Question about RCA HDLP50W151 50" Rear Projection HDTV
Rca rt2911 fan noisy - RCA HDLP50W151 50" Rear Projection HDTV
RCA RT2911 Home theater with AV receiver
You will have to ask the seller whether local repair, possibly at an authorized service facility, is acceptable.
Jan 04, 2014 | RCA Audio Players & Recorders
Rca rt2911 will not come on at all
Check and replace damaged component/s at its main power regulator section circuit. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Aug 13, 2013 | Televison & Video
My surround system says Sat\opt i need it to say Sat\Coax what do i need to do ?
look for a button on the remote that says input select or something like that. Should be able to switch between input options.
Jul 13, 2013 | RCA RT2911 1000-Watt HDMI Home Theater...
Rca rt2911 beeps
Try with an hdmi cable . I think
Mar 04, 2013 | RCA rt2911 1000-watt hdmir home theater...
DOES THE FAN HAVE TO BE REPLACED? GETTING VERY NOISY
A fan like noise can also be a color wheel which depending on brand and model number (can you confirm brand and model number?) may or may not be sold as a part.
The more you tell me the better I can help you
Mar 12, 2012 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Rca model HD50LPW164YX2 cooling fan sounds
the fan is old and, is off balance (noisy) it can't keep your tv cool so the tv shuts off
open the tv and, remove the fan. replace it with one off e-bay
Sep 10, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Need info on fan for RCA HD50LPW42 TV
Thats a DLP and those fans are noisy. Most of those fans are special and I don't think I can recommend a dealer but you can Google Electronic Parts and pick one. They will need the Model Numbers as well as the Chassis number. There is no guarentee it will be any quiter for very long. You might check with some local TV shops and see if any of them have a good used one. DLP's go bad all the time and many times it's the light engine and the fans are realitively new.
Oct 14, 2008 | RCA HD50LPW42 50" Rear Projection HDTV
RCA HDLP50W151 50" Rear Projection HDTV Logo
77 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
