Question about Nokia 6288 Cellular Phone
Flex connector where would I find the flex connector in my phone.. and how do I tell if there is a problem. if there is, how can I go about fixing it?thaanks.
  • 45 Answers
Re: flex connector
Remove back cover and battery
you can remove ur front panel by using ur nail it self
u can find white keymat that willbe fixed with flexi , remove it
then remove lcd carefully
unscrew the the four screws in the back panel
then seperate D cover from front panel you can find flex conn
give some little care while removing flexi cable for its position .
plz follow the reci for assembly
Posted on Nov 07, 2007
0 characters
3 Points
5300 nokia display light not working
Usual cause of this phone is losing the flex connector on the upper board,this may happen when the phone drop off the ground or a force of sliding up/down.
To fix this problem,please follow this method.
1. turn off the phone
2. remove the battery
3. slide up the phone
4. at the back of the upper panel,pill the metal shield with a cutter blade.(it's a little bit sticky because of adhesive.)
5. upon seeing a flex connector,check if it's detach or loosen,gently push that connector until it locks or fit (be careful with the lcd in front panel when pushing that connector,might broke it if pushing over)
Now test if gonna work now.
Otherwise,it can be flex connector or LCD screen need to replace,it is more safe if you bring the phone to a mobile service shop for parts replacement.
Good Luck...
Aug 12, 2011 | Cell Phones
I have one nokia 5200 mobile but following problem are there 1) only seen complete blue colour screen 2)no connectivity with pc by using nokia pc suite i want to upload comlete contacts from phone so...
When LCD or the flex connector is damage,it should be readable by the computer,no matter this two parts is not connected.
No matter what the history is,might be drop on the ground or water damage,before doing software method,try to dismantle the upper panel,possible that the flex connector is shortening because its line is hitting some grounds that's why the phone is not powering.
This is my suggestion,
* Remove the back cover and the battery pack.
* Remove the front cover by release the side clips
* unscrew 4 screws connected on the metal frame of the lcd using a T6 screw driver or any tool that can twist or release the screw.
* remove the LCD connector and the LCD itself.
* gently lift up the top pcb or top boad with the lcd is connected,be careful because the is a flex connector underneath,the release the flex connector.
Now try to put the battery and connect the usb cable and turn the phone on,If there is a response on the computer,that means either flex connector or lcd is the problem.
This is the time that you can copy all important files if the computer recognizes the phone using nokia pc suite.
* If this method does not work,you need to ask assistance to any mobile service shop near you,and tell the if it's possible to recover the data on your phone without flashing your phone firmware.
Hope this solution can help you....
Jul 17, 2011 | Nokia 5200 Cellular Phone
My samsung s8300 mobile touch screen is not working, numeric keypad is working & on screen pannel only end button is working.
i bought this and solved the problem. NIKOS GREECE...
Jan 16, 2011 | Samsung S8300 Ultra Touch platinium-red...
Touch screen not working
Hi, The problem with your phone is as a result of a bad flex connector cable which connects the touch screen to the panel,it's weak and needs to be replaced.
However,the solution is to take apart the phone and remove the flex cable which is in form of a ribbon situated behind the touch screen and replace it with a newly purchased flex cable.
Thanks and take care
Aug 02, 2010 | Samsung Star GT-S5233 Cell Phone
I flip the phone open and the screen is blank. Cannot tell if it is on or off.
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Take care.
Jun 12, 2010 | Motorola Mobility RAZR V3
LG display is completly black, however the phone works
The problem is either in the the flex ribbon connector, connector terminals or LCD itself. Disassemble the unit then check the flex ribbon connector for any crack or damage. If no apparent damage is found, clean both the flex terminals and the connector terminals. Resoldering the connector terminals is also suggested. If no result, LCD is damaged, replace it.
Oct 18, 2009 | LG Shine CU720 Cellular Phone
My samsung blast does not have water damage but the screen works intermittently what is the problem?
The problem is in the the flex ribbon connector or in the connector terminals. Disassemble the unit then check the flex ribbon connector for any crack or damage. If no apparent damage is found, clean both the flex terminals and the connector terminals. Resoldering the connector terminals is also suggested.
Oct 18, 2009 | Samsung SGH-G600 Cellular Phone
Phone turn off when I open it (lift the flip)
it has the problem on the FLEX!!! go to the technician it has the chance to fix if you change the flex, tell it about the flex, im rely2 xur cit is the flex is the problem
Mar 28, 2009 | Nokia 6103 Cellular Phone
You need to replace the flexcable on the phone.
Jun 25, 2008 | Motorola Mobility RAZR V3
White screen
open and close it a bunch of times. it works for me.
Aug 23, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Nokia 6288 Cellular Phone Logo
64 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
