Question about 7754P RESPONDER LC3 SST REMOTE
My python 7754p is locked up - 7754P RESPONDER LC3 SST REMOTE
Hi I would like to make my python 7754p security alarm more sensitive to touch. How do I do this??
there is a vibration detector on this unit... you need to adjust the dial clockwise to make it more sensitive to vibration... but someone merely touching the car will most likely not set it off...
also the placement of the sensor is crucial in detecting minor bumps to the car... best place is directly on the steering column or on a weight bearing panel/rod...
Jul 19, 2016 | Python Vehicle Parts & Accessories
Is 448V remote compatible with Python Car Alarm?
if its lit solid that usually means a problem with the system... so the alarm portion is most likely not active... or it might simply be in valet mode... without knowing the model of your car that's the best I can offer...
May 05, 2016 | Python Vehicle Parts & Accessories
Python alarm (460 HP) will not lock doors
The lock button in your remote may be faulty.
Nov 13, 2013 | 460HP Security System
Python car starter
Can you remove the python box without removing the wiring? That'd be a pretty definitive way of determining if the relays inside the python box are bad. On another note, this sounds like an ignition switch issue, the python box could just be coincidental.
Sorry, not much help... but see if you can eliminate the python box. That's the diagnostic process with electrical is to remove possible causes and record the results. Next, you might consider unplugging the wire harness from the ignition switch... or remove the wire harness that leads up the steering column.
Oct 16, 2013 | Vehicle Parts & Accessories
Python 476p
May depend how it was programmed. My Python 476P was setup with Lock and Unlock pressed to get it to remote start. Then, get in the vehicle, put the key in the "on" position and press lock / unlock to get it to end the remote start cycle. Then Drive off ...
I got a second remote, followed some directions via YouTube to program. Key in the on position, then hit the valet button once, then press and hold. One chirp, hit lock on remote. Let go of valet button . Press, then press and hold, two chirps. Hit unlock. Continue for 3 (aux) and 4 (panic). End result was Lock would also unlock. Unlock did nothing. And Aux started the remote start sequence.
Having bought a vehicle used, then no manual made this a bit difficult. I will continue to test alternate programming to try to match the original remote so accidentally firing up the rig doesn't happen. My suspicion is I have to maybe do Lock, Aux, Lock/Unlock, panic instead. Good luck.
Oct 30, 2012 | Python Vehicle Parts & Accessories
How to reprogram Python 4Button Remote 474P ?
I had the exact same thing happen with my 4-button 474p remote. WITHOUT REMOTE START the correct sequence is:
1. Enter car - Leave door open.
2. Turn key to "on" position.
3. Within 5 (five) seconds press the Valet button 7 times then hold down. (Programs to channel 7)
4. Watch alarm light - It should now flash 7 times.
5. While still holding down the Valet button - Press the "lock" button on the remote and release. Should get a "chirp"
6. Now release and repress the Valet button once, holding down. You'll get the "chirp". Release Valet button.
7. Turn key "off". Exit vehicle and test remote. All 4 buttons should now work.
Mar 09, 2012 | 4Button Remote 474P
A few times each week when i use the remote start function on my Python 991, the truck will start for a second or two then the horn starts blowing, lights flash then the truck shuts off and I lose all...
It sounds like the factory alarm is setting up. To make sure the factory alarm does not come on you should make sure all doors are closed before you actually hit the remote to lock the doors. Do not lock the doors with the switch on the door. Make sure you use the Python remote only and all doors closed before you press the lock button.
Jan 23, 2011 | 5702P Python 991 ResponderLE 2Way Security...
Python 990 isnt locking or unlocking my doors .
Its going to be either the wires going to the locks or the programming in the alarm. The only way to tell is to get the wiring tested. A plug could have just pulled out also. Do many variances for one straight answer.
Jun 04, 2009 | DEI Python 990 2-Way Security...
I have a python sst car alarm
usually a combination of 2 buttons so the car doesnt start accidentally.
Depending on the number of output channels - the installer could have installed on any of the channels and that would dictate which buttons to press.
if it is not set on the AUX (output 2) button, then try...
  1. Lock + unlock at the same time - output 3
  2. * + AUX at the same time - output 4
  3. Lock + Aux at the same time - output 5
  4. Lock + * at the same time - output 6
You have not given the model # of the unit - so these are viper's STANDARD remote controm configurations.
CLICK HERE to enter your correct model # and Download your instruction manual.
Hope this helps.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 01, 2009 | Python Vehicle Parts & Accessories
7754P RESPONDER LC3 SST REMOTE Logo
66 people viewed this question
Top Python Vehicle Parts & Accessories Experts
rjivaro
Kevin Daniels
AzVip
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
