more setup details.
Hope you good luck.
Dec 27, 2007 | Gestetner DSm618 All-In-One Printer
My Canon Imagerunner 2200 won't scan.
Sorry that was actually me...after i posted...it asked me to register...so i did.
Okay, you need to download Canon Network scangear from the Canon website. then take your document...put it on the top feeder...turn you scanner online...open up microsoft word 2003..insert, picture....from scanner or camera select network scangear....custom insert....then scan. The machine needs to be hooked up to a network...but note...a simple cross over cable or usb between pc and the photocopier will not work.
Oct 22, 2007 | Canon (6981A002AA) for imagerunner 2200,...
225 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
