Question about Thetford Norcold DE0051 Refrigerator
Ref quit check gas lite is blinking why wont it run on elecvt ?
Heater fires 3 times then quits, light on control board quits blinking then minutes later it tries again.
It sounds like a weak pilot generator. They wear out after a number of years. It is trying to fire which means the safety loop is all good. Sometimes the pilot generator is strong enough to keep the pilot valve open, but upon call for heat the main gas valve isn't getting enough voltage to open (and a good voltage output from the generator drops to nothing). It's not too hard of a diy
Sep 12, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
Rml8555 ref will not run on gas
make sure trailer is level also check voltage at back of unit
Nov 20, 2012 | Dometic Refrigerators
My car wont stay idling
Lets start with figuring out why the check engine light is on. You can get a blinkout of the the code by switching you key to the on and off position three times quickly and leaving it in the on position on the final time (note, do not take the key so far that it tries to start the engine). So start with the key in, and engine off, quickly turn the key to on, then off, then on, then off, then on and leave it there. Now watch your check engine light. It will blink out any codes that may be stored. The blinking will have breaks between each code and each code is a two digit number. For instance, blink short pause, blink blink, long pause, blink, blink, blink, pause, blink, blink, would be codes 12 and 32. I believe the final code is 55 and just simply means "end of codes". That should at least tell you if its an issue the ECU has detected. You can do a quick google search to find out what each code it spits out means. As for a guess as to why it isn't idling...I've seen everything from a failing fuel pump (inadequate pressure), to a clogged EGR valve cause this. Could be quite a few things unfortunately. Good luck!
Feb 25, 2012 | 1995 Chrysler LeBaron
My problem is i have a jandi lite 2 and the control panel is just blinking just wondering if there is a reset button i had the heater working good then shut it down now i cant get it to work it just...
check to see if water temp sensor shorted remove to black wires from control board if it quits bad temp sensor if it doesnt bad display board need new display board
May 23, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
My pool heater wont start the pilot light is on the red light is blinking and the fuel tank is full the temp. Is on high .the burners came on for asecond and then shut off?????what should i try to do now??
With these pool heaters, there are a couple things that you can check yourself before you call a pro for this problem. Try cycling the ignition sequence until all air is out of the gas line. Also, check your gas valve. If it is manfunctioning, it will need to be replaced.
Jul 12, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
The gas heater will not turn off. I have removed
disconnect one wire from the gas valve if the flame quits it is a thromostat problem
if not try tapping the gas valve if the flame wont go out then the valve is stuck and must be replaced if the flame goes out after you tap on it the valve still needs to be replaced
Sep 11, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
F150 tail lites will not come on when headlites come on
Check to see if the wiring isnt wrong. sometimes wires get crossed and the lights wont function properly. check each strand that they go where they belong.
Apr 11, 2009 | 1982 Ford F 150
Goodman ac/gas furnace unit mdl. # gmp075-4
i HAD THE SAME PROBLEM, TURNS OUT IT WAS THE FLAME SENSOR, CLEANED IT, AND ALL WAS GOOD
Nov 27, 2007 | Cozy (W352E) Heater
Thetford Norcold DE0051 Refrigerator Logo
19 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
john h
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
