Question about Canon PIXMA MP530 All-In-One InkJet Printer
INNER COVER IS OPEN FOLLOWING CHANG IN INK
I RECEIVED A LOW INK MESSAGE. I REPLACED BOTH BLACK INK CARTRIDGES. NOW, THE MESSAGE REMAINS LOW INK AND INNER DOOR IS OPEN.
  • Canon Master
  • 365 Answers
The inner door is the CD tray that is disabled in US versions.
Look right above the paper output tray and you will see a 6 inch long and 1.5 in wide tray sticking parrallel to the output tray.Flip it back up and you should be good to go.
Posted on Jun 23, 2009
Lexmark x5470 the machine received faxes but does not print them. saying "fax jobs in memory"... how do i print them?!?!
It could be because one of your cartridges has low ink level, thus printer is not able to continue printing the fax message. Open the printer cover and replace your cartridges (without navigating away from the fax mode). Once cartridge/s has been replaced, just hit the Check mark to print the fax message.
May 18, 2011 | Lexmark X5470 All-In-One InkJet Printer
I've received the error message: "Printer
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Dec 23, 2010 | HP Photosmart C4580 All-in-One InkJet...
Ink red light on . which colour is out?
When red ink light flashes - one or more ink cartridges is low. When you print, a message on your screen will tell you which one(s).
When red ink light remains on - one or more ink cartridges is empty. When you try to print, a message on your screen will tell you which one(s).
Furthermore: When following the procedure for installing a new cartridge, if the red ink light was on or flashing, pressing the ink button will cause the carriage to stop with the cartridge that needs replacing under the "ink out mark" (ink droplet with a slash through it).
Jan 08, 2010 | Epson Stylus C66 Inkjet Printer
Getting "inner cover is open" message
The inner cover is a flap on the inside in front of the carriage when it is at rest when the cover us open. You had to flip the inner cover down to access the ink cartridges.
Open the cover. The inner cover is in the center and need to be flipped up.
Good luck.
Dec 04, 2009 | Canon Pixma MP500 All-In-One InkJet...
I recently replaced the magenta cartridge in my HP 3210 Photosmart printer because the light indicated it needed to be replaced. However, the printer still won't print, and the message still says that I...
If you turned the machine off and replaced the cartridge, you can get this error.
Could you try the following procedure below please to clear the error, thanks.
  1. Turn on the unit.
  2. Open the top cover to access the print cartridges.
  3. Remove the new cartridge that is causing the message.
  4. Reinsert the cartridge and close the cover. The following message will appear on the front panel: "Press 1 for new cartridge or press 2 for a used cartridge."
  5. Press the 1 on the numeric keypad of the HP product.
If the message, press 1 for new cartridge or press 2 for a used cartridge, "does not appear after removing and reinstalling the new cartridge, and the low ink warning message still displays,
follow the steps below:
  2. Open the top cover to access the ink cartridges.
  3. After the cartridges stop moving, unplug the power cord.
  4. Remove both cartridges and close the top cover.
  5. Plug the power back in. The unit will reinitialize and a message will appear to insert the cartridges.
  6. Open the top cover and reinsert the ink cartridges. Close the top cover. The message,
  7. Press 1 for new cartridge or press 2 for a used cartridge," should appear.
Hope this helps
Regards.
Apr 18, 2009 | HP Photosmart 3310 Printer
How do you remove the ink cartridges from Canon MP890?
  1. If replacing both ink tanks, remove and replace each one individually.
  2. Make sure the device is powered on.
  3. Lift the scan unit until it locks into place. When the machine is ON and the scan unit is lifted, the paper output tray automatically opens.
  4. Open the inner cover.
  5. Hold the tab and pull it forward to release the ink tank.
  6. Lift out the ink tank.
  7. Remove the new ink tank from its packaging.
  8. Hold the ink tank and remove the protective cap.
  9. Insert the ink tank into the empty slot on the print head.
  10. If you need to replace the other ink tank, repeat steps 4 to 8.
  11. Close the inner cover.
  12. Return the scan unit to its original position. The LCD displays a message asking if you replaced an ink tank.
  13. Press [<] to select <YES>.
  14. The LCD displays a message asking if you replaced the black ink tank.
  15. If you replaced the black ink tank, press [<]. If you did not, press [>].
  16. The LCD displays a message asking if you replaced the color ink tank.
  17. If you replaced the color ink tank, press [<]. If you did not, press [>].
  18. The ink counter is now reset.
  19. If additional ink tanks need to be replaced, replace them now.
Jan 22, 2009 | Office Equipment & Supplies
Black ink cartridge doesn't work.
Have you tried
  1. Taking out all the cartridges
  2. Power down the power
  3. Power up the printer
  4. Open the scanner Cover
  5. Close the scanner cover
  6. Message will ask you to put the ink.
  7. Put in Black
  8. Close scanner cover
  9. It may ask you whether the Black is being changed.
  10. Open the cover.
  11. Install Cyan.
  12. Repeat step 8-10 for the rest of the 2 colours.
  13. It should resolve the Black ink empty message.
Let us know if this works.
Thank you.
Dec 11, 2008 | Brother DCP-110C All-In-One InkJet Printer
shut the cd tray side, turn off and start again
Apr 29, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Bought today a hP7200 All-inOne Series. Set up and received the following: Error message "Incorrect Ink Cartridge: The following ink cartridges cannot be used after device initializaed and must be...
hi friend
try remove your printer cardige & rinstall it if u have not remove your printer cardige nosel raper so remove tape of the nosel try to install & print
Apr 13, 2008 | Office Equipment & Supplies
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
282 people viewed this question
old marine
old marine
