I have had a number of problems with the printer. The drum and error light are continual flashing. I have installed a new driver and toner cartridge as well as the printer to usb cable. I reinstalled the drivers and now the icon for printers and faxes is not showing up Please advise Dr. Mike Knaus
  • 3 more comments
  • michael927 Jun 23, 2009
    thanks for the info. I have found device manager what icon will show the printers it is not listed on the drop down menu
    i did find printers and the hl 2140 is listed on there as working properly.
    have done all you advised and i still have the problem
    unable to printer on this printer have reinstalled drivers the drum and error message are blinking.
    Checked the device manager and it says the the device is working properly have installed new cartridge and drum.
    Dr. Knaus
    what is firmware?
  • 11,896 Answers
You will need to replace the drum and reset the printer. The drums do have a fairly high failure rate.
If you have installed all new parts and are still getting errror code, you may have a fualty motherboard or the firmware needs to be upgraded.
Posted on Jun 23, 2009
  • Nate Stansfield
    Nate Stansfield Jun 23, 2009
    The software/hardware compatablility and communication.
    President:
  • 1,383 Answers
I f you get drum error in printer you have pull inkmcartdges and clean all thing from dust.
Then check.
Also clean ink cartrdges.
and connect your usb cable to usb port of computer then check in device maanger that your printer is found ad new hardware or unknown device?
You cna go to device maanger in my computer property.
then hardware ->then u can see device maanger.
  • kishor
    kishor Jun 23, 2009
    Now check on printer you get ant error on printer.
    Then check.
    Also clean ink cartridges.
  • kishor
    kishor Jun 23, 2009
    go to control panel and open printer and faxes then open your printer icon then print test page
    Pl;ease let me know.
I HAVE REPLACED TONER WITH THE CORRECT BROTHER TONER CARRTRIDGE AND THE MACHINE KEEPS TELLING ME TONER ERROR AND REINSTALL DRUM UNIT..HELP
Below are instructions that I have found from the internet. Hope that they will help.
  • Open the front cover of the printer.
  • Hold down the Go button for 4 seconds until all the LEDs light up. Then release the Go button
  • Remove the drum unit and toner cartridge assembly.
  • Replace the drum unit and toner cartridge assembly back into the printer.
  • Close the front cover of the printer
  • Your drum unit should now be reset
  • MFC / DCP PRINTER SERIES
    1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
    2.Replace the drum unit and toner cartridge into printer.
    3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
    4.To clear this error message, you need to reset the drum counter as instructed below.
    5.Make sure that the machine is turned on.
    For MFC users: To confirm you are installing a new drum, press 1. For DCP users To confirm you are installing a new drum, press the Up Arrow key
    7.When the LCD shows Accepted, close the front cover.
    8.Your drum is now reset.
    Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
Feb 24, 2015 | Brother MFC-8860DN Printer
Printer Problem
The drum has come to the end of its life. You should replace the drum assembly and reset the drum counter. Here is the procedure:
power off and open front door
hold down the continue button as you power on printer leaving front door open
when error light comes on release continue and close front door.
toner low, load paper, ready, and continue will all be lit.
press cancel slowly 4 times or until just toner low lights up. each time you press cancel, the light sequence should change
when just toner low is lit, press and hold continue button until lights cycle up and down in sequence.
release continue.. toner low will be lit again
turn printer off, wait 10 secs or so and then back on
press continue button to print off settings page and check under cartridge information, photoconductor value is 0K (zero)
Apr 09, 2014 | Dell 1720dn Laser Printer
All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Jun 26, 2009 | Brother HL-2170W Laser Printer
Replaced drum on Dell 1720dn printer. Where is
This should fix the drum light being on that 1720
Turn off the power using the switch on the back of the printer. Open the front door of the printer. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit. Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit. Cycle the power of the printer: Remove the power cable - Wait for 5 seconds - Plug the power cable back to the printer - Power the Printer on.
May 13, 2009 | Dell 1720dn Laser Printer
The drum light came on (Brother HL 5240) and I replaced the drum with a new one and it still will not work... Any suggestions?
I continued looking and found where someone else had the same problem. I opened the front cover, held down the go key for 10 seconds and closed the door. This reset something because it works now.
Thanks
Jan 20, 2009 | Brother HL-5240 Laser Printer
Dell 1720dn toner error
You have to reset the drum count on the printer after you replace the drum. Call dell tech support they will not charge you for help resetting the drum even if you are not in warrenty.
Nov 16, 2008 | Dell 1710n Laser Printer
New toners and drums, but flashing amber error light - won't print now
Have you replaced the printer drums? The status monitor will tell you what percent they are at (similar to the toner cartridge status). This fixed my problem before.
Jun 07, 2008 | OKI C3400n Laser Printer
1700 Drum Error
hold cancel button down with door open, this should rest it
Mar 27, 2008 | Dell 1700n Laser Printer
Computers & Internet Logo
67 people viewed this question
Alun Cox
David Payne
David Payne
