Question about Samsung RF4287HA
The temperature of the refrigerator and freezer is not lighting up on contro panel on front of refrigerator. Also I cannot get the childlick for ice to go off
SOURCE: Samsung RS21w USA style frige freezer panel problem
If the fridge has been making more noise than usual, like the sound of a plastic fan grating against something then the fan has probably seized up with ice. This will cause the fridge temperature to rise. It is located at the back of the fridge behind a plastic panel at the bottom where the water cooler pipe and bottle are. You need to partially remove this panel just enough to be able to aim a hairdryer down the back of it to defrost the fan.
Posted on Sep 20, 2007
IrishDruid
  • 2712 Answers
SOURCE: Samsung RS2555SL Side by Side Refrigerator
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
If you are unable to troubleshoot the problem from here, you may need to contact a qualified appliance repair technician.
Posted on May 19, 2008
  • 121 Answers
SOURCE: Freezer compartment is OK, But refrigerator is
sounds like your thermostat may be bad . the thermostat senses the tempreture in the fresh food section and turns the ref. on and off as needed . do it yourself roughly 39-89 dollars if u hire a proffesional around 95.00- 165.oo depending on were u live and who u use.hope this helps
Posted on Oct 06, 2009
  • 117 Answers
SOURCE: Refrigerator (Samsung RS2555SL) quit cooling
hello dont know if you have the same model
but this may be worht a look
samsung fridge freezer problems
http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01"> name="allowFullScreen" value="true">http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344">
Posted on Oct 03, 2010
bobicehouse
  • 1524 Answers
SOURCE: This RF263AERS refrigerator was repaired by LOWEs
Some newer refrigerators have been using an electronic board instead of an mechanical defrost timer. The adaptive defrost control. does the same job as the defrost timer ( shuts off the refrigerator cooling items and redirects the power to the defrost heater for the defrosting cycle, then redirects the power to the compressor and fans to come back on when the defrost cycle is over ). This adaptive defrost system is a bit different when testing, normally speaking if the defrost heater and defrost thermostat pass the ohm test, we replace the adaptive defrost board.
Posted on Nov 27, 2010
There is a constant buzzing noise coming from the lower freezer ice maker. It is producing very few ice cubes. The control bar is down and in proper position to make ice.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow
May 21, 2015 | Whirlpool Gold Series GB2SHTXTS (219 cu...
Got fridge freezer but no instructions. Alarm keeps going off. Front panel contriols
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Apr 10, 2015 | Refrigerators
Front panel blinking
I have a Samsung RF265AABP model. I had the same problem, with the right 8 on refrigerator temperature flashing (top bar only on 7 segment display). The set buttons would not change the display either. The refrigerator and freezer both were about the right temperature (41F and -3F).
The problem was a broken temperature sensor wire on the ice maker. The sensor assembly often gets snagged on the ice tray or scoop or something and falls down, making it more likely to snag, and prevents the ice maker from cycling when frozen.
I fabricated a metal bracket to hold the temperature sensor assembly in place, and used a small tie wrap to hold the wire to the bracket, up and out of the way after soldering the broken wire of course.
If you have a volt meter you can do some diagnostics. Remove the cover from the back of the refrigerator to access the control board. Measure the voltages on the power supply, marked +12V and +5V
(yel and red, blk common). If the display reads 88 88 then the power supply is probably fine. Measure the voltages on the sensor connector CN30 at the bottom of the main control board (larger one). The gry wire on the left is common, and you should read approximately the following on the other wires starting on the left:
WHT 2.63 may depend on Pantry temp setting fresh or cold
BLU 3.59 R-DEF sensor refrigerator defrost I assume
WHT 2.55 R sensor, refrigerator temperature I assume
ORG 4.06 F-Def sensor, freezer defrost I assume
RED 3.54 F sensor freezer temperature, may depend on whether ice is frozen or still water in ice maker.
When the ice maker wire was broken, the readings on ORG and RED were 4.30 and 4.05 volts so I assume high readings above 4 volts might indicate a sensor open condition.
Control board access panel removed
Temperature sensor connector CN30
Nov 13, 2013 | Samsung RF267AERS French Door Refrigerator
Refrigerator and freezer not working
What is the model number for you fridge?
Mar 12, 2013 | Refrigerators
Frigidaire refrigerator/freezer side by side--compressor keeps running
Most problems with side by sides frosting up is due to failure of the defrost heater in the bottom of the freezer section behind the panel inside.
Jun 16, 2012 | Refrigerators
Water and ice despencer does not
look at the pc board . on front of door . loose connections may be problem and if not repl contro panel . mm
Aug 10, 2010 | Maytag 22.7 Cu. Ft. Side-by-Side...
I have a Kenmore Coldspot Top Freezer refrigerator. Everything in the freezer is really, really cold, but the refrigerator is not. I tried to clean the coils at the bottom, but I could only get to the one...
There is an ice blockage between the freezer and the refrigerator. Cold air passes from the freezer into the refrigerator in the back behind the plastic housing with the temperature controls. Empty your freezer and remove the bottom panel. You will see that everything is frozen. Carefully remove this ice until you can clear the passage to the refrigerator. It may be helpful to remove the temperature control housing in the refrigerator as well to see when the ice is cleared.
Oct 03, 2009 | Kenmore 53642 / 53644 Side by Side...
Mr.
When the heater comes on for defrost behind the rear freezer panel , it gets red hot . The defrost thermostat ( bimetal ) , cuts the heater off , when it reaches 140 degrees for new (2000 - 2009 ) and 55 degrees for older refrigs . When this temp is reached at the top of the coils , the lower portion will be hotter due to being closer to the heater . The frozen food in the freezer , is what keeps the temp down in front of the rear freezer panel . No food in freezer , the hotter the freezer section will be .
Oct 03, 2009 | GE Hotpoint® HTR17BBSL Top Freezer...
Freezer not working properly
Your heating element has failed and needs to be replaced, the heating element keeps your coils from icing up and in return when then go bad cause this problem.
May 16, 2009 | GE Monogram ZISB360DR 36'' Trimmed For...
Samsung RF4287HA Logo
13 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
