Question about Husqvarna Designer I
Bobbin thread not cutting - Husqvarna Designer I
    Novelist:
  • Husqvarna Expert
  • 371 Answers
With the bobbin case out of the machine, touch the cutter button. Do you see the cutter arm move from left to right and then back left. If not the cutter arm is out of place. If it does it is something else.
I usually check two things:
1 - your cutter blade might be missing or dull and needs to be replaced. I would not recommend doing this yourself unless you are very good.
2 - many times there is lint or loose threads around the cutter in the area to the left of the needle plate that needs to be cleaned out. You can remove the cover to this area by first removing the needle plate and bobbin case. Then the cover is accessible to pop off by sliding the tip of a small screw driver under the cover at the bottom right corner of the cover. There should be a little opening. Carefully pop the cover off but be careful that the blade mechanism does not come off too. With your finger carefully hold the silver metal blade area steady and pick out the loose threads/lint from around the copper looking metal part. There is velcrow on the tip of the copper metal part so be sure that you don't remove that too. That's what holds the thread for the blade to cut it. If velcrow is missing, or the silver metal part is out of place that could be the problem also.
I recommend that any repairs/service be done by an authorized Viking dealer. You can find a local dealer by checking the Viking website at http://www.husqvarnaviking.com/us and going to the Locate a Dealer link.
Good luck
Posted on Jul 13, 2014
2 Suggested Answers
  • 371 Answers
SOURCE: Husqvarna Vicking - The bobbin thread is knotting
Check that it is threaded correctly (both top and bottom) making sure that the upper thread is in the takeup lever. Watch the needle as you slowly turn the handwheel counter clockwise (toward you) and the needle point touches the fabric (make sure presser foot is down). Is the thread still relatively taunt? If it is loose, the upper thread tension unit does not have enough tension. Check the areas where the thread goes and make sure you remove any loose threads or fluff which could be inhibiting the tension discs from closing over the thread. If the tension unit still is not tightening enough, the tension unit may need to be replaced or the circuit board replaced. If everything is ok in the upper thread area, now look at the bobbin area. With no fabric, watch as the needle enters the bobbin area. Does it go down and the upper thread catch the bobbin thread and pulls it to the surface? Check for anything preventing the bobbin thread from being pulled up to the surface through the needle plate. If you have still not been able to resolve the problem suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Posted on Feb 14, 2010
How to wind a bobbin for a 250 electronic Viking Husqvarna machine
Make sure that the presser foot is raised if you are winding a bobbin with the top thread threaded through the needle. Place the bobbin on the spool spindle with the mark (a stylized H) outwards. Bring the bobbin spindle down. Next pull the thread from the needle under the presser foot to the thread guide on the right. Bring the thread above the bobbin and wrap the thread around the bobbin several times. Cut off the excess thread on the thread knife and step on the foot control to wind the bobbin. When the bobbin winding is finished, remove the bobbin from the spindle. Cut the thread to separate the bobbin thread from the needle thread. Move the bobbin spindle up.
Sewingpartsonline.com has a link to the manual for the Husqvarna Viking 250 on the machine specific parts page (under Manuals), http://www.sewingpartsonline.com/viking-250-sewing-machine-parts.aspx . The direct link to the manual is http://manuals.husqvarnaviking.com/VSM/Husqvarna%20Viking/HVManual.nsf/5bc6115484660075c12575d2003f80e3/ecf97dd171581582852575ed00755e7a/$FILE/Viking%20210,%20230,%20250%20%20x.PDF . The bobbin winding steps are on page 12. There is also a method for winding a bobbin with a different thread from the top thread. See the manual.
I hope this helps.
May 28, 2017 | Husqvarna Sewing Machines
For the dressmaker II, the first bobbin, I got through step 1-5 but where the does step 6 go BECUZ that's really trippin me, PLS tell me. And the instruction is not clear at all, I don't understand it
Hi Vicky, I hope this helps you:
1. Remove the slide cover plate by sliding it toward you, and lift
up the bobbin and the bobbin case from the machine.
2. Put the bobbin pin into the hole on top of the hand wheel and
place an empty bobbin on the bobbin pin (spindle).
3. Lift the large spool pin from the back of the machine and
place the spool of thread on the large spool pin.
4. Place the bobbin winder tension clip into the hole in the back
of the machine.
5. Pull the thread to the left and pass it through the bobbin
winder tension disc.
6. Insert the thread through the hole in the bobbin from the inside
out and leave about 3" of thread out. (ensure that the hole on the bobbin is facing upwards)
7. Hold the end of the thread and start the machine, either by
pressing on the start button or the foot control. After the
bobbin winds a few turns, stop the machine and cut the thread
close to the bobbin. (Cut the thread end that is protruding from the hole at the top of the bobbin).
8. Start the machine again and continue winding until the bobbin
is full or the quantity of thread is enough for your needs.
9. Stop the machine and cut the thread. Remove the bobbin from
the bobbin pin.
10.Take out the bobbin pin from the hand wheel and push back
the large spool pin into the slot in the back of the machine.
Good luck :)
Jun 21, 2015 | Euro-Pro Dressmaker 998B
Babylock espire thread cutter stopped working
Your cutting blade is dull. It needs to be replaced by a experienced technician.
Cheers,
K
Feb 27, 2014 | Baby Lock Espire
Automatic thread cutter.bobbin thread does not feed to the top.
when you stop sewing where is the arm located ,up or down ..that will make a world of difference
Jan 06, 2014 | Elna 7200 Computerized Sewing Machine
Needle goes down but don't pick up the bobbin thread. It come up and tell me that my upper or lower thread is cut.
try changing the needle
try rethreading the machine top and bobbin
make sure to use every thread guide-this is improtant for the
thread tension
make sure the bobbin is turned correctly in the bobbin case
also could be a problem with the computer motherboard
or there could be a problem with the timing
Dec 03, 2012 | Brother PE-150V Computerized Sewing...
BOBBIN THREADING ON BERNINA 1090S IS NOT WORKING
Make sure bobbin is pushed all the way to the right to lock in place for winding. You say thread cuts...Do you mean bobbin in bobbin case and you are trying to sew, but thread is breaking? If so, a whole different issue. That means there is jam and it can happen if thread not going into tension discs top of machine. Keep presser foot in up position when you thread your machine. Clean the bobbin case and feed dog area out with a brush. Always turn handwheel toasted you or you can cause imbalance of timing. Slow down. Start over after you check basics. Make sure presser foot up when you insert new needle and thread front to back--flat side needle back, more rounded side facing you, use emery cloth to carefully, gently smooth out any burrs or scratches on your bobbin case (that threaded bobbin fits into), and make sure bobbin you place into bobbin case has thread EVENLY distributed on it. Good luck! Jimmy
Apr 03, 2012 | Bernina Sewing Machines
Bobbin
To insert a filled bobbin, lift the presser foot and turn the hand wheel to put the needle at the highest point. Slide open the face plate and drop in the bobbin with the two holes up. Pull the thread into the groove near the center front of the bobbin opening and then to the left (another groove). Then pull it to the back of the machine and close the face plate.
To wind a bobbin, you will need to unthread the machine most of the way. Leave the the thread through first and second thread guides. Then bring the thread around the bobbin winding disc (so that it goes under and around the disc) back towards the bobbin pin (on the top right of the machine). Pull the thread through the correct hole in the bobbin (the one away from the center of the bobbin). Leave a 4" tail. Push the bobbin onto the pin and then push the bobbin and pin as far to the right as it will go. Hold onto the thread tail and step on the presser foot to start winding. After ~10 winds, temporarily stop winding and cut the thread tail. Then step on the presser foot and complete winding. When done, cut the thread to separate the bobbin from the top thread. Rethread the top thread and insert your bobbin.
The manual for the 4228 is available here: http://www.singerco.com/uploads/download/492_4228_4220_030707_new.pdf . See page 31 (18 of the pdf) for pictures of threading and winding the bobbin.
I hope this helps.
Jan 19, 2012 | Singer Inspiration 4228 Mechanical Sewing...
Husqvarna Sapphire - thread cutter not working
Does the metal arm come out to grab the threads to cut it? Is there a blade in the metal arm that cuts the tread? I think a standard utility knife cutter blade is the same size (just like the one that cuts the bobbin thread when you put in a new bobbin). What happens when you activate the cutter is the arm comes out, grabs the threads, brings them to the blade which cuts the threads, the velcro by the cutter holds the bobbin thread in place for the next stitch. Otherwise the thread may end up on top and the top thread would not be able to pick it up for the next stitch.
Good luck.
Jun 27, 2009 | Husqvarna Viking 1
Upper thread keeps breaking bobbin thread grtting cut on bobbin,
you need to change your needle first. then if that does not work you may have a small area on your bobbin case that has been damaged
May 22, 2009 | Baby Lock Esante
Sewing Machines Logo
91 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
