Question about Simplicity Garden
How do i fix sloppy simplicity hydro steering?
2 Suggested Answers
  • 5 Answers
SOURCE: re;25yr old simplicity zero turn,20hp
Check your belts
Posted on Sep 30, 2013
How do I remove the steering wheel on a 1995 Oldsmobile cutlass ciera sl 3.1l to tighten the steering column
You don't need to.There isn't any thing behind the wheel that you can tighten. A sloppy steering column has to be removed to replace any parts making it sloppy. You best bet is to call around local junk yards or maybe Ebay and find a replacement column. Your not going to find the parts you need to fix it.
Apr 03, 2015 | 1995 Oldsmobile Cutlass Ciera SL
Sloppy steering
bad steering gear or bad ball joint tie rod ends
Sep 30, 2013 | Simplicity Garden
Belt size for 616 deutz allis riding mower ,deck & drive
most wear parts numbers are on the bottom side of the hood.
Jul 29, 2012 | Garden
My brakes and power-steering are not working. The brake pedal is hard, but the brakes will not engage. The power steering was not working at the same time. It has brake fluid, but when I took the power...
Yes, your brakes are boosted by the power steering pump rather than by vacuum. I don't think it's air in the system. More likely your pump has failed, but you can try bleeding the pump. Here is a procedure from autozone.com:
Observe the following:
Use clean, new power steering fluid type only Hoses touching the frame, body or engine may cause system noise. Verify that the hoses do not touch any other part of the vehicle. Loose connections may not leak, but could allow air into the steering system. Verify that all hose connections are tight.
NOTE Power steering fluid level must be maintained throughout bleed procedure.
  1. Fill pump reservoir with fluid to minimum system level, FULL COLD level, or middle of hash mark on cap stick fluid level indicator.
    NOTE With hydro-boost only, the oil level will appear falsely high if the hydro-boost accumulator is not fully charged. Do not apply the brake pedal with the engine OFF . This will discharge the hydro-boost accumulator.
  2. If equipped with hydro-boost, fully charge the hydro-boost accumulator using the following procedure:
    1. Start the engine.
    2. Firmly apply the brake pedal 10-15 times.
    3. Turn the engine OFF
  3. Raise the vehicle until the front wheels are off the ground.
  4. With key in the ON position and the engine OFF , turn the steering wheel from stop to stop 12 times. Vehicles equipped with hydro-boost systems or longer length power steering hoses may require turns up to 15 to 20 stop to stops.
  5. Verify power steering fluid level per operating specification.
  6. Start the engine. Rotate steering wheel from left to right. Check for sign of cavitation or fluid aeration (pump noise/whining).
  7. Verify the fluid level. Repeat the bleed procedure if necessary.
Oct 24, 2010 | 2005 Chevrolet Silverado
'89 chevy k1500 sloppy steering wheel (HELP PLEASE)
Everyone always gravitates to the suspension but folks, it's 99% sure that it is the EVO. The EVO is the sensor built into the steering column that senses movement of the steering wheel then controls the power steering pump accordingly. When it goes out (which is all too frequently) you get sloppy and loose steering at lower speeds and it does tighten up a bit on the highway at higher speeds. This is the way it is supposed to work but when it fails it's downright scary trying to keep the truck straight on a narrow two lane road!
Jun 14, 2009 | 1998 Jeep Grand Cherokee
Garden Logo
Top Simplicity Garden Experts
Dennis Key
Dennis Key
dannydoesita
ray gallant
Are you a Simplicity Garden Expert? Answer questions, earn points and help others
