Question about Garmin Nuvi 360 Bilingual GPS Navigator and Personal Travel Assistant GPS Receiver
I need to change the home address on garmin nuvi 360
eagle338
  • 4889 Answers
SOURCE: Reboot the Nuvi 360 to "Mass Storage Mode"
Try these two reset procedures
Procedure 1:
1)disconnect nuvi from external power
2)Flip up GPS antenna
3)Press the reset button
4)Connect nuvi to power source. The nuvi should turn back on and operate normally
procedure 2:
1)Hold your finger on the upper-right corner of the nuvi's screen while you turn it on. keep your finger until the pop-up window appears
2)Touch YES. All factory settings are restored. Your recent selections and audio bookmarks are also deleted
Posted on Sep 30, 2008
  • 3 Answers
SOURCE: Garmin Nuvi 360 - Acquiring Satellites
I had a problem with my Nuvi 360 that it couldn't find the satellites. I couldn't solve the problem with resets or updated software, but a new, external antenna that plugs into the side of the folding antenna seems to have solved the problem. Available from Wireless Finest through Amazon.com - like $11.50. Great solution - can't beat the price.
Posted on Mar 03, 2009
the kowalski
  • 86 Answers
SOURCE: need to know how to reset home address....Picked wrong one.
To remove the Home Address, do the following:
  • Choose "Where to?"
  • Select "Favorites"
  • Find "Home" in the list
  • Press "Edit" -> "Remove" -> "Yes"
Your home position is now removed, and you can add a new one.
Posted on Jun 04, 2009
HarryHarley
  • 343 Answers
SOURCE: Need to know how to charge garmin nuvi 255w using
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are three ways to charge the internal battery in your automotive GPS unit.1
  1. Use the provided vehicle power cable that came with your GPS unit. The unit will charge while powered on and using the device as well as when the GPS unit is powered off and plugged into a running vehicle. About 3 hrs for a full charge. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
  2. Use an AC power adaptor. Some units come with this power cable to plug the GPS unit into a wall outlet allowing the GPS unit to take a charge. For units that do not come with this cable, one can be purchased from Garmin's online store.
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer (like a full day) than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
1 - Please note that temperature can play an effect on the charging of a device. If the battery registers a temperature of 0°C and below or 45°C and above (32°F and 113°F respectively) then it will not charge. When connected to external power it will only be operating off of external power.
2 - The Quest® and Quest® 2 will not charge using a USB cable.
Posted on Feb 06, 2010
SOURCE: change the language on the garmin nuvi 1300
I have just bought a garmin nuvi 1300 and when turned it on the language is german or dutch. We need english but cannot figure out how to change to that seleciton. Help??
Posted on Mar 04, 2011
How do i set home in my nuvi 2505 when the wrong address was added at first
To change the home address on the Nuvi, select Where To? on the left side of the main screen. Then choose Saved > Home and then press i > Edit . After you make the needed changes, press Done. (To edit some Saved items, you have to press Menu (the icon with the horizontal lines) after pressing the i button to see the Edit option.)
The manuals for the Nuvi 2595 LMT and the 2505 are available here: http://support.garmin.com/support/manuals/manuals.htm?partNo=010-01002-01&language=en&country=US .
I hope this helps.
Sep 29, 2012 | Garmin nuvi GPS
Tip
Nuvi 255W Change Home Phone Number
Garmin Nuvi 255W Change Home Phone Number
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Would you like to edit the phone number entry on your Garmin Nuvi 255W for the Call Home option?
To edit your phone number touch:
  1. Where To?
  2. Favorites
  3. Home
  4. Edit
I hope that helps.
____________________________________________
Backup your Nuvi 255W Favorites here.
Download Nuvi 255W Manuals here.
Download Garmin Nuvi 255W WebUpdater here.
Garmin Nuvi 255W Hard Reset here.
on Apr 23, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 265WT Change Home Phone Number
Garmin Nuvi 265WT Change Home Phone Number
Would you like to edit the phone number entry on your Garmin Nuvi 265WT for the Call Home option?
  1. Where To?
  2. Favorites
  3. Home
  4. Edit
I hope that helps.
Erase Nuvi 265WT Phone Numbers here.
Backup your Nuvi 265WT Favorites here.
Download Nuvi 265WT Manuals here.
Download Garmin Nuvi 265WT WebUpdater here.
Garmin Nuvi 265WT Hard Reset here.
on Apr 23, 2010 | Garmin n?vi 265WT Car GPS Receiver
We have a Garmin nuvi 360 that we bought as a factory-refurbished unit. But now we're trying to update software and it says the product has already been registered! It won't let the process proceed. What...
You will have to contact Garmin support and have them change the registration which is matched to an e-mail address and the unit serial number. Device registration on Garmin's site is a "security feature" for two reasons: 1: People can buy lifetime map upgrades for a particular peice of hardware, and 2: GPS units are very high-theft devices.
E-mail support with the details (proof) of your purchase and ask them to change or reset the ownership information for your unit's serial number.
Mar 20, 2010 | Garmin NUVI 360 GPS Receiver
I need to change the home address on my garmin 2 times a year.
Go tothe menu:
Where to (Magnifying glass)
Chose favorites
Choose Home
Down right choose Change
Choose Erase
Then make a new Waypoint named
HOME
Good Luck
Mar 09, 2010 | Garmin nuvi 200W GPS Receiver
How to change home address on garmin
Where to > Favorites > All Favorites > Home > Edit
enter the changes
press Done
If this solves your problem, please come back and rate our solution. Thanks.
Dec 24, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
Need to know how to reset home address....Picked wrong one.
Jun 04, 2009 | Garmin Nuvi 660 GPS Receiver
I need to change the home address on garmin nuvi 760
Go to the Garmin site www.garmin.com and look up the model for guidance. I believe there is a reset button under the plastic cover around the screen the needs to be pushed in. That may do it.
May 31, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
GPS Logo
26 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
