Question about OKI B6500 Led Printer
B710 service error - OKI B6500 Led Printer
We have put a new toner cartridge in our oki b710. it still reads 0% how do we reset?
There are some toners out there that do not have the "Chip" that makes contact with the printer itself. If you have the old cartridge then you can prize out the chip and fit it into your new cartridge. that will get it working again.
Nov 30, 2016 | OKI Office Equipment & Supplies
How to reset Oki 720 to factory default
Okidata B710 and B720 Maintenance Reqd. Reset Procedure
To enter the Diagnostics area:
Turn the printer power OFF.
Press and Hold the MENU^ and Enter buttons.
Turn the printer power ON (you can release these buttons as soon as "loading ... '' is displayed.
The Operator Panel reads "Diagnostics"
There is a list of Test Options and settings.
Press the Down Arrow highlight "Maintenance Info." Press the Enter button
The Operator Panel Display reads "Maintenance Info" with setting listed.
Reset Maintenance reqd. is highlighted. Press Enter
Reset Maint. Reqd. is displayed and Execute is highlighted.
Press Enter.
The Display reads - Resetting Maintenance Required.
This completes the process.
Dec 23, 2015 | OKI Office Equipment & Supplies
May I use higher octane unleaded fuel in this engine? (Say, 97 or 98 octane).
Hi Paul
Certainly you can. We use mid-grade or supreme in our Honda 15 outboard all the time. If the higher octane isn't needed, no harm done. After all, with a boat motor, it's working hard all the time and the higher octane certainly can't hurt.
Hope this helps.
-Steve
May 16, 2015 | Clymer Mercury/Mariner 4-90 HP Four Stroke...
My acer iconia B710 turns on it runs but my display is dark "negative" looking. I'm able to go to all apps but it remains dark
Check the brightness settings on the f keys should look like a light bulb and have 1 up and 1 down
Sep 20, 2014 | Computers & Internet
I have oki b710 and only loading... message is displayed but nothing else happeness printer doesn't initialize.
I called this number - 1-800-654-3282 available 24/7
and they have steps
1. Turn off the printer
2. Press the "menu" and "online"
3. Press until the screen says - "Format User Flash"
4. Press "enter"
5. Restart printer when prompted
Apr 11, 2012 | OKI Printing Solutions B710dn Printer
Error call service 4000:00433933
The codes on this model are the same as on the Kyocera Mita copiers.
ie: 4-digit codes
Call service 0150 engine pcb EEPROM error
Call service 0420 option paper feeder communication error
Call service 1010 lift motor lock error
Call service 1140 lift motor going up error
Call service 1150 lift motor going down error
Call service 2000 main motor error
Call service 2200 drum motor error
Call service 4000 laser scanner unit (polygon motor) error
Call service 4200 laser scanner unit (pin photo sensor) error
Call service 5100 short-circuited main charger output
Call service 6000 broken fuser heater lamp M wire
Call service 6020 abnormally high fuser thermistor M temperature
Call service 6030 broken fuser thermistor M wire
Call service 6400 zero-crossing signal problem
Call service 7000 toner motor lock error
Call service 7410 drum unit non-installing error
Call service F000 communication error between the main controller board and operation panel board
Call service F010 main board (system DIMM board) checksum error
Call service F020 main or expanded memory error
Call service F030 general failure
Call service F040 communication problem between main board and engine board
Call service F226 main pcb video data control error
May 18, 2011 | Kyocera FS-3900DN Laser Printer
Computer shows no display
did you try installing newest drivers from intel/gigabyte website? what you described looks to me as a overheating problem. try running the game with case open. are you running on the integrated GMA graphics or PCI-E graphics card(like geforce, radeon)?
Jul 02, 2009 | Gigabyte Computers & Internet
Error c0998
That what service manual says:
Service Req xyyyy
A Controller error or print engine error detected. Turn off the printer. Wait at least 5 seconds and then turn it back on. If the error message still appears, write down the error number listed on the LCD panel (xyyyy) and turn off the printer, unplug the power cord, and contact a qualified service representative
Apr 29, 2008 | Epson Aculaser C1100 Printer
OKI B6500 Led Printer Logo
243 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
