Question about Frigidaire Electric Dryer
Dryer turns on then shuts off. Will turn back on after cools down
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon Friend,
I understand that your Frigidaire dryer turns on and then shuts off. I also see that it will turn back on after it cools down. I will be more than happy to assist you. If I could please have the model number of your dryer, this way I can better assist you in resolving the troubles with your dryer. Looking forward to hearing from you.
WP
Posted on May 16, 2014
Shutting off won't start when hot
The windings in the motor are bad and the motor will need to be replaced. Here is the motor to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 17, 2012 | LG Home Applaince LG DLE0442W 7.3 Cu. Ft....
Kenmore Elite Electric Dryer - in recent days the dryer will not start but makes a buzzing noise. If the dryer starts it may tumble for 2-3 to three minutes and then shut down. When the unit shuts down...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 18, 2011 | Kenmore 74892 Gas Dryer
Dryer will turn on but when it gets to hot it shuts off and when it cools back down it will turn back on.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
May 16, 2011 | Whirlpool LER5636P Electric Dryer
Why would my dryer get hot than after a couple minutes shut down and not turn back on until it cools down? Could it be a thermostat or weak gas valve?
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Dec 26, 2010 | Amana ALG443RAW Gas Dryer
Clothes dryer is overheating and then shuts off
Your vent pipe is probably clogged with lint. Clean out, and blow out, if possible, If the vent is clogged, the air cannot properly escape and all that heat stays in the dryer, which probably sets off some kind of themal protection switch, preventing the dryer from running until it cools down.
Oct 10, 2009 | Kenmore 73932 Gas Dryer
Dryer runs for a few mins. then shuts off and turns on after a while
Hi, The motor is overheating and shutting off on an overload.
The motor will need changed. Let me know if I can assist you further.
Vic
May 30, 2009 | Dryers
Dryer not working
Belt is snapped
Drum cant turn , machine gets hot because the drum provides the airflow , thermal overload kicks in machine shuts down.
Resets when it has cooled.
Get someone to take the back off or tip it backwards and see if there is a belt laying on the chassis or the floor
May 25, 2009 | Dryers
Dryer shts down during load
Have not solved problem but after messing with it more I think that the hi limit themostat may be the problem. It seems like if I let the dryer cool down then try it again it seems to work fine for awhile. Does this sound like something that may cause it to shut down. The load problem didn't seem to a factor for I reloaded it with the original load weight. I have not replaced part yet going to try few more loads soon.
Jan 26, 2009 | Whirlpool LER4634J Electric Dryer
Dryer turns off after one minute.
Sounds as if your high temperature thermostat is going bad or is bad. Check your thermostats. If your dryer gets to hot this will shut it down for safety reason!
Jan 09, 2009 | Kenmore 66832 Dryer
Frigidaire  Electric Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
