Question about Peg Perego Gaucho Superpower
Electrical problems installed new battery and can not get either light to turn on
Will not crank over to start and nothing electrical works. Just installed a new battery. What can cause this problem? It was working fine when parked 3 weeks ago.
Test the battery with a voltmeter, if good, check connection to battery. Has to have a real good ground.
Mar 15, 2016 | ATVs
No Electrical Power
You'll need to use a test light or meter to follow the power from the battery to the main fuse box. Check the ground connections also.
Feb 20, 2014 | 1986 Toyota Land Cruiser
I have a Yamaha Raptor 700r battery powered atv, I have a new charged battery and when it is installed the battery power indicator lights doesn't light up at all. I know the battery works because I use it...
Assuming the Raptor does not start:
The main fuse and the fuse box are located under
the seat. There should be a spare fuse there also. Turn the key to
OFF and turn off all electrical circuits. Replace any blown fuses.Turn the key to ON and turn on the electrical circuits to check if the devices operates. If the fuse immediately blows again, have a Yamaha dealer check the electrical system.
I found this in the online owners manual at this site:
http://www.yamaha-motor.com/assets/service/manuals/2008/LIT-11626-21-12_Raptor700_SE_1516.pdf
Maybe the manual will help troubleshoot your problem.
Jan 05, 2014 | Toys
I try to start my Lincoln town car and when I turn the ignition on the electrical battery system goes down but won't turn over. I have installed a new car battery
You would need to take a meter or test light and check for power after the battery. You could have a bad connection inside one of the cables.
There should be 12 volts at the battery post and at the cable end on the starter. Also be sure and check the ground connections.
Jan 30, 2013 | Lincoln Town Car Cars & Trucks
Problems starting my van. new battery but one quiet click and it all goes dead
When the van was parked, was it in an area where mice or other rodents could get to it? If so, check for chewed wires near top of engine compartment and under van near starter.
Apr 09, 2017 | Toyota HiAce Cars & Trucks
I need to replace the driver's side brake light.
Rear Combination Light- 2007 might vary from these diagrams:
Removal & Installation 2004 (Early Production) 4 Door To Remove:
  1. Disconnect battery negative cable.
  2. Disconnect electrical connector. Rear Combination Light kia-06-18-7495.gif
  3. Remove 2 screws and 2 nuts and remove light assembly.
To Install:
  1. Install light assembly and 2 screws and 2 nuts.
  2. Connect electrical connector.
  3. Connect battery negative cable.
5 Door To Remove:
  2. Disconnect electrical connector. Rear combination light kia-06-18-7496.gif
  3. Remove 2 screws and push light assembly toward outside of vehicle. CAUTION
    Use care to not damage gasket.
  4. Pull rear combination light from vehicle.
To Install:
  1. Install rear combination light and 2 screws.
  2. Install 2 screws.
  3. Connect electrical connector.
  4. Connect battery negative cable.
2004 (Late Production), 2005-2009 To Remove:
  2. Remove 2 screws and cover inside trunk.
  3. Remove 4 nuts and disconnect electrical connector (A).
  4. Remove rear combination lamp.
To Install:
  1. Install rear combination lamp.
  2. Install 4 nuts and connect electrical connector (A).
  3. Install cover inside trunk and install 2 screws.
Oct 28, 2010 | 2007 Kia Spectra5
My problem is on the brake light switch everithing started when i replaced brackes booster didn't put the retainer clip back week later i start to have problems can't get it off parking is an automatic 97...
I think that it requires a new retainer on the brake pedal stud.
--- Brake Light Switch Removal & Installation To Remove:
  1. Disconnect the negative battery cable.
  2. Disable the air bag system. Refer to Chassis Electrical.
  3. Use snap ring pliers to remove the pushrod retainer from the stud on the brake pedal.
  4. Unsnap the brake light switch from the pushrod.
  5. Disconnect the electrical connector from the brake light switch.
To Install:
  1. Connect the electrical connector to the brake light switch.
  2. Snap the brake light switch on the pushrod.
  3. Install a new retainer on the brake pedal stud. Use a 7/16 in (11 mm) socket to push the retainer on the stud.
  4. Connect the negative battery cable.
  5. Enable the air bag system. Refer to Chassis Electrical.
Oct 08, 2010 | 1997 GMC Sierra
Battery loose power
I had a very similar problem on my daughter's VW New Beetle. The garage checked the electrical system, installed a new battery, and within days the battery was dead once again. After quite a bit of hunting and tweeking the problem was isolated to an electrical connection to the hood release latch. The electrical connection was shorting out, and the battery was being drained. I replaced the item that was connected to the hood latch, and the problem never happened again. The garage wasn't sophisticated enough to find a "small electrical drain" but the VW dealer was.
Jun 04, 2009 | 2002 Volkswagen Jetta TDI
Peg Perego Gaucho Superpower Logo
73 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
