Question about Samsung Dryers
Why Samsung Steam dryer does not get hot, no codes or errors?
My Samsung Steam Dryer (Model DV448EP) was in use yesterday, when it no longer hot... no error codes or reason was noted... any ideas?
the dr
  • 447 Answers
SOURCE: Error Code F2
That means the sensor that tells the computer what temp the drum (and the clothes) are so it can cycle the heater on or off according has failed. Please rate my help as solved if i answered your question! THANX
Posted on Oct 03, 2007
Illeagle
  • 525 Answers
SOURCE: Error code PF
PF means Power Failure!
Unplug both units for 10 minutes, then plug them back in and try operating them. You may need an electrician to investigate why you are losing power to both units
Posted on Jun 04, 2008
SOURCE: My Frigidaire Electric Dryer keeps giving an error code
If your dryer is the same or similar to mine (Model AEQ6000ES2) then error E68 is a stuck key on the keypad. This may be mechanically stuck or the membrane contacts. The simple solution is to replace the keypad.
I found this information by searching for "Frigidaire Model AEQ6000ES2"
Posted on Mar 30, 2009
SOURCE: Error code LOC on frigidaire front load dryer
hold down "OPTION and "SELECT" button at simaltaniously until screen resets. This should work for you.
Posted on Jun 07, 2009
SOURCE: samsung gas dryer convert to propane
I purchased a Samsung steam gas dryer and found that no one in our area knew anything about them, Fortunately I am a gas tech. but have never worked on this brand. The first thing is you should always use a gas technician before doing this. Secondly turn off the gas and electricity. You must remove the two screws from the back that hold on the top of the appliance and set this aside. Then lift up the front electronics and disconnect the wiring harness, once you've done this there are 5 screws along the top of the silver strip or door area. This will alow you to lift up the front and disconnect the wiring harness and set aside. now you can follow the instructions on converting your dryer. PLEASE check for LEAKS and proper gas flow. Follow the same steps in reverse to put the dryer back together and happy drying.
Posted on Jul 01, 2009
SAMSUNG steam moisture sensor front load dryer has noises coming from it. Need help to pinpoint possible problems and how to fix.
You may have a roller out of alignment or off track with the drum now if you took the front panel off. Check to make sure the rollers are on track and the front slides may need t o be replaced if your dryer is a 2 roller model.
Feb 08, 2017 | Samsung Dryers
Troubleshooting heating element on samsung steam dryer
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot or not heat at all. . If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Dec 10, 2016 | Samsung Dryers
Why would a Samsung gas dryer, model DV400GWHDWR-AA cutout and show a FE code after about three seconds after pressing the start button?
Samsung Dryer Error Code = FE
Error Condition = Power supply out of range (frequency)
Check and or Repair = If the dryer is getting the power it requires then replace the electronic control panel board.
Parts For Replacement = Electronic Control Board
Sep 26, 2016 | Samsung Dryers
Dryer comes on but won't start any cycle. What could be causing this?
Samsung Dryer Won't Start - Model DV448AGPXAA - Repair ...
www.repairclinic.com/...Dryer/...-/Samsung-Dryer-won-t-start-DV448A...
Samsung dryer won't start? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Dryer Won't Start - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/How-To...Dryer/...---/Dryer-won-t-sta...
If the dryer hums but does not start, the start switch is not at fault. If the dryer does not respond or make any noise, the start switch could be at fault. Use a ...
Troubleshooting Why Your Dryer Won't Start ' PartSelect ...
? 4:47
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
Oct 14, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer might not be starting. ... If it makes noise but won't start trying spinning the drum empty ten times then close door and try it. ... I changed the door switch and still gives code AU. any suggestions .... thermal fuse everything seems good except my dryer won't come on!!!.
Samsung Dryer DV431AEP - won't start cycle - Appliance Repai
Jan 10, 2016 | Samsung Dv410aew 7.4 Cuft 11-cycle Steam...
Samsung Steam Dryer has power but only displays a flashing smiling person. The dial will not turn and will not start cycle??
Maybe you press lock button, simply unlock it again try this one
? What is the "Child Lock" function?
• If you press the "Child Lock" button (Spin+Option button) longer than 2 sec during operation, this
function is selected.
• If once this function is selected, no change can be done until the end of laundry.
• Press the "Child Lock" button (Spin+Option button) longer than 2 sec to cancel the function
Jan 19, 2015 | Samsung DV419AEW 7.4 Cu. Ft. Electric...
I have a samsung DV220AGW I'm getting an error code of AE or RE. The dryer will spin and heat up but after about a minute it will stop and display the error code. I've had no luck finding...
Hello Dan;
My name is Peter. I am a retired field service appliance technician.
You have a air flow problem. This will shut down the dryer.
AE= Air Exhaust. There is a hot air distribution manifold in the back of your dryer. This is an elongated cover plate. At the smaller bottom is the blower hot air discharge and at the top is the hot air discharge into the dryer. At the bottom of the manifold is where you are plugged up. This is a common problem for just about all dryers. It is plugged with lint. This is item #17
The manifold is held in place with several screws and easily removed. Unplug your unit before the start of any work.
You may also have a rotary fan wheel that is jammed with lint.
This is more difficult to access. It will require the removal of the dryer top and front panels.
There are also several sensors that may shut your unit down. But for now I would go with a plugged up exhaust manifold.
25281118-sy2vaml5ip4mff3cv0drpm3g-2-15.png 25281118-sy2vaml5ip4mff3cv0drpm3g-2-24.png
Nov 13, 2014 | Samsung Dryers
Why won't my Samsung Dryer run?
is there any error codes?just had a dryer with an he error and found it had a bad thermistor located on the back of the blower wheel housing.send model number and any error code
Sep 02, 2014 | Samsung DV218AEW Electric Dryer
Model dv209aewxaa timer counts down but nothing else is runing
Belt came off?? see We fixed our dryer!! so happy!! First We ordered the dryer belt with part # Samsung Dryer Belt 66002-001655. I got it off Amazon at a good price $11-13 at http://www.amazon.com/gp/product/B001KGX...THANK GOD we ordered it just in case because it turned out the belt had NOT slipped off but was SHREDDED apart. The BEST ADVICE to this particular model Samsung VRT steam dryer DV419AEW came from a commenter to another thread . Follow this thread if you have Samsung VRT steam dryer with model # DV419AEW= this threadhttp://www.fixya.com/support/t1210394-sa... The comment at the BOTTOM of the reply made by "dumb-stump". He describes how you take apart this particlar model. I also watched the youtube video on belt placement http://www.youtube.com/watch?v=obaoSDbzY... This shows how to place on pulleys etc once you get belt around the drum.
Jan 29, 2013 | Samsung Dryers
SAMSUNG GAS DRYER DV 328 RUNS FOR A WHILE AND THEN STOPS . I GET ERROR CODE EO. THE CLOTHES IN THE DRYER ARE VERY HOT. AFTER A PERIOD OF TIME THE DRYER COOLS DOWN AND STARTS TO WORK AGAIN. THE DRYER...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 14, 2011 | Dryers
Dryers Logo
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
