Question about Canon Office Equipment & Supplies
Canon scanner device could not be locked - Canon Office Equipment & Supplies
I have problem with my canon Scanner 110 lide
Disconnect the USB (which is the power source) and install the driver. Then reconnect the USB. The driver should be detected automatically. Go into "Device Manager" to check.
Jan 01, 2015 | Canon CanoScan LiDe110
Code 2, 189,0
All scanners come with the scanning head locked to prevent damage to it during shipping. On the back of the scanner, where the power cord and wires connect, there will be a sliding switch, sometimes a turning type lock, with two positions, one with the icon of a closed [so locked] padlock and the other with the icon of a open [so unlocked] padlock. Every scanner I have bought describes this lock in the setup manual.
Oct 17, 2014 | Canon CanoScan 9000F Mark II Color Image...
How do you get rid of the Canon DR-7550C -4630 error "The device could not be locked"?
It's usually a software conflict.
If you have multiple scanning programs, the one of them may have it locked. Especially if you have a scanning program that runs as a service.
Jun 13, 2014 | Canon imageFORMULA DR-7550C - Document...
Canon dr-2010c device cannot be locked
I hope there is enough hard disk space is available in the drive/volume you are attempting to send the data. Scan in TIF compressed mode, uncompressed made uses large space.
Check if there is virus on your system. Uninstall and reinstall the drivers. Run scandisk to optimise disk performance.
S. Mohan
Apr 03, 2012 | Canon DR Office Equipment & Supplies
I have canon DR-2010C scanner which gives error after some times.my system is vista.the error is "The device could not be locked. Check to see that another application isn't using the device...
Question
canon DR-2010C scanner which gives error after some times.my system is vista.the error is "The device could not be locked. Check to see that another application isn't using the device -4630".
Answer :- change USB cable which is connect with scanner to PC or laptop definitely it will resolve.
By:- shyam shyam.lal@teamcomputers.com 9210845186
Sep 13, 2011 | Canon DR-2050C Path-Through Scanner
Can any one help to find product that uses validated keypad code entry that could "unlock" the device and take copies and lock Once that is done, for canon 3300 copiers.
The Canon 9080C is purely an input device and cannot 'take' copies, however it can scan any A3/A4 document which can be printed or emailed. By printing you get the copy. Technically it is possible to control the software/Computer through Software password.
S. Mohan
Aug 29, 2010 | Canon DR-9080C Path-Through Scanner
Installed driver twice for Canon DR-2050c. Still
Pls run checkdisc/scandisk on your Comp. Your OS may be corrupted. Just to verify try scanning by connecting to a formatted newly loaded OS Computer.
S. Mohan
Sep 09, 2009 | Canon DR-2580C Path-Through Scanner
Canon MX310 Scanner Error
The scanner mechanism is locked....there should be a bar or button that slides to lock/unlock. Probably a picture of a lock.....this prevents damage while transporting the device....
May 12, 2008 | Canon MX310 Office All-In-One Printer
Scanner lock is on
the luck for a scanner is usually located under the device near whenr the head is parked. Have you looked. Check the manual Go to canon for Tech Help Take a look through this lot http://www.fixya.com/support/p466666-canon_printer_mp830_all_in_one/solutions
May 16, 2007 | Canon MP830 All-In-One Printer
49 people viewed this question
old marine
old marine
