Question about Sport & Outdoor - Others
What are the difference between terestrial and jovian planets?
What IS Mercury Retrograde?
In horoscopes the planets move through the Zodiac. However due to the fact that some planets have different orbits, that in the sky they appear to move backwards. Which is what astrologies call retrograde motion. Of course the planet doesn't go backwards at all. However when calculating the birth chart or doing any astrological chart, any planet going backwards is noted. Astrologers attach great significance to a planet going backwards. Though not all do. For example as Mercury controls communication, it going backwards might interfere with that.
Jan 04, 2017 | Horoscopes
Name five features of Jupiter
Great Red Spot
The Stripes
The Jovian Rings (yes, it does)
The largest moon in the Solar System, Ganymede
The White Ovals
The shortest day of all planets
The greatest mass of all planets, more than all the others combined
Nov 18, 2016 | Computers & Internet
Name all the planets people have walked on
Earth. That's it. The moon isn't a planet.
No way of really knowing the number of people who have walked on Earth. It's a tad over 7 billion right now but how do you count all the ones who have lived and died?
Oct 14, 2016 | Optics
Do a recording on my thomson dv3 digital terestrial recorder
The Thomson DV3 is now called Top Up TV. The manuals for the product are here: http://www.topuptv.co.uk/help+centre/downloads
This site also gives the codes to make the Top Up TV box control your TV volume. Hope this helps.
Sep 16, 2014 | Televison & Video
What are planets named after
The 5 planets visible to the eye have been known for all human history, and have therefore had many names in different cultures. Eventually except for Earth, the names of the planets came to be from Roman and Greek mythology, like much else we have inherited.
Then when Uranus was discovered this tradition was already established, although its discoverer Herschel wanted to call it planet George, after the King. What a cringe.
When Pluto was discovered there was a sort of unofficial poll or contest, with the result we know, because Pluto is the god of the underworld, cold and dark.
http://rome.mrdonn.org/romangods/planets.html
May 28, 2014 | Cambridge University Press Planets To...
Can we stop the rapid destruction of this planet ?
The way things are going this planet will survive until the sun goes nova or burns out. Whether humans survive that long or go the way of the dinosaurs is a different matter.
Jan 10, 2014 | Animal Planet Sherpa Pet Blanket Brown
When i publish a level it doesn't appear on the community front planet? Can you help me?
it may have been categorized in a different area, so use l1 and r1 to find it. also, search for authors and put in your username.
Feb 03, 2010 | Sony Little Big Planet
PLANET WL-8310 Wireless Adapter - "Code 10" error on WinXP
I had to format and to install WinXP again. But this time I installed the Adapter first, and then the motherboard's chipset.
Now it works.
Jan 03, 2009 | Planet Technology WL-8310 (WL8310)...
Telescope
the image in your telescope is suposed to be upside down (you'll find it's back to front too!). The reason for this is to get as much light to the eye as possible, the more lenses/mirrors the light has to go through/reflect off, the greater the light loss, and in astronomy you need all the light you can get.
For terestrial viewing, you can purchase, quite cheeply, an image erecting adaptor. This will make your image the right way up. For the best terestrial viewing, you can still purchase prismatic adaptors. Best bet would be ebay.
If I can be of any further help, don't hesitate
Cheers.....Dave
Mar 11, 2008 | Meade TeleStar DS-2114ATSA Telescope
Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
Jan 30, 2008 | Televison & Video
Sport & Outdoor - Others Logo
229 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
