Broken recoil start on tecumseh 6.5 hp
broken cord? remove bolts holding recoil housing.lift housing straight up,you may have to wiggle it a bit.turn housing over,remove any cord thats left,note how & where it connects to the spool.wind the spool [and consquently the spring under it]in the direction the cord would turn it as pulled when starting.hold spool tight.thread new cord through hole in housing.let spool turn back just enough to attach new cord.hold cord & housing,let spring "re-coil" cord slowly.check for smooth operation.replace housing.you may need to pull cord slightly to align 'square' shaft w/hole in spool.only after you are satisfied with the operation of it adjust length of cord by pushing excess cord through the handle,tie a new knot,then cut off excess,if any.
