Question about Avaya 2410 Corded Phone
Phone features not available Download denied - Avaya 2410 Corded Phone
How do I remove Denied in Admin from a Nortel phone handset t7208
It's not so much removing Denied in Admin as it is enabling whatever feature the user was trying to access at that set.
Which was... ?
Aug 11, 2014 | NorStar T7208 Corded Phone
Connection has been denied by PAN server
You can only pair your phone to your computer by bluetooth to use the personal hotspot feature, nothing else. So, unless you're setting up personal hotspot it won't pair. File transfer by bluetooth is not supported.
Did you subscribe to the personal hotspot feature? It is not free.
Dec 09, 2012 | Samsung Galaxy S Iii Gt-i9300 - 16gb -...
I need user manual for Deni Vaccum Sealer
Manuals for the Deni Vacuum Sealers can be found on the Deni website. Manuals are available for models: 1331, 1910, 1920 and 1921.
The manual for the 1831 is available here and the manual for the1715 is available here.
If your model is not one of these I suggest you try contacting Deni Customer Service: 800-DENI-VAC (800-336-4822)
Trust this is helpful.
Mar 02, 2012 | Ice Cream Makers
The phone will not allow me to feature 75 to pick up another rining line. It states denied in admin
Your telephone technician would have to issue you this access since it's a setting at the main telephone switch.
Jan 12, 2011 | NorStar M7208 Corded Phone
I should be able to use Feature 75 to pick up an incoming call; however, when I try the phone tells me that it is denied in admin. How do I fix this?
more than likely your not in the same pick up group as the phone that is ringing. Instead of setting up pick up groups you could use feature 76 (directed pick up) if you know which set is ringing.
Apr 08, 2010 | Nortel T7316E 2-Line Corded Phone
No owner's book
I had the same problem. I went to Deni's Website www.deni.com and usedthe contact us form and asked for the manual. I had it the next morning. If you know where I can post the PDF, let me know and I will post it for download.
Mar 08, 2009 | Deni 9100 Combo Cooker Deep Fryer
I cannot remove do not disturb
Feature 69 is priority call.
Feature 85 is DND
To cancel a feature you need to insert a "#" before teh feature number, example:
to cancel DND:
press feature"#85"
Nov 28, 2008 | NorStar Meridian M7310 Phone
Access Denied
Dear joanmyers,
You may want to try the CONFIG mode to change the time. Press Feature **266344 and depending on they version of the software (i.e, DR5) you may be able to change the time in the system configuration.
Jul 17, 2008 | Nortel Meridian M7208 Corded Phone
DND Feature turned on
DND feature is 85.
To cancel DND press FEATURE # 8 5 on the set with the issue.
Feature 69 is for priority calling...
Feb 29, 2008 | NorStar Meridian M7310 Phone
Lands Phones Logo
296 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
