Question about Razor MX500 Dirt Rocket
I have a Lifefitness 9500R exercise bike...where is the 6 volt batt. located?
Looking for location of battery in LifeFitness C9i exercise bike. (C7i battery was in control panel, earlier models may have been in the base.) Thanks!
How do replace the battery in Lifecycle C9i exercise
The web site above states the following:
The 9 volt battery for the display on the bars of the bicycle goes in underneath the display (on the bottom of it).You can also see the 7th page (pages are not numbered, simply scroll to the 2nd to last page) of the manual at the link below to see where the battery installs:
https://www.lifefitness.es/static-assets/document/manuals/C9iAssemblyInstructions_12-07-05.pdf
Feb 16, 2018 | Exercise & Fitness
Battery 9500hr
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
If the battery continues to fail, I would check the alternator brushes and see if they need to be replaced. Chances are they are worn and the battery is not being recharged sufficiently.
Battery 6 Volt 2 5 Amp Hr LifeFitness 0017 00003 0685 SPORTSMITH net
Feb 23, 2014 | Life Fitness 9500RHR Dove Tail Recumbent...
Chain keeps comming off
It sounds like you are dealing with a stretched chain. If the chain will not tension any further, you may be looking at the need to purchase a new chain. Use your model and serial number at the following link to order a new chain.
Bike Parts for LifeFitness LifeCycle 9500 Upright Belts Pedals Seats...
Jan 29, 2014 | Life Fitness Lifecycle 9500 Upright...
Screen flashes when trying to operate
If you have not already done so, start with checking the battery voltage. It should be at least 6 volts DC. Check the link attached for instructions on how to properly check the voltage on a battery. Video about How to Test Battery
Dec 07, 2013 | Stairmaster 3800RC Recumbent Exercise Bike
Vital fitness RB 360 exercise bike requires 6volt DC
Yes, Vital Fitness RB 360 exercise bike requires 6 volts DC because it is comfortable for exercise and also are safer because they are lower to the ground and result in less impact on the knees and lower back.
Sep 11, 2013 | Exercise & Fitness
Electrical
Replace the battery.
Aug 11, 2012 | 2003 Suzuki VS 1400 Intruder
Where is battery located for LifeFitness' Lifecycle 9500HR
The Lifefitness Lifesyscle 9500HR battery location is at in the lower portion of the recumbent bike. This is a 1/2 to one hour task for most do it yourself'er.
In order to gain access to the battery compartment,you has to remove the pedals.
The center cover has to be remove.
Additional reference: Lifecycle Battery 0819-0012 Model Description Terminal Volts AH L W H Lbs Price 0819-0012 Fits Lifecycle Stairmaster series 4200, 4400 - Lifecycle Lifefitness CT8500, CT9100, 9500HR, 95Ci - Star Trac 5300/6300, 5400/6400, StarTrac 6100 Pro, 6200 Elite, ET4600 (0819-0012 replaces the 0819-1006) F2 6 2.5 4.48 1.81 2.75 2 $19.80
Feb 02, 2011 | Life Fitness Exercise & Fitness
Stairmaster 3400 Exercise bike - how do I turn it on?
It should come on once you begin to pedal. If it is not coming on, then start by checking the voltage of your battery. Chances are it is low or even completely discharged.
Battery 6 Volt Stairmaster SM14123 SPORTSMITH net
Dec 03, 2010 | Stairmaster 3400CE Upright Exercise Bike
I have lifefitness life cyle that the display does not work also...already replaced 9 volt battery and checked all push on connections. Help!
Inside the side panels there is a 6v @ 2.5 AH batt check this with a multi meter any thing less than 6v replace it go to gymparts. com they will have this batt.
Apr 09, 2010 | Life Fitness 9500RHRT Recumbent Bike
Lifefitness 9500hr recumbant exercise bike dead
This unit takes a special 6 volt battery. The battery is in one of two places. First place to look is under the unit. If you lay the bike over on its side there is an opening in the covers. If the battery is not there then you will need to take one of the side covers off. When you get the side off you cannot miss it. The battery is black with three cylinders. You can get the battery from sportsmith.net.
Mar 15, 2010 | Exercise & Fitness
Razor MX500 Dirt Rocket Logo
Top Razor Cycling Experts
Lawrence Oravetz
Wayne Fraser
ray gallant
Are you a Razor Cycling Expert? Answer questions, earn points and help others
