Question about Konica Minolta magicolor 1680MF - Multifunction - color - laser - cop... Printer
Reset end of life indicator for toner on magicolor 1650en
I replaced the magenta toner with an aftermarket, and I get magenta end of life replace toner. I cleaned the contacts, is there something else I can do?
  • Konica Minolta Master
  • 6,161 Answers
Use OEM not third party
Posted on Dec 29, 2015
5 Suggested Answers
  • 3 Answers
SOURCE: toner end life
There are silver wire contacts on the left and right that are spring-loaded and touch on copper tabs on the cartridge. They may not be making proper contact. Wiping with some contact cleaner ona cloth may help, or failing that try brightening the surfaces with some fine Scotchbrite pad to help them make proper contact.
Posted on Nov 19, 2007
SOURCE: Magicolor 5430dl, "No Toner Magenta" error
Hi this might work, have you tried to remove the toner and re-seat it??
If this doesnt work very carefully take the toner somewhere well ventelated preferablly outside and give it a good shake for about 15-20 seconds, this frees any clogged toner there may be.
Failing all of that you would want to try outting a new toner in and see what happens.
Posted on Mar 23, 2009
  • 46 Answers
SOURCE: Toner End warning occurs - even after replacing
maybe you have more than one color empty
Posted on Oct 23, 2009
canontech
  • 1219 Answers
SOURCE: Hello, I just replaced my K toner in a Konica
it's probably fault in K toner chip. Try with new toner.
Hope that helps!
Posted on May 29, 2011
My printer says "Belt Error" how can I fix this?
The printer detected incorrect
image position on the image
transfer belt.
Check the cyan and black
toner cartridges and replace
them if they have run out. Page 171 of Konica Minolta Magicolor 1650en Laser Printer Manual...
Nov 16, 2014 | Konica Minolta A034012 Magicolor 1650en...
0092 error
CAUSE: The transfer belt is not rotating correctly inside of the Image Unit.
SOLUTION: Check the PRCB connector for proper connection and correct as necessary. Also, check Belt Positioning Sensor (PS6). Replace Image Unit (p/n A0VU011). The PRCB may also need to be replaced. (p/n A034 H001 06 for magicolor 1650EN or p/n A034 H009 07 for magicolor 1680MF/1690MF)
SPECIAL NOTE: Solution contribution by SSD Printer Support
ID No.
TABP1000085EN
FROM KMBS SSD
Jun 20, 2013 | Konica Minolta magicolor 1690MF All-In-One...
Fading copies
Hi
If you have stock toner for very long time, I suggest you just shake it well to distribute evenly the toner powder.
If this solution doesn't help, roller drum inside the copier that might worn out and needs replacement.
I hope it helps you.
Jul 21, 2012 | Konica Minolta - Magicolor 1600 1600w...
Error k toner life end in konica menolta 1650en
Purchase a new toner or does it say Image Unit life?????
Dec 02, 2011 | Konica Minolta MAGICOLR 1650EN COLOR LASER...
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
Dec 11, 2010 | Minolta magicolor 2200 DeskLaser Printer
I have followed the instructions exactly for replacing the black toner cartridge on my Magicolor 2300 DL, but i still have the error message "Replace Toner Black." I tried taking out the cartridge and...
If you have changed the toner cartridge, the printer must complete a calibration cycle (up to 150 seconds). If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
1. Open the Status Display (double-click on Status Display icon in the system tray on the lower right-hand portion of the task bar, OR click Start/Programs/KONICA MINOLTA magicolor 2300W Utilities/KONICA MINOLTA magicolor 2300W Status), and then check which toner color is empty.
2. From the Print menu choose Toner Replace...
3. In the Color list box, select the color of the toner cartridge to be replaced (CYAN, MAGENTA, YELLOW, or BLACK).
4. Select the capacity of the new toner cartridge (1500 or 4500).
5. Click OK.
6. When the toner indicator on the control panel starts flashing, open the printer's front door. The carousel is automatically repositioned so that the appropriate toner cartridge can be removed.
2300-0.gif 7. Insert your thumb and index finger into the two holes in the front of the toner cartridge, and then pull the cartridge straight out about 6" (15 cm).
2300-1.gif8. Support the middle of the cartridge with your left hand, and then pull out the cartridge.
2300-2.gif9. Remove the new toner cartridge from its shipping carton.
10. Remove the protective cover clearly marked 'Remove'.
Each toner cartridge has a colored end that corresponds to a color inside the cartridge slots. Always install the toner cartridge in the slot of the same color.
2300-4.gif11. Support the middle of the cartridge with your left hand, insert the thumb and index finger of your right hand into the two holes in the front of the toner cartridge, and then insert the cartridge so that the guides on the cartridge fit into the rails in the cartridge compartment in the carousel.
2300-5.gif12. Gently push the new toner cartridge into the printer.
13. Close the printer's front door.
The printer must complete a calibration cycle (up to 150 seconds) after any consumable has been replaced. If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
Sep 01, 2009 | Konica Minolta magicolor 2300DL Laser...
Magenta (yellow) unit is PAST end of life... (I have changed cartridges I still have this message. I tried to read instruction, and I got following message: Install P/N 108R00649 following the instalation)
Hi armaskopljak:
You have replaced the toner cartridge but you still have to replace the imaging unit which is the drom that the toner cartridge attaches to.
Toner Cartridge OK, Low, Empty When 15,000
(high-capacity cartridge) or
7,500 (standard-capacity
cartridge) pages are
printed (5% print density).
Imaging Units At/Near end-of-life When 30,000 pages are
printed out or when the
pixel counts are
exceeded.
A fuse in the new
imaging unit will blow
upon installation,
resetting the counter.
Verify color calibration. Clean lenses.
Xerox Part Numbers
Toner Cartridges:
Standard Capacity Yellow 016-1975-00
Standard Capacity Magenta 016-1974-00
‘ Standard Capacity Cyan 016-1973-00
Standard Capacity Black 016-1976-00
High Capacity Yellow 016-1979-00
High Capacity Magenta 016-1978-00
High Capacity Cyan 016-1977-00
High Capacity Black 016-1980-00
Imaging Units
Cyan 016-1993-00
Magenta 016-1994-00
Yellow 016-1995-00
Black 016-1996-00
Hope this helps
Jul 10, 2009 | Xerox Phaser 7300DN Laser Printer
Konica Minolta magicolor 1680MF - Multifunction  - color - laser - cop... Printer Logo
60 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
