Question about Pyle 2 Channel 4000 Watt High Power MOSFET Amplifier Car Audio Amplifier
Why would i spend a 100 to 120 dollars on a car amp?
Why would i spend a 100 to 120 dollars on a amp just to run
one 8 inch kicker subwoffer?
i dont want 97000 watts in my car i just want enough power
for a basic car stereo the .boss
amp is 38 dollars 200 watts 2009
version the ssl amp is 59.00 2009 verision 400 watts whats wrong with buying a amp that has the same
specs as a name brand i'm quite sure there are a lot of people
who have boss amps in their car
everybody keeps reccomending name brands wouldnt a boss
amp play just as well as a kicker if you hook it up correctly if boss products were not quality i dont believe they would have any business!!
    Novelist:
  • 131 Answers
Any amp will work with any speaker, you just need to make sure it is a mono amp if you are running 1 speaker and a stereo amp wither 2 or 4 channel if you are running 2 or 4 speakers, the ohm rating on the amp should match the speakers also, on the back of the speaker it has the ohm rating, most will be 8 ohm, but you still find some 4 ohm, depending on the speaker if it has a lot of throw (the in and out movement) you may want a higher wattage amp so you get clean sound, it is up to you.... if you are installing lower price amps to you may hear engine wine or noise while car is running so a grounde loop isolator installed on the system will remedy that... also with the amp the directions will tell you the ohm rating of the wire to use, follow that.... and keep the ground short and clean where ever you put it.. try not to go directly off the battery cause you will get a lot of noise... hope this helps..
Posted on Jun 23, 2009
How do I properly wire 2 12 inch 40 cwr122 subs to a Kicker 12cx1200.1 mono amp
Need to know the resistance of the speakers you are wiring, are they 4 ohm or 8 ohm speakers? Is this for car or home audio? What resistance does the amp show it is capable of handling?
Oct 13, 2013 | Kicker CVR12 Car Subwoofer
How do I build a shallow box for my 8 inch Kicker Comp to fit on my motorcycle
It should be built out of mdf ,That it sounds decent, As for the size of the box figgure that out your self,
Nov 27, 2012 | Kicker Comp 05C88 8" Car Subwoofer
Would a 10ZX750.1 amp be alright on a Single Solobaric L5 10" inch in a ported box???
yes, the 10ZX750.1 is capable of running two L5's at two ohms in either a ported or sealed box. Just be sure to wire it up to suit your needs correctly (if you need to know how i can help) and make sure that your box dimensions match what kicker specify. the L5 is actually one of the subs that kicker reccommend for that amp.
Hope I helped , and please dont forget to rate.
cheers
Jan 15, 2011 | Kicker Car Audio & Video
Hey
there are 2 components, so all you do is put wire from the red (+) to the (+) output on your amp. and then you put wire from the black (-) to the (-) output on your amp.
May 12, 2010 | Kicker 05C104 Car Subwoofer
Need An amp for 2, 4ohm Kicker 12" L5
i bought two Audiobahn A2300hcx on ebay for a little over 400. look around on ebay you can really score sometime dirt cheap........ Check out audiobahn amps, never did me any wrong...........
May 06, 2010 | Kicker Solo-Baric L5 Car Subwoofer
I have a jl 500/1 pops fuses some times could it be im pulling too much power from the battery because i dont have a cap or extra battery im running at 2ohm with a 15 inch kicker l5
Seems like the KICKER is pulling to much power try to knock it back up to 4ohm and see what happens. If its fine that way then you might need a bigger amp.
Apr 29, 2010 | Jl Audio 500/1 Car Audio Amplifier
Need help.. I have two 12 inch dual voice coil kicker comp vrs.. they are 4 ohm subs..how do i wire them to get a final ohm load between 1.5 to 4ohms in a dual enclosed box...Im hooking them up to a jl 500...
To do this they MUST be wired in parallel, IE: Plus to Plus, Negative to Negative. 2 4 OHMS in parallel is about 2 OHMS in series it would be 8 OHMS... series is positive to negative. Are you using a crossover network?
Mar 05, 2010 | Kicker CVR12 Car Subwoofer
How to install kicker amp to a 1995 f-150 new
nice radio bud. also want to say that the kicker amp will take the input from the stereos rca subwoffer out port on the back of the stereo, i have read about your radio before answering your questions to ensure acuracy.
Taken Directly from your manual
Press and hold the SEL button until LCD display “DSP OFF”. Press SEL button again and LCD display “WOOFER OFF’. Rotate volume to activate the subwoofer control function, then leave the unit idle for your desired setting to take effect. Make sure the unit is connected to an external amplifier.
RCA Line Out
The RCA Output Jack is on the back of the
unit on the right side. (See figure 1) This
output is for connecting an amplifier, equal-
izer, or other audio component that requires
a pre-amp out connection. (Red = Right,
White = Left) Follow the manufacturers in-
structions for the audio component that you
are connecting
The Subwoofer Output Jack is on the back
of the unit on the right side.
on page 8 of 22 on this ebook illustarted the proper wireing configurations for an aopmilifier. note: the remote wire must be conencted to the radio to the amp remote to allow radio to trun amp off and on good luck.
http://roadmasterusa.com/manuals/VRCD400SDU_eng.pdf&ei=AXyQSuzaC5KDlgfU8_jQDw&sa=X&oi=spellmeleon_result&resnum=1&ct=result&usg=AFQjCNG7aejdBV5Ravpq7UarpMzCSGBP2A
Aug 22, 2009 | Car Audio & Video
SHOULD I GO AHEAD AND BUY A 400 WATT AMP?
All amps aren't created equal. More exspense amps put out "cleaner" power. You need to know what the RMS power rating is for the amp at 8 ohms and 4 ohms. Also, is the speaker an 8 or 4 ohm speaker? How you wire a speaker or speakers (series or paralell) can change the ohms (resistence) which will change the power put out of the amp. Also, I'm assuming you are setting it up in mono?
Jun 22, 2009 | Pyle 2 Channel 4000 Watt High Power MOSFET...
What is best amp to run 2 12 inch cvr's
12In Kicker CVRs
are Dual Voice Coil, and You can run each voice coil around 200 Watts RMS
So each sub will have a 400 Watt RMS and 800 Watts peak.
Now since you have 2, Your total will be 800 Watts RMS and 1600 Watts Peak.
I would get really any amp that sits at around 800-1000 Watts RMS.
These are kicker but they are low end so i wouldnt push them to the extreme.
1000-1200 Watts RMS Max and but keep the Gain down on the amp. They will hit no doubt but i wouldnt push these subs or you will be disapointed in the long run.
I would get a Fosgate or MTX amp.
You can get any amp really but find something right around 1000 Watts RMS and it will push those well.
You can go mono block or a 2 channel, just depends on how you want to wire them.
Be careful though. If your running them bridged right now with your mono block, do not run them parallel bridged on a 1000w RMS Amp, you will blow them so fast lol
(RMS = Root Mean Square. Or in other words is the continuous wattage being sent from the amplifier to the subwoffers)
Feb 15, 2009 | Kicker KX1200.1 Car Audio Amplifier
Pyle 2 Channel 4000 Watt High Power MOSFET Amplifier Car Audio Amplifier Logo
110 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
