Question about Boatmates Boating
How do you reattach a sagging vinyl headliner in the cuddy cabin of a boat?
2003 four winns 225 sundowner has a vinyl headliner in cuddy cabin of boat is sagging, how do I reattach it to the hull?
  • 3 Answers
SOURCE: Wenonah Sundowner ABS Canoe repair
no actually you can't.. but heres an idea. get a couple pieces of gum, and flavor you like, and chew it up till its super duper sticky, then take it out of your mouth and stick it in the hole :) and thats its done,
Posted on Apr 24, 2009
seans46
  • 161 Answers
SOURCE: 1989 Formula Headliner Sag:
3m makes a great spray adhe they sell it at walmart for $10 in the auto section , most of the time do it right in the car remove any side trim and spray between liner and board and smooth down.
Posted on Jun 07, 2009
SOURCE: My headliner is sagging, I have solved the water
I bought my Audi A4 used and it had the same issue. I just had a place that did headliners replace it for like $200 bucks. It's not the same fabric but same Color and looks fine and I don't have to worry about it sagging potientally again!
Posted on Aug 07, 2009
  • 2002 Answers
SOURCE: Sagging headliner
If you can get at the headliner, usually a piece of trim or screws, peel back a small section at the edge and see what it is fastened to. Its probably a piece of cardboard or something similar. If so just pick up a spray can of contact cement or some rubber cement and glue the sagging piece back in place. Don't get too carried away with the glue or it will look "hard" when it dries. Hope this helps.
Posted on Sep 05, 2009
juandiablo
SOURCE: bought a 1995 Four Winns boat inthe dash it has a
I own a 1995 Four Winns and what you need is a Lowrance LSM-1 depth finder unit. It accepts the two pin lead from the transducer and send the depth reading to the dashboard display via the 6-pin connector. There is also a three wire harness (red/blk/wht) that connects to a power supply.
The reason I know all this is my depth finder fried a couple years ago so I removed the Lowrance LSM-1 from the boat in order to find a replacement. Unfortunately, this was an OEM part that is not available from Four Winns or any aftermarket source. Probably your best bet is to look in a boat salvage yard or purchase an aftermarket depth finder.
Posted on Sep 19, 2009
I have an older model stejcraft stallion 5.2 mtr cuddy cabin and need to know the weight of the boat and it has a 75 yamaha motor
Google the weight of the stegecraft then the motor, I did this recently so I could work out the weight I would have on my trailer.
Feb 14, 2017 | Yamaha Boating
Looking to repower 1997 Four Winns bowrider with newer outboard engine. What max HP is boat rated for? Found Yamaha 150 XB 2016 for a good price . Will boat work with a 25 inch shaft? Thanks,Kathy
there should be a manufacturers plate attached to the hull of the boat with a number of passengers it can carry and the max hp motor allowed to be fitted
talk with boat shops as they will know the approximate hp for each make of boat and length
while it may be attractive to fit big hp motors to small boats , it in fact makes the boat less sea worthy and makes capsizing easier so get the advice right from the boat shops
Feb 07, 2017 | Yamaha Boating
1991 four winns boat gets stuck in a gear
What engine, drive, outboard?
Aug 21, 2014 | Boating
Steering problem with a 1984 four winns boat
probably needs a new steering cable.they seize up if not greased regularly
Aug 19, 2014 | Boating
I have a 1995 four winns,with a volvo 4 cyl.motor3.0
You have a timing problem. Check the timing first. If a simple adjustment doesn't fix the problem, check the plug wires. Make sure they are on the right plugs. If they are, your timing chain or belt jumped.
Aug 30, 2009 | Boating
I am looking for a boat manual for a 1995
we contacted a boat place in port isabel
Aug 29, 2009 | Boating
Lowrance depth finder missing adapter cable
Jul 28, 2009 | Boating
Bought a 1995 Four Winns boat inthe dash it has a lowrance dept finder. under dash i see a 6pin male round connector & 2 pin round male hareness is there a harness i need to connect the 2 or what would...
Hi- I have a 1996 Four winns boat with the same problem. I believe we are missing an adapter cable which goes from the depth cable to the instrument panel. I have not been able to locate this cable yet. If I find it I will let you know and can you do the same for me if you locate one?
Jul 03, 2009 | Lowrance Boating
Boating Logo
16 people viewed this question
Top Boatmates Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boatmates Boating Expert? Answer questions, earn points and help others
