Question about Emerson LD195EM8 19 in. LCD TV
How to hook up a tv and laptop - Emerson LD195EM8 19 in. LCD TV
Want to hook pc to tv
Connect HDMI output of laptop to input of tv. If no HDMI output look for laptop video output and get a converter for it to go to the input of tv.
Apr 01, 2016 | Hitachi 46F500 46" Rear Projection...
I HAVE ASUS LAPTOP I WANT TO HOOK IT TO MY FLAT SCREEN TV MADE BYPHILIPS
you can either hook it up to tv with hdmi if your laptop has that or with vga cable
Aug 16, 2014 | Philips Televison & Video
Want to use TV as monitor for laptop
There is no way to hook the TV to the laptop. You can hook the laptop to the TV but not the other way around. It is done with a VGA monitor cord. The same one that you connect to your regular monitor. Your TV will have a plug labeled VGA.
Nov 23, 2013 | Televison & Video
Vga hook up
may need to tell the laptop in the screen resolution settings to display the image on the tv instead of the laptop. Right click on the empty desktop of the laptop and go to either propertie or screen resolution and then make sure that the computer can see that the tv is hooked up and that the image is showing on the tv instead of the laptop. You may also need to change the mode on the tv to vga.
Nov 21, 2013 | Pioneer SD-532HD5 53" Rear Projection...
How do i hook lap top up
Most Laptops have a VGA output port. You would just hook this to the VGA input of the TV for video (picture).
You would then need to hook an audio cable from the laptops headphone jack to the TV's VGA's Audio Input jack.
Newer laptops have a HDMI output so that is easier and can hook directly to the TV's HDMI input for both video and audio.
Nov 13, 2013 | Zenith R57W46 57" Rear Projection...
How do i connect my laptop to my hd tv
you need to have a HDMI socket on your computer.
Apr 11, 2010 | Computers & Internet
What type of cable for laptop to Tv?
In order to hook a laptop or any computer to a tv you have to have the right video card with the correct video connections like hdmi or s-video. If you don't have those connections then you can't hook a laptop to a tv.
May 05, 2009 | Sharp 19 in. LCD HDTV
Trying to hook laptop to tv
try pressing FN key and F8 key to switch between screens. If that doesn't help right click on desktop, select properties, settings tab, click advanced button. there may be something in there to force the TV.
Dec 21, 2008 | Dell Inspiron 8000 Notebook
Lcd hdtv is hooked up to laptop but it is every 10 sec gos black
if theres nothing happening on ur pc like same as tv its probably the tv config ...
check tv setup
check tv screen saver..if it disabled it would explain why screen black...
could try checking power settings in pc(screensaver properties)
Dec 10, 2008 | HP Compaq Presario V6000T Notebook
Hook up laptop to tv
there should be an s-video plugin in the back. if correct, buy an s-video cord and plug it in from your laptop to your tv.
Nov 25, 2008 | Acer Aspire 5580 Notebook
Emerson LD195EM8 19 in. LCD TV Logo
20 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
