Question about Kenmore Refrigerators
My icemaker will not fill with water. It is not jammed and the water is available from the door spout. Ive replaced the filter and still, nothing.
  • 351 Answers
Free kenmore tech support whirlpoolpartssurplus.com, but either you have a water valve problem or you have a ice maker problem , jump 110 volts to the water valve, do that by taking the water line to the ice maker and trace it all the way down unplug the fridge take the ice maker wires off the water valve and jump it if you get water it is either the ice maker bad or you have a block. if you dont get no water then change the water valve.
Posted on Jun 23, 2009
I have major ice build up in the freezer near the icemaker area of my GE side by side. Replaced the icemaker, but the problem came right back. HELP!
Icemaker inlet water valve may need replacing. If the valve
is not closing all the way it will leak water into ice tray.
Sometimes well water without a conditioner can cause
cause this problem. LynnMBent
Oct 27, 2015 | GE Refrigerators
Water leaking behind freezer wall
I would make sure the fill tube in the freezer is in the proper place on the icemaker. there is usually a slot it will rest in or on. If it is it the right place. The water valve may not be closing in time and allowing excess water to fill into the icemaker causing it to over flow. On some icemakers there is a adjustment screw on the icemaker to increase or decrease the amount of water that fills. If not I would check the valve and replace it if nessacary.
Jul 10, 2007 | Frigidaire FRS23KR4AQ Side by Side...
My Icemaker is filling up with frost around the ice dispenser spout. Have to pull the bin every 30 days dump the ice and clean it with hot water. The icemaker was replaced 2 months ago. What causes the...
You have a duct door problem. The most common is the seal on the door goes bad or the pivot on the dispener can break off. Both allow warm air inside thus your moisture. I hope this helps.
Aug 24, 2011 | KitchenAid KSCS25FKSS Side by Side...
The automatic ice maker does not make anymore. How can I fix this?
Check the fill spout for ice clog. If it clogged with ice then you will need a new water valve. A quick test is to remove icemaker cover and short L and V together to turn water on and check flow. If it's good then you will need a new icemaker.
Nov 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water is not going into icemaker, I've replaced
I have a maytag side by side with water in the door, the cold water works but the icemaker doesn't. No water flow into the icemaker, it doesn't appear to be iced up. Can not tell if the selenoid works.
Jul 14, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water dispenser not working replaced filter ice maker works fine
Try using a hair dryer around the spout it may be frozen. I did that for mine and it worked.The pump is working , it is just froze in the spout. Make sure you have water in the line at the connection going in to the door.
Jun 26, 2009 | Hotpoint HSS25GFP Side by Side...
Ice Maker abruptly quit
is the ice bucket in the door ? if not and there is water or ice inthe maker and your frezer temps are right[close to 0]the its the ice maker.some maker have a moduel you can replace but the surest way is to replace the whole maker.if bucket in the door theirs other posibilties.God bless,tom
Jan 02, 2009 | Maytag MSD2754G Side by Side Refrigerator
Icemaker won't fill with water
If you would like a repair manual for your refrigerator, you can get one here. These are helpful to have in case you have other issues with the fridge.
Thanks
Sep 29, 2008 | Samsung RS2630WW Side by Side Refrigerator
Refrigerators Logo
121 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
