Question about Toaster Ovens
Intertek 10 In 1 toaster oven
Where can replacement heating rods be gotten? Style # 46-0048-2
SOURCE: Heating elements
I just called the company @ 1-800-947-3744 and they are sending me a new toaster over to replace Model #328. DO NOT use the oven was what I was told and when the new oven arrives they'll tell me what to do with the damaged one. Mine had 2 warped areas on the front upper heating element.
Posted on Nov 25, 2008
cactus bob
  • 267 Answers
SOURCE: sunbeam toaster oven upper heating coil not working
the part (element) cannot be bought , its connectors are welded into place ........ if you realy love your oven , you can get one by shopping in a goodwill store for a used oven and cut the element out and cut and weld the element into your oven ........ this does work ,i have done it
Posted on Feb 25, 2009
  • 864 Answers
SOURCE: can the top heating element on the b&d under
I have replaced heating elements on B&D toaster ovens in the past. Check here for specific information about your model: http://www.blackanddecker.com/CustomerCenter/parts.aspx
Posted on Nov 24, 2009
woodchuck789
  • 4070 Answers
SOURCE: How do you get the top heating rods to work on the
broil for the top and bake for the bottom and toast for both together.
Posted on Jan 25, 2010
kebah
  • 683 Answers
SOURCE: Oster 6058 Toaster Oven heating
You will be able to locate authorized parts and service centers by visiting http://www.oster.com
Regards.
Posted on Jun 18, 2011
Is preheating this toaster oven necessary? How do you preheat?
Preheat is helpful when you're not cooking for more than a few minutes. If you're going to cook for 20 minutes or more, then most likely you don't need to pre-heat.
To pre-heat, simply turn your toaster-oven on 10 minutes before you put the food in.
Feb 27, 2016 | Toaster Ovens
What part needs to be replaced when the lcd and controls work but no heat?
Most likely suspects in this scenario would be the heating element or the temperature sensing rod. Not sure what the sensing rod setup on this oven looks like, but it is generally a few inches long, similar diameter to a charging cable for your phone, attached to the back wall of the oven and sticking out directly toward the oven door. If it goes bad, the oven may think it has reached the set temperature and turn off, but generally, it is the opposite (it allows the oven to get too hot). My guess is heating element, but the sensor generally costs a lot less to replace, though maybe not with a small toaster oven. Good luck!
Jul 18, 2014 | Breville BOV800XL 1800 Watts Toaster Oven...
Where do you buy heating elements for black and decker perfect broil?
I was unable to locate the replacement heating elements for your toaster oven. These parts do not appear to be available. Probably buting a new toaster oven is your best bet.
May 08, 2014 | Black & Decker CTO4400B Toaster Oven with...
HEATING ELEMENTS
The heating elements are inside on the top and bottom
Jun 08, 2013 | Bella Cucina 13049 1500 Watts Toaster Oven...
My toaster oven stopped heating all together.
your heating element has gone bad or there is some bad wiring in the oven itself
to check open up the toaster oven and look at the wires coming from the heating elements inside to the timer on the front panel if there is no bad wiring then the heating elements are bad and the toaster oven needs to be replaced
Jan 02, 2011 | DeLonghi XR640 Retro 1500 Watts Toaster...
OSTER TOASTER OVEN --- TIMER TWIST KNOB BROKE
you can get on amazon for sure. take a look here Thanksgiving essentials from the Oster brand. p.s. take a look on seller reviews. I hope this was helpful. cheers
Jan 19, 2009 | Oster 6232 / 6233 1500 Watts Toaster Oven...
Heating elements
I think this is a common problem with these kind of toaster ovens. Mine isn't a Toastmaster - mine is Cook's Essentials (from QVC), and my upper elements have also warped and split, although mine are curved downwards.
Dec 12, 2007 | Toastmaster 328 Toaster Oven with...
Toaster Ovens Logo
32 people viewed this question
Top Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a Toaster Oven Expert? Answer questions, earn points and help others
