Question about GE Spacemaker JVM1640SJ Microwave Oven
How do I get the timer to quiot beeping - GE Spacemaker JVM1640SJ Microwave Oven
Microwave started beeping while unplugged
If it beeps for just a few seconds after being unplugged from the wall, that's not a problem.
It's likely just the software or hardware feature utilizing a "sanity timer" to alert you when the oven loses line power. It's similar to a freezer alarm or sump pump alarm.
If this doesn't seem to answer your question or address your situation, please e-mail me and remind me of your symptoms and include your full model number as shown on the label.
Dec 28, 2016 | Microwave Ovens
I have a Galaxy 721. microwave. There is a beep that sounds every minute and the microwave is not being used. I am stumpped! How do I stop the beeping?
Sounds like someone activated the timer function. See if you can find the timer function in the menu, then turn it off.
Dec 31, 2014 | Microwave Ovens
Why does the microwave beep for nothing?
some one may have set the timer to a spassific time and that will set it off
Jul 03, 2014 | Danby DMW753 Microwave Oven
Can't get out of demo mode Westinghouse oven WVE916SA!
DEMONSTRATION MODE – PROGRAMMABLE CONTROLLER MODELS
For display purposes, the appliance has a demonstration mode to enable demonstration of oven functionality without consuming power. In demonstration mode, the display, the light and the fan only are operational.
When the appliance is in demonstration mode and the display is switched on, the clock symbol will be on.
If the appliance is in demonstration mode, to operate the appliance normally the demonstration mode will need to be deactivated.
To deactivate demonstration mode:
1. Ensure the oven is off by pressing the ON/OFF button. 2. Press and hold the ON/OFF button until the display turns
ON then OFF and a single ‘beep’ is heard. Immediately after press and hold the ‘Timer’ and ‘–’ buttons simultaneously, until a triple beep sounds to confirm
the operation.
Nov 15, 2013 | Microwave Ovens
How to change the beep.
Unless that option is mentioned in the owner's manual, no.
May 18, 2013 | DeLonghi P90D23ELT2AH Microwave Oven
The digital clock/timer on my stove has basically quit working. The timer keeps setting to 59 minutes and beeping all day and all night and I cannot set it back to clock after the buzzer goes off. How do...
Your membrane keypad is shorted.
Whether it's available as a separate part, assembly, or if you have to order a whole controller is determined by the model number, which you did not mention.
You can find handy exploded views and order parts by model number here.
May 25, 2011 | Microwave Ovens
Round soft key OXO Timer I need to change the clock time their model # is 1061978
Operating functions:
To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
Sep 18, 2010 | Microwave Ovens
GE xl 1800 beep
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Jul 10, 2008 | GE JVM1660 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
11 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
