Question about Samsung Galaxy Cell Phones
S6102 short bord pleas any more
SamsungE1410 bord shart how to remove
If your mobile motherboard short.. You can remove easily.. Connect full charge battery in short bord then if any component heat remove tha component or remove flirting capacitor on voltage path
Aug 26, 2014 | Samsung Cell Phones
Gt-s6102
Hi Wasif,
Here is a pay link should you want to go that way. Unlock Samsung GT S6102 Handset .
Here is a hands on method free by Altaf Khan to watch and follow on You Tube: Unlock Google Pettern Lock Samsung Galaxy GT 6102 .
And last but not least is the follow-up from the first choice to experience before you open your purse strings, How To Unlock Samsung Galaxy DUOS GT S6102 and GT S6102B By Unlock Code...
You will communicating soon. Fare. well.
Jul 06, 2014 | Samsung GT-S6102 Galaxy Y DUOS - Unlocked...
Samsung galaxy y duos gt s6102 is asking gmail account to unlock
Mar 10, 2013 | Samsung S6102 Galaxy Y Duos - Black...
What is code 14 on 03 zx636
Hi, here you go:
Service Code Problems
11 Main throttle sensor malfunction, wiring open or short
12 Inlet air pressure sensor malfunction, wiring open or short
13 Inlet air temperature sensor malfunction, wiring open or short
14 Water temperature sensor malfunction, wiring open or short
15 Atmospheric pressure sensor malfunction, wiring open or short
21 Crankshaft sensor malfunction, wiring open or short
23 Camshaft position sensor malfunction, wiring open or short
24 Speed sensor malfunction, wiring open or short
25 Gear position switch malfunction, wiring open or short
31 Vehicle-down sensor malfunction, wiring open or short
32 Subthrottle sensor malfunction, wiring open or short
33 Oxygen sensor #1 inactivation, wiring open or short (Equipped Models)
34 Exhaust butterfly valve actuator sensor malfunction, wiring open or short
35 Immobilizer amplifier malfunction
36 Blank Key detection
39 ECU communication error
51 Stick coil #1 malfunction, wiring open or short
52 Stick coil #2 malfunction, wiring open or short
53 Stick coil #3 malfunction, wiring open or short
54 Stick coil #4 malfunction, wiring open or short
56 Radiator fan relay malfunction, wiring open or short
62 Subthrottle valve actuator malfunction, wiring open or short
63 Exhaust butterfly valve actuator malfunction, wiring open or short
64 Air switching valve malfunction, wiring open or short
67 Oxygen sensor heater malfunction, wiring open or short (Equipped Models)
83 Oxygen Sensor #2 inactivation, wiring open or shout (Equipped Models)
94 Oxygen sensor #1 malfunction, wiring open or short (Equipped Models)
95 Oxygen sensor #2 malfunction, wiring open or short (Equipped Models)
Feb 01, 2011 | kawasaki ZX-6R Motorcycles
Clicking - Freezer section problem...
could be the bord but my bet is its the fan motor,,,it has a short in it,,,try unhooking the fan motor from the bord and switching it on, if the bord stayes switched on,,, its the fan motor faulty
Jul 10, 2010 | Hotpoint HSS25GFP Side by Side...
My computer mother board model number is aad28751-402
come with more qwestions about wath kind of card or you want to now the driver for it i do need brand name for your motherboard
ben.pluijm@viveole.com
Jul 01, 2009 | Computers & Internet
Mother bord not a display
have you a graphics card you could use? if so you could try re-installing graphics drivers for the onboard graphics.
if not, to test the video output you would need a post test card, available for approx £15. this would enable you to test your motherboard completely.
Feb 25, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Hallo, I dnot know monther bord number, how to identyfy can you help me? pleas
Try CPU-Z freeware program... look in the motherboard tab.
http://www.cpuid.com/cpuz.php
Jan 05, 2009 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
PC wont power up after replacing the Power Supply and MOBo
hi swich off pc & remoove power card from smps. short Bios jumper
on mother bord.(locate that jumper, lift ,short with 3rdpin &replace it as old position.
now switchon pc.
r u connect cpu core supply voltage on mother bord ?
tell me
Aug 07, 2008 | Gateway Computers & Internet
Cell Phones Logo
12 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
