Question about Us Leisure Garden
Where can i purchase replacement hinges for the stonghold shed
Where can I find a replacement roof panel for a Leisure Stronghold 10x8 shed?
Probably not a very good answer since the Owner / Installation Manual for this shed specifically states "do not contact the store....". Instead, follow instructions in the manual and contact US Leisure at 1-877-638-7056. Ext 6. Get ready for voice mail and punch the buttons HE...LL. These people apparently cannot hire folks to run their phones or customer service department. Sat on hold and running buttons in their system for 35 minutes the other day before giving up.
Aug 12, 2014 | Us Leisure Storage Building. Stronghold 10...
How do you make shelves for Rubbermaid Large Storage Shed HIP-046H?
Hi, I would use 3/4" plywood and build a Horseshoe type structure at the desired height then place it on a lower shelf, place another shelf on top of it.
good luck
Jul 13, 2014 | Rubbermaid 3746 Taupe/Green Large Vertical...
Door beside the driver seat is not closing properly, thats why whene its raining, the water is going inside the car.
you did not give the age of your car. if it is more than 8 years old i would suspect the hinges are old, loose, causing the door to sag and not latch properly and/or old door gaskets get hard and lose their water shedding seal. if it is newer then your door latch or the post it hangs onto is maladjusted or broken. take it to a dealer and get a diagnosis and price, then fix it yourself. do not take on replacing the hinges yourself, if you do not have a jack for it you will never get it back on right.
Jul 06, 2011 | Honda Civic Cars & Trucks
Where is the Suncast Corporation Sierra 6ft. x 8ft. Resin Storage Shed Manual? I purchased the shed. No manuels or instructions in the box
Here you are. I hope your model is listed. I downloaded a couple of them. I don't know if you have the 6 X 8 or the 8 X 6. Both (with model numbers) are listed here. Adobe Reader is required.
http://www.storageshedsoutlet.com/suncastshedmanuals.aspx
Apr 05, 2011 | Suncast Garden
Hp pavilion dv9000 laptop with a broken hinge. It fell from my bed a it looks like the piece of metal inside one of the hinges is broken.
Check out these WEB sites, they are helpful :-
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br...
This isn't for a Gateway laptop, granted. But all laptops fall into a general replacement like this.
Inside my laptop
Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Sep 28, 2009 | HP Pavilion dv9000z Notebook
How to anchor a Big Max shed
No anchor is necessary. The weight of the shed plus any contents will keep it in place unless you encounter a tornado or hurricane.
May 06, 2009 | Elite Rubbermaid Frameworks Outdoor...
Volvo 2002 s60 fuel door
My guess is that the hinge clips are broken - it's hard to see how it works after the clips are broken off. I purchased and installed a replacement hinge from Myswedishparts.com. I emailed asking for help and they provided direction, but it's pretty easy. Use a small punch to drive the centers out of the plastic attachement pins to get the old hinge off. Replace the hinge, press the center pins in and re-attach the door. There was a drawing on the referenced web site when I replaced mine, but I just looked and didn't see it. I'm sure there are many places to purchase the replacement hinge - that's just where I bought mine.
May 28, 2008 | 2002 Volvo S60
Broken screen hinge/collar
You can purchase replacement hinges and hinge covers here: http://www.mundocorp.com/m275.html They may be a bit of work to replace. But short of replacing the hinge assembly, it doesn't sound like that is going to move.
Aug 28, 2007 | Gateway M275 Tablet PC
Garden Logo
655 people viewed this question
Top Us Leisure Garden Experts
Dennis Key
Dennis Key
john h
Are you an Us Leisure Garden Expert? Answer questions, earn points and help others
