Question about Coach Heritage Pink White Stripe Signature Large Multi Tote Diaper Bag Purse
Coach purse is it real a087312204?
Is it really real it has mums on it it is pink with brown c's
When to change gear oil in maruti zen 2002 model
when the lube is 30k-50k miles oil or when it looks bad. change it.
ask a mech, he knows. this. let him.
auto or stick trans?
we dont have Maruti in USA< this is a usa forum
but on sticks shifts remove side plug first
then drain plug out. then drain, the back in plug
and fill from side,
if A/T , get a full flush and filter at a real shop, its NON Trivial
and when , same deal, when the fluid progressed from pink to red
and wants to go brown, change it before brown happens.
ATF fluid.
Jun 18, 2014 | Maruti Cars & Trucks
Exclamation next to Drive and RPM's going up
the operators guide tells you every warning icon, lost that?
look here, see all those, Exclamation points, one is yours.
post a photo of yours, or get oper guide.
or try getting the car scanned, really. get it scanned to see what
those funny icons really mean.
RPM's no my 6sp m/t go up in direct proportion to engine RPM
(real gears) but on a A/T this is partly true (the slush factor)
if the slip is excessive, its is called tranny slip or of far gone FLARE.
id say dont driver it or risk burning up A/T clutch packs ? or?
1: check all fuses.
2: check fluid levels and color quality (ATF is pink not brown)
3: scan it. jack in and see what's up doc.
Jan 19, 2014 | 2008 Jeep Patriot
1973 chevy truck wiring diagram
The odometer uses the same cable the speedometer uses. It should be mechanical.
Now the HEI coil has two pinks and a brown. One pink goes to the pickup in the bottom of the distributor and the other pink goes to the key switch. The brown goes to the pickup or the ignition module in the distributor.
Jul 14, 2013 | Cars & Trucks
1990 Chevy GMC Suburban alternator wiring
Well, according to my diagrams for 88-94 models, the alternator only uses the red and brown. There are pink-black wires that power some of the sensors and solenoids but should go to a fuse marked ECM in the fuse box.
Have you tried hooking up the harness without using the pink-black wire ?
Aug 28, 2012 | 1990 GMC Suburban
Instruction for holiday time majestic pine christmas tree setup.
I think u got to do it bye colors if it has colers then huk it up on the cloer on each space or try to do it this way go to the biggest med big small big and then small hope it works try it or just get a really tree lol good luck
Dec 12, 2010 | Computers & Internet
Matching wires for a car radio in a nissan maxima
Constant 12V+ Green/Red Switched 12V+ Pink/Brown Ground n/a Illumination Red/White Dimmer n/a Antenna Right Rear Front Speakers 5 1/4" Doors Left Front (+) Blue/White Left Front (-) Blue/Yellow Right Front (+) Brown Right Front (-) Brown/White Rear Speakers 5 1/4" Rear Deck Left Rear (+) Red Left Rear (-) Green Right Rear (+) Blue Right Rear (-) Pink
Aug 26, 2010 | 1986 Nissan Maxima
A digram for the factory wireing for the radio
This color code works for 87-93 mustang factory radio; it might work on yours as well. I'm not sure if it has the same fuses though.
Radio Connector:
Light Green / Yellow - Hot at all times (Fuse 8)
Yellow / Black - Hot in ACC or Run (Fuse 11)
Light Brown / Red - Goes to instrument panel dimming rheostat (Fuse 4)
Red - Ground
White / Purple - Hot in ACC or Run (Fuse 11)
Speaker Connector:
White / Light Green - (+) Right Instrument Panel & Door Speaker
Dark Green / Orange - (-) Right Instrument Panel & Door Speaker
Brown / Pink - (+) Right Rear Speaker
Pink / Light Brown - (-) Right Rear Speaker
Pink / Light Green - (+) Left Rear Speaker
Tan / Yellow - (-) Left Rear Speaker
Light Brown / White - (+) Left Instrument Panel & Door Speaker
Orange / Light Green - (-) Left Instrument Panel & Door Speaker
Hope this helps.
Aug 15, 2009 | 1991 Ford Econoline
Need color code diagram for sterio
I'm not sure what year you have but this color code works for 87-93 mustangs.
Radio Connector:
Red - Ground
Speaker Connector:
Hope this helps.
Jun 19, 2009 | Ford Escort Cars & Trucks
Wiring for a 99 jeep cherokee
On your vehicle there should be two male plugs from the back of the radio, one black and one gray. The simplest thing to do is get an after market harness but if you really need the wiring,here you go:
12V+ Pink/Yellow
Acc Red/White
Ground Black
Illumination (not really needed) Orange/Brown
Dimmer (also not needed) Black/Light Blue
Speakers:
FL + Dark Green
FL - Brown/Red
FR + Violet
FR - Dark Blue/Red
RL + Brown/Yellow
RL - Brown/Light Blue
RR + Darl Blue/White
RR - Dark Blue/Orange
Mar 15, 2008 | Kenwood KDC-MP235 CD Player
Coach Heritage Pink White Stripe Signature Large Multi Tote Diaper Bag Purse Logo
89 people viewed this question
Top Coach Baby Care Experts
masud
masud
Tom Chichester
Are you a Coach Baby Care Expert? Answer questions, earn points and help others
