Can I Put a Normende Tv Model NM32780 on the wall
I have a panasonic viera plasma tv model number TC-P60U50, where on tv do I put brackets to mount to the wall?
You will need to purchase a suitable wall mount separately. (You'll need one for LARGE TVs.) On the back of your TV set you'll see there are 4 holes in the lower-central region of the rear panel. They are about 20" apart (left-right) and about 12" apart (up-down) These should match up with the bracket that comes with your wall mount. You will need M8 metric screws that are about 1.25" long. These will also be included with the wall mount. (Which will include some general directions for wall mounting.)
Here is a manual for your TV:
PANASONIC Viera TC P60U50 Owner Manual Page 7
Feb 09, 2016 | Panasonic Televison & Video
HOW TO RESET NORMENDE REMOTE
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 09, 2014 | Televison & Video
Wall mount Sanyo LCD-32xr8DA
look at the middle of the tv the 4 screw mount thats wre the tv wall mount gos. good luck
Jun 15, 2013 | Televison & Video
How can I put. On my led tv on the wall
You need to purchase a wall bracket for your TV. There are several types on the market. Make sure the mountind holes on the TV line up with the wall bracket mounting holes and it can support the weight of your TV.
Google search for a wall mounting bracket for your model TV.
Nov 21, 2011 | Televison & Video
I have a normende tv and it wont turn on and has no sound?
hi there: kindly do this simple steps:
step 1: check if the fuses inside are blown up. then replace it.
step 2: if step 1 is okay, check the continuity of the power cord .
step 3: check the speaker if not okay . replace it.
May 02, 2011 | Televison & Video
Have a Nordmende NM32780 tv it keeps powering off itself and its not the power button sticking. Any ideas?
nordmende nu323lv lslcd it wont power on and is stuck in standbye any ideas???
Jul 04, 2010 | Televison & Video
Can thris protron tv be mounted on a wall?
it can be mounted, they sell a universal hanging kit, you will see 4 holes in the back of the tv, thats where you put the screws for the mount
Jan 11, 2009 | Protron PLTV-4250 42 in. LCD Television
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
