Question about Fein Vacuums
How may I find a Fein Service location?
My Fein Turbo 1 9-20-24 needs servicing. Wher may I take it? I live in the greater Boston area.
Cant find reset button
Hey Troy, the PowerForce Turbo Helix doesn't have a reset button. You may want to have a Qualified Technician at at BISSELL Authorized Service Center inspect your vacuum.
Here's a quick link to assist you in locating one in your area.
http://www.bissell.com/service-centers/?cid=ccsocial
Jan 28, 2013 | Bissell PowerForce Turbo Helix Bagless...
Need switch for Fein mdl 9355.13 vac. Where to purchase?
Type www.fein.com in the address line in browser. It should take you to Fein in your country. On the left hand side of screen you will see a list of links click on service then Authorized workshops that will give you a list of places to fine spare parts and repairers.
Mar 26, 2012 | Fein 9-55-13 Turbo II Bagged Canister...
FEIN 9.55.13 WILL NOT TURN ON. SWITCH? BRUSHES?
replacement parts for that model can be found at amazon, click here and take a look: Amazon com fein vacuum parts . Have a nice day
Sep 12, 2011 | Fein 9-55-13 Turbo II Bagged Canister...
I need the orange top cover for my 9.55.13 because mine is cracked. Where can I buy one?
You will probably be able to find it at: http://www.ereplacementparts.com/fein-parts-c-15741.html?osCsid=2cldhjbhfcq03503il7el658t4
Paul
Oct 12, 2010 | Fein 9-55-13 Turbo II Bagged Canister...
Are fein vacumes anti static?
all vacuums create static from friction even plastic cased ones
May 18, 2010 | Fein 9-55-13 Turbo II Bagged Canister...
I have a fein turbo III and I think it got some dust in the motor and now it wounds like it is going to blow up when I turn it on. Is there anything that I can do?
Best bet is try to access the motor and disassemble if possible. There will be fine fine dust in the fans causing eventual wear and bushings or bearings as well as the carbon brushes. To clean it properly all must be dismantled. Any fine dust on the armature should be cleaned with forced air or suction and a soft brush
Nov 05, 2009 | Fein 9-77-25 Turbo III Bagged Canister...
Cracked lid/top of fein vac model 9-55-13
Contact Rudi at E & H Repair in Chicago. They are an Authorized Warranty Repair Center for Fein. The phone no. is 312-829-6770. Email is rudi@kooltools.com. Good luck
Jan 20, 2009 | Fein 9-55-13 Turbo II Bagged Canister...
Vacuums Logo
22 people viewed this question
Top Fein Vacuums Experts
JoeVacs
Are you a Fein Vacuum Expert? Answer questions, earn points and help others
