Question about Ryobi Garden
Fuel line for ryobi rbc30pht - Ryobi Garden
What size fuel line for Ryobi Homelite Fuel Tank Fits Trimmers 308181008
Ryobi makes a neet little fuel line kit for these , and its inexpensive too , it contains a new fuel filter (and tool for installing it) a new primer bulb (change it anyway) and enough of two different fuel line to reach your trimmer's carb , I stock a few of these here and you can buy ne from any roybi dealer , the only tool you need besides your fingers are a pair of scissors and a Phillips screwdriver for taking off the air cleaner to gain access to lines
directions are included on back of package
Jun 09, 2014 | Ryobi Homelite Fuel Tank Fits Trimmers...
Can someone tell me where to find replacement fuel hose for this style of Ryobi? The existing line has hardened with time and is leaking fuel / sucking air iat an inline connection below the primer bulb. I...
Your local repair shop should carry this fuel line in large quantities and sell it by the foot or by the inch. Your Ryobi probably uses Homelite's 3/64" line.
Homelite #70310-98 or Rotary #20-8645
Homelite Consumer Products is the company that made your 30cc Ryobi trimmer. At their website (www.homelite.com) they offer a replacement tank assembly which would include the fuel line.
I think your best opportunity is with the local repair shop.
Sep 10, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My Ryobi 77 line trimmers revs like mad when I
Hi and welcome to FiXya. I am Kelly
What your describing it the result of fuel starvation. This can be caused by:
1. Debris in the fuel line or a crack in the fuel line
2 A clogged "fuel tank" internal pick up hose screen
3. A pinched fuel line
4. A clogged needle jet seat
5. A hole in the carb diaphram
6. Debris in the fuel air mixture screw / needle passages
7. A non vented gas tank cap.
Any of the above can cause the symtom you described. For sure it is a fuel supply problem.
I tried crossing the part numbers for just a Ryobi Model 77 and was unalbe to cross it to a working model number.
I came up with 2 different carb part numbers using a 30 CC engine
1st PN: 791-182875
2nd PN: 985624001
If you can pass the exact Model Number, I can provide you with a source for the carb or parts.
Thanks for using FixYa.
Kelly
Feb 15, 2010 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
I have a Ryobi Leaf Blower (Model 310 BVr) which
Look for a cracked fuel line, or a loose fuel line around the fuel tank. I'm going to lean towards the cracked fuel line.
Feb 01, 2010 | Ryobi Garden
Putting fuel line on right on ryobi 725r 15'' 31cc weedeater
Typical fuel line routing is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Sep 08, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Fuel line routing on ryobi 775r
One line ( the one with the fuel filter in the end of it) comes out of the fuel tank and goes to the lower port on the carburator. The second line goes from the fuel tank to the bottom fitting on the primer bulb. The third section goes from the top port on the primer bulb to the top port on the carburator. Hope this helps and best wishes.
Sep 01, 2009 | Ryobi 15" Electric Factory Reconditioned...
Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
May 27, 2009 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
20 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
