Question about Alpine Car Audio & Video
No sound out of my cde-141 - Alpine Car Audio & Video
Where can I find the audio diagram of this scar stereo
90% of stereo wire harness are the same colors, so here you gohttp://columbiaisa.50webs.com/car_audio_typical_hu_wiring_colors.jpg
Jul 14, 2015 | Alpine CDE-141 CD/MP3 Car Stereo Receiver...
Alpine CDE 141 will not output to sub
Your description is not very clear but my guess is that the output from the RCA connector on the head unit (receiver) is low level and intended to be connected to an amplifier input. Apparently the 3.5 mm "jack" (plug) connects something to the RCA input of the amp and that works.
Nov 24, 2013 | Alpine Car Audio & Video
Alpine cde 133bt no sound
check trouble shooting methods on the manufactures website http://support.alpine-usa.com/products/documents/OM_CDE-133BT_EN.pdf
http://www.alpine-usa.com/product/view/cde-133bt/Specs
Hope this helps also check your wires make sure they match up
May 31, 2013 | Car Audio & Video
Alpine cde-9842 clock set
  1. In the Clock priority mode, press and holdTITLE for at least 2 seconds while the time is displayed.The time indication will blink.
  2. Turn the Rotary encoder CDE-9846 only) or press "up" and "down" (CDE-9842 only) to adjust the hours while the time indication is blinking.
  3. When the hour has been adjusted, press the Rotary encoder (CDE-9846 only) or press MODE (CDE-9842 only).
  4. Turn the Rotary encoder (CDE-9846 only) or press "up" and "down" (CDE-9842 only) to adjust the minutes while the time indication is blinking.
  5. The time is automatically set 5 seconds after the minute adjustment.
  6. The time can also be manually set by pressing the Rotary encoder (CDE-9846 only) or press MODE (CDE-9842 only).
Download Alpine CDE 9842 Manual
Feb 05, 2013 | Alpine CDE-9846 CD/MP3 Car Stereo
How do you set minutes on clock?
Settin Time
1 In the Clock priority mode, press and hold
displayed.
2 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press 4 and 3 (CDE-9841 only) to adjust
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9845/CDE-9843 only) or
press MODE (CDE-9841 only).
4 Turn the Rotary encoder (CDE-9845/CDE-9843
adjustment. The time can also be manually set by
pressing the Rotary encoder (CDE-9845/CDE-9843 only)
or press MODE (CDE-9841 only).
6. To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9845/
CDE-9843 only) or press and hold MODE (CDE-9841 only) for at
least 2 seconds after setting the "hour." Minutes will reset to 00. If
the display shows over "30" minutes when you do this, the time
will advance one hour.
Or you can ge tthe manual on the link below.
Mar 11, 2012 | Alpine CDE-9841 CD Player
How do i set the time on my alpine cde 9841?
Setting Time
displayed.
• To synchronize the clock to another clock/watch or radio time
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/500/500CDE9843.PDF
Jun 17, 2011 | Alpine CDE-9841 CD Player
Alpine CDE-102 w/usb port: will not
Hello desoren,
The receiver may not be set to recognize MP3 files.
Press and hold "sound setup" until the unit enters setup mode. Rotate the volume knob to "play mode" and press "enter". Check that the setting is CD/MP3 (not CD/MA), or rotate the volume knob to change the setting to CD/MP3 and press enter again. Press and hold "sound setup" again until the unit exits sound setup.
If the files are still not recognized, I'd try using a different USB drive, a different computer to write the MP3's, and/or a different application to download or rip the original music content.
Hope this helps.
Sep 23, 2009 | Alpine CDE-102Ri CD Reciever, iPod and USB...
Can't set the clock
Pasted from the manual:
TITLE/ for at least 2 seconds while the time is
displayed.
2 Turn the Rotary encoder (CDE-9846 only) or
press
up or down arrow (CDE-9842 only) to adjust the
(CDE-9842 only).
4 Turn the Rotary encoder (CDE-9846 only) or
press
Oct 15, 2008 | Alpine CDE-9842 CD Player
Alpine CDE-9843
Page 16 of the manual:
http://vault.alpine-usa.com/products/documents/CDE-9841,%2043,%2045%20OM.PDF
Setting Time
displayed.
only) or press
only) or press
least 2 seconds after setting the “hour.” Minutes will reset to 00. If
the display shows over “30” minutes when you do this, the time
Apr 26, 2008 | Alpine CDE-9843 CD Player
Alpine cde-9843 . i hand it in and working for 3 days then no sound.
Try a CD lens cleaner[A disk with a little brush and a bottle of fluid. But be prepared for a new player - once the lasers goes its trash can time.
Jun 30, 2007 | Alpine CDE-9843 CD Player
Car Audio & Video Logo
20 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
