D7CG036N07925A PACKAGE ROOFTOP UNIT
3 Suggested Answers
  • 189 Answers
SOURCE: the pilot on my rooftop day and night gas package
you will need a flat blade screwdriver, 3/8" and a 7/16" open end wrench and a new thermocoupling. remove and clean the pilot assembley. install a new thermocoupling. replace the assembly. follow the pilot lighting instructions on the furnace. this should solve your problem.
Posted on Mar 28, 2009
toddsteele72
SOURCE: Airtemp rooftop package AC unit M/N- RT-3130-01,
RT stands for Rooftop
3 stands for 3 Phase, 1 for single compressor and the remaining 30 stands for 30kW nominal cooling.
Posted on Sep 18, 2012
My Dad doesn't want to pay anything to answer our question. If answering the question is free, you can answer it. My Dad is 94 and very stubborn so thank you for understanding. He owns a Carrier...
LOL. Tell your dad since he has lived that long, he deserves free answers! Yes on that Carrier package unit, there is a time delay fan switch. I believe it is located up by the blower section, and probably when you take the two screws out that hold it, there will be an insert behind it. Shouldn't cost too much, less than 100 anyway. Be sure to shut the power off to the unit before taking it loose. Hope this helps. Keep your dad cool, he deserves it.
Jul 22, 2011 | Carrier 50TJ028 Rooftop Electric Cool Air...
Airtemp rooftop package AC unit M/N- RT-3130-01, what is the capacity of this unit
Aug 25, 2010 | Airtemp B6D30E7A Air Conditioner
I have my dometic Rooftop ac unit. The heatstrip/fan run perfectly but when I turn on the ac...the fan runs good but when the compressor kicks on it just hums.
The compressor coming on does make a slight "humming" sound which is normal. Is the unit cooling properly? Do you think it is louder than before?
May 09, 2010 | Dometic Rooftop RV Air Conditioner
How to identify the btu of rooftop AC unit
ANY # DIVISABLE BY 12. MODEL HAS  12-24-30-36-40-48-54-60 12 1 TON 24 2 TON 30 2 1/2 36  3 TON 36.00 BTU 40 3 1/2 48 4 TON 48.00 BTU 54  4 1/2 60 5 TON   60.000 BTU
Apr 21, 2010 | Dometic Rooftop RV Air Conditioner
We require condenser fan motors for Interclisa Carrier package (rooftop) air conditioner model AAD 250 (1980's model) model. Air conditioner - supply voltage 380 Volts 50 Hz AC. Condenser fan motor voltage...
Hi, this is an odd voltage 380 volts. Is it a 3 phase unit? To get a 220 volt 50hz condenser fan motor, you will have to go through a refrigeration/air conditioning parts house and order this. 60hz you would have no problem finding one in stock. Carrier is a good unit, and have been around for many years. You shouldn't have any problems locating one.
Sincerely,
Shastalaker7
PS You will need to go through a wholesale parts house.
Jan 21, 2010 | Carrier Heating & Cooling
Is it hard to install a heat strip in a model#57915541 serial#54936348 air conditioner
Hi, like most of the RV roof tops, they will have a manual showing the type and wattage of heat strips you're system calls for. It comes as a unit, pre-wired to fit and set in place. You should have no problems installing a heat strip kit, but make sure you get the right one that the unit calls for as they do make several models. Very self explanatory. Also, be sure that you're system calls for a heat strip package?? Good Luck, and if you need more help please contact me. Very easy to set in place and plug in. Sincerely,
Shastalaker7
Dec 10, 2009 | Dometic Rooftop RV Air Conditioner
Carrier package heat unit Model 50TJ-006---600 Unit is around 20 degrees and at 425psig on the high side...frost lines on the evaporator coil...high is super hot and the suction line is mild...no cooling...
reclam the units refrigerent and wight it to what it says on the compliance plate then put it on the vacum pump for a hour then recharge the system and see what happens.or you might hav a faulty compressor.
Jun 09, 2009 | Carrier 50TJ028 Rooftop Electric Cool Air...
The pilot on my rooftop day and night gas package unit will not light. please help.
Mar 25, 2009 | Goodman GMS90703BXA Heater
Air conditioner short cycling
Sounds like the thermostat probe is behind the filter,next to the coil,and not sensing good return air . just punch a hole through the filter so the bulb can sense return air! thank you-very-much!
Jul 21, 2008 | Dometic Rooftop RV Air Conditioner
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
