Question about Thetford Refrigerators
Thetford error 14 - Thetford Refrigerators
Will a fridge still work if fault code 13 is displayed?
13 error code means heater element in freezer drain bad replace have to take apart whole freezer
Aug 12, 2014 | Thetford Refrigerators
I have error code 8 on thetford fridge how do I remove code to used on 240 v
If switching off and on again doesn't clear fault 8 (ac volts 20% lower than spec) you may need to replace the board for one with a resetting fuse.
May 19, 2012 | Thetford Refrigerators
Thetford n97 fridge runs ok on electic for 6 hours then flashes up diagnostic No 14 and stops working
Error code 14 usually means that the powerboard is faulty. This would require replacing, it is found in a black box at the rear of the fridge.
Oct 28, 2011 | Thetford Porta Potti
Thetford N90 EL.L built-in has stopped cooling/freezing. It has power (the light is on) Any repair suggestions?
If it won't cool on all 3 power sources the cooling unit is probably faulty. Contact Thetford asap if the unit is uner 3 years old as it should be under warranty. Thetford won't sell a replacement cooling unit, their only answer is that you need to buy a new fridge at over £600. I have this problem too and am looking for another solution but to luck so far
Mar 28, 2010 | Thetford RV Refrigerator - N300 Model -...
Will not turn on as error code no 14
simple answer. Little resetable fuse on power board, F5 as i remember. It causes the display board to go insane as it doesn't provide enough power to the board. Solder a 2amp one across it. I nicked one from an old computer motherboard USB fuse(usually mounted next to each usb socket). SORTED! was an issue with 2007/8 fridges, especially if you had solar panels fitted tgo your caravan!!!! :)
Jan 03, 2010 | Thetford Refrigerators
Electric diagram c2
go to thetford main site, you can download all manuals and diagrams
Jul 02, 2009 | Thetford Porta Potti
Will not ignite with any source of power
is this a Sub- Zero? Need to know what brand it is and a little more explaination as to the problem
Apr 01, 2009 | Thetford N641
Refrigerators Logo
16 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
tom wright
tom wright
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
